Home » Eclipse Projects » EclipseLink » cascade insert not working on Eclipselink event
cascade insert not working on Eclipselink event [message #528048] Mon, 19 April 2010 02:07 Go to next message
If we create and persist an entity in the preInsert Eclipselink event, these are simply not persisted. A PK is assigned, but the insert is not executed. What is the correct place to create and persist a related entity?
Tom
Re: cascade insert not working on Eclipselink event [message #528151 is a reply to message #528048] Mon, 19 April 2010 10:25 Go to previous message
preInsert may be too late, you could try prePersist.
On the preInsert you could also manually insert the new object. Call Session.insertObject(), this may work.
Previous Topic:Problem with ReportQuery
Next Topic:cascade delete not working when cache is active
Current Time: Sun Aug 31 00:37:21 EDT 2025
Powered by FUDForum. Page generated in 0.04385 seconds
