Home » Eclipse Projects » GEF » Draw2d Printing to XPS format not operational
Draw2d Printing to XPS format not operational [message #528014] Sun, 18 April 2010 14:32
With Windows 7, and I believe Vista too, Microsoft has introduced a new format as alternative to routing output to a printer called XPS: XML Paper Specification.
In Windows XP, a format called MDI was supported, and Eclipse release 3.5 works find with this, but support for this format from MS is disappearing.
This problem can be demonstrated with a small modification to the PrintExample.jave found in cvs: namely the call "PrintDialog" is added so that the printer can be selected. See below for modification.
I note that GMF does work with XPS! However, GMF uses quite a bit different code, and I wasn't able to spot exactly what is making the difference.
Should I log this into bugzilla?
Steve Punte
Test Lens
== Mod to PrintExample.java
static private void printIt(IFigure fig){
PrintDialog dialog = new PrintDialog(Display.getCurrent().getActiveShell(), SWT.NULL);
PrinterData data = dialog.open();
if (data != null) {
Printer p = new Printer(data);
PrintOperation op = new PrintFigureOperation(p, fig);
op.setPrintMargin(new Insets(0,0,0,0));
op.run("Test"); // "Test" is the print job name
p.dispose();
Previous Topic:Change icon when tool selected from palette
Next Topic:How to use a EditorPart to draw Draw2D figures on it ?
Current Time: Fri Jul 18 20:41:41 EDT 2025
Powered by FUDForum. Page generated in 0.03444 seconds
