Problem with Spring Remote (RMI) and RCP application [message #528015] |
Sun, 18 April 2010 14:36  |
I am trying to use RMI in client-server RCP application with spring framework. I create four projects: client, common, server and libs. If I define one service no problem, but with two services defined in XML file, a error occurs. When I run the same application in normal java project, without plugins, it works. Has anyone had a similar problem?
This is the XML for server configuration:
<!DOCTYPE beans PUBLIC "-//SPRING//DTD BEAN//EN" "http://www.springframework.org/dtd/spring-beans.dtd">
<beans>
<bean id="remoteServiceA" class="test.rcpspring.server.services.RemoteServiceA">
</bean>
<bean class="org.springframework.remoting.rmi.RmiServiceExporter">
<property name="serviceName" value="remote-service-A"/>
<property name="service" ref="remoteServiceA"/>
<property name="serviceInterface" value="test.rcpspring.common.interfaces.IRemoteServiceA"/>
<property name="registryPort" value="34567"/>
</bean>
<bean id="remoteServiceB" class="test.rcpspring.server.services.RemoteServiceB">
</bean>
<property name="serviceName" value="remote-service-B"/>
<property name="service" ref="remoteServiceB"/>
<property name="serviceInterface" value="test.rcpspring.common.interfaces.IRemoteServiceB"/>
</bean>
</beans>
This is the console output in server:
0 [main] DEBUG org.springframework.core.io.support.PathMatchingResourcePatternResolver - Found Equinox FileLocator for OSGi bundle URL resolution
11 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@3c342b: startup date [Sun Apr 18 20:25:34 CEST 2010]; root of context hierarchy
67 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [conf/rmi-server-context.xml]
70 [main] DEBUG org.springframework.beans.factory.xml.DefaultDocumentLoader - Using JAXP provider [com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderFactoryImpl]
99 [main] DEBUG org.springframework.beans.factory.xml.BeansDtdResolver - Found beans DTD [http://www.springframework.org/dtd/spring-beans.dtd] in classpath: spring-beans.dtd
118 [main] DEBUG org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader - Loading bean definitions
143 [main] DEBUG org.springframework.beans.factory.xml.BeanDefinitionParserDelegate - Neither XML 'id' nor 'name' specified - using generated bean name [org.springframework.remoting.rmi.RmiServiceExporter#0]
144 [main] DEBUG org.springframework.beans.factory.xml.BeanDefinitionParserDelegate - Neither XML 'id' nor 'name' specified - using generated bean name [org.springframework.remoting.rmi.RmiServiceExporter#1]
144 [main] DEBUG org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loaded 4 bean definitions from location pattern [conf/rmi-server-context.xml]
144 [main] DEBUG org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for org.springframework.context.support.ClassPathXmlApplicationContext@3c342b: org.springframework.beans.factory.support.DefaultListableBeanFactory@17ec9f7: defining beans [remoteServiceA,org.springframework.remoting.rmi.RmiServiceExporter#0,remoteServiceB,org.springframework.remoting.rmi.RmiServiceExporter#1]; root of factory hierarchy
165 [main] DEBUG org.springframework.context.support.ClassPathXmlApplicationContext - Unable to locate MessageSource with name 'messageSource': using default [org.springframework.context.support.DelegatingMessageSource@131c89c]
167 [main] DEBUG org.springframework.context.support.ClassPathXmlApplicationContext - Unable to locate ApplicationEventMulticaster with name 'applicationEventMulticaster': using default [org.springframework.context.event.SimpleApplicationEventMulticaster@7a4489]
169 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@17ec9f7: defining beans [remoteServiceA,org.springframework.remoting.rmi.RmiServiceExporter#0,remoteServiceB,org.springframework.remoting.rmi.RmiServiceExporter#1]; root of factory hierarchy
169 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Creating shared instance of singleton bean 'remoteServiceA'
169 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Creating instance of bean 'remoteServiceA'
188 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Eagerly caching bean 'remoteServiceA' to allow for resolving potential circular references
189 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Finished creating instance of bean 'remoteServiceA'
189 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Creating shared instance of singleton bean 'org.springframework.remoting.rmi.RmiServiceExporter#0'
189 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Creating instance of bean 'org.springframework.remoting.rmi.RmiServiceExporter#0'
192 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Eagerly caching bean 'org.springframework.remoting.rmi.RmiServiceExporter#0' to allow for resolving potential circular references
234 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Returning cached instance of singleton bean 'remoteServiceA'
243 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Invoking afterPropertiesSet() on bean with name 'org.springframework.remoting.rmi.RmiServiceExporter#0'
243 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '34567'
262 [main] DEBUG org.springframework.remoting.rmi.RmiServiceExporter - RMI registry access threw exception
java.rmi.ConnectException: Connection refused to host: 127.0.1.1; nested exception is:
java.net.ConnectException: Connection refused
at sun.rmi.transport.tcp.TCPEndpoint.newSocket(TCPEndpoint.java:601)
at sun.rmi.transport.tcp.TCPChannel.createConnection(TCPChannel.java:198)
at sun.rmi.transport.tcp.TCPChannel.newConnection(TCPChannel.java:184)
at sun.rmi.server.UnicastRef.newCall(UnicastRef.java:322)
at sun.rmi.registry.RegistryImpl_Stub.list(Unknown Source)
at org.springframework.remoting.rmi.RmiServiceExporter.testRegistry(RmiServiceExporter.java:415)
at org.springframework.remoting.rmi.RmiServiceExporter.getRegistry(RmiServiceExporter.java:394)
at org.springframework.remoting.rmi.RmiServiceExporter.getRegistry(RmiServiceExporter.java:372)
at org.springframework.remoting.rmi.RmiServiceExporter.getRegistry(RmiServiceExporter.java:331)
at org.springframework.remoting.rmi.RmiServiceExporter.prepare(RmiServiceExporter.java:264)
at org.springframework.remoting.rmi.RmiServiceExporter.afterPropertiesSet(RmiServiceExporter.java:227)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1469)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1409)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:288)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:190)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:563)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:872)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:423)
at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:139)
at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:83)
at test.rcpspring.server.ServerApplication.start(ServerApplication.java:25)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1406)
at org.eclipse.equinox.launcher.Main.main(Main.java:1382)
Caused by: java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:525)
at java.net.Socket.connect(Socket.java:475)
at java.net.Socket.<init>(Socket.java:372)
at java.net.Socket.<init>(Socket.java:186)
at sun.rmi.transport.proxy.RMIDirectSocketFactory.createSocket(RMIDirectSocketFactory.java:22)
at sun.rmi.transport.proxy.RMIMasterSocketFactory.createSocket(RMIMasterSocketFactory.java:128)
at sun.rmi.transport.tcp.TCPEndpoint.newSocket(TCPEndpoint.java:595)
... 37 more
264 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
269 [main] DEBUG org.springframework.remoting.rmi.RmiServiceExporter - RMI service [test.rcpspring.server.services.RemoteServiceA@18bd7f1] is an RMI invoker
282 [main] DEBUG org.springframework.aop.framework.JdkDynamicAopProxy - Creating JDK dynamic proxy: target source is SingletonTargetSource for target object [test.rcpspring.server.services.RemoteServiceA@18bd7f1]
295 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'remote-service-A' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[127.0.1.1:34567](local),objID:[0:0:0, 0]]]]
301 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Finished creating instance of bean 'org.springframework.remoting.rmi.RmiServiceExporter#0'
301 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Creating shared instance of singleton bean 'remoteServiceB'
301 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Creating instance of bean 'remoteServiceB'
302 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Eagerly caching bean 'remoteServiceB' to allow for resolving potential circular references
302 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Finished creating instance of bean 'remoteServiceB'
302 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Creating shared instance of singleton bean 'org.springframework.remoting.rmi.RmiServiceExporter#1'
302 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Creating instance of bean 'org.springframework.remoting.rmi.RmiServiceExporter#1'
302 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Eagerly caching bean 'org.springframework.remoting.rmi.RmiServiceExporter#1' to allow for resolving potential circular references
302 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Returning cached instance of singleton bean 'remoteServiceB'
303 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Invoking afterPropertiesSet() on bean with name 'org.springframework.remoting.rmi.RmiServiceExporter#1'
303 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '34567'
380 [main] DEBUG org.springframework.remoting.rmi.RmiServiceExporter - RMI service [test.rcpspring.server.services.RemoteServiceB@6db724] is an RMI invoker
380 [main] DEBUG org.springframework.aop.framework.JdkDynamicAopProxy - Creating JDK dynamic proxy: target source is SingletonTargetSource for target object [test.rcpspring.server.services.RemoteServiceB@6db724]
387 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'remote-service-B' to RMI registry: RegistryImpl_Stub[UnicastRef [liveRef: [endpoint:[127.0.1.1:34567](remote),objID:[0:0:0, 0]]]]
430 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@17ec9f7: defining beans [remoteServiceA,org.springframework.remoting.rmi.RmiServiceExporter#0,remoteServiceB,org.springframework.remoting.rmi.RmiServiceExporter#1]; root of factory hierarchy
430 [main] DEBUG org.springframework.beans.factory.support.DisposableBeanAdapter - Invoking destroy() on bean with name 'org.springframework.remoting.rmi.RmiServiceExporter#0'
430 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Unbinding RMI service 'remote-service-A' from registry at port '34567'
!SESSION 2010-04-18 20:25:32.957 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_16
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=es_ES
Framework arguments: -product test.rcpspring.server.product
Command-line arguments: -product test.rcpspring.server.product -data /home/jorge/workspace-3.6M6/../runtime-server.product -dev file:/home/jorge/workspace-3.6M6/.metadata/.plugins/org.eclipse.pde.core/server.product/dev.properties -os linux -ws gtk -arch x86 -consoleLog
!ENTRY org.eclipse.osgi 4 0 2010-04-18 20:25:35.044
!MESSAGE Application error
!STACK 1
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.springframework.remoting.rmi.RmiServiceExporter#1' defined in class path resource [conf/rmi-server-context.xml]: Invocation of init method failed; nested exception is java.rmi.ServerException: RemoteException occurred in server thread; nested exception is:
java.rmi.UnmarshalException: error unmarshalling arguments; nested exception is:
java.lang.ClassNotFoundException: org.springframework.remoting.rmi.RmiInvocationHandler (no security manager: RMI class loader disabled)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1412)
Caused by: java.rmi.ServerException: RemoteException occurred in server thread; nested exception is:
at sun.rmi.server.UnicastServerRef.oldDispatch(UnicastServerRef.java:396)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:250)
at sun.rmi.transport.Transport$1.run(Transport.java:159)
at sun.rmi.transport.Transport.serviceCall(Transport.java:155)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:535)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:790)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:649)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
at sun.rmi.transport.StreamRemoteCall.exceptionReceivedFromServer(StreamRemoteCall.java:255)
at sun.rmi.transport.StreamRemoteCall.executeCall(StreamRemoteCall.java:233)
at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:359)
at sun.rmi.registry.RegistryImpl_Stub.rebind(Unknown Source)
at org.springframework.remoting.rmi.RmiServiceExporter.prepare(RmiServiceExporter.java:286)
... 25 more
Caused by: java.rmi.UnmarshalException: error unmarshalling arguments; nested exception is:
at sun.rmi.registry.RegistryImpl_Skel.dispatch(Unknown Source)
at sun.rmi.server.UnicastServerRef.oldDispatch(UnicastServerRef.java:386)
Caused by: java.lang.ClassNotFoundException: org.springframework.remoting.rmi.RmiInvocationHandler (no security manager: RMI class loader disabled)
at sun.rmi.server.LoaderHandler.loadProxyClass(LoaderHandler.java:535)
at java.rmi.server.RMIClassLoader$2.loadProxyClass(RMIClassLoader.java:628)
at java.rmi.server.RMIClassLoader.loadProxyClass(RMIClassLoader.java:294)
at sun.rmi.server.MarshalInputStream.resolveProxyClass(MarshalInputStream.java:238)
at java.io.ObjectInputStream.readProxyDesc(ObjectInputStream.java:1531)
at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.java:1493)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1732)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1329)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java:351)
... 12 more
Re: Problem with Spring Remote (RMI) and RCP application [message #699479 is a reply to message #558269] |
Thu, 21 July 2011 11:53  |
Hi! You have to add:
System.setSecurityManager(new RMISecurityManager());
before:
LocateRegistry.createRegistry(port);
and in bin/dmk.bat:
set KERNEL_JAVA_PARMS=%KERNEL_JAVA_PARMS% -Djava.security.policy="%CONFIG_DIR%\server.policy"
server.policy:
grant codeBase "file:${java.home}/lib/ext/-" {
permission java.security.AllPermission;
// default permissions granted to all domains
grant {
but after that I am having:
on line 291 in RmiServiceexporter class ;/
...and I have imported 'org.springframework.remoting.rmi' package in my bundle ;/
[Updated on: Thu, 21 July 2011 11:54] by Moderator
FUDForum. Page generated in 0.04005 seconds
