Diags.setMaskMeta [message #527943] |
Sat, 17 April 2010 02:38  |
Champs,
I am using Diags.setMaskMeta using wildcard to match all modules within a package.
I have added the line
Diags.setMaskMeta("ti.omx.domx.%", Diags.USER1, Diags.ALWAYS_ON);
as the last line of my config file.
I see that Diags.setMaskMeta iterates thru the xdc.om list of modules and only if a module is used it enables Diag mask.
Now the issue I have is some of the modules in ti.omx.domx will get used during the close() phase after the config step which results in Diags mask never getting enabled for them even though they are used in the executable.
I tried putting the Diags.setMask meta in the close of my executable package but even that doesnt help. Looks like I need to invoke Diags.setMaskMeta only after close() of all packages is complete.
The only way to get Diags.setMaskMeta working is I need to explicitly do a useModule of all Modules in the package and then invoke setMask which defeats the purpose of having wildcard match.
I am using xdc version xdctools_3_16_01_27
Please advise on the right method to resolve this issue,
Badri
Re: Diags.setMaskMeta [message #527978 is a reply to message #527943] |
Sat, 17 April 2010 14:12  |
Diags.setMaskMeta() can only operate on modules currently loaded in the
configuration model. As you point out, setting the diags mask at config
time is problematic when the set of modules in the configuration can
change as packages close. The wildcard only applies to modules used at
the time Diags.setMaskMeta() is called.
I've filed a bug to capture this; Bug 309573 - Diags.setMaskMeta should
affect all used modules in a configuration
One possibility is to use the runtime function Diags_setMask() (which
also accepts limited wildcards).
On 4/16/2010 11:38 PM, Badri wrote:
> Champs,
> a package. I have added the line Diags.setMaskMeta("ti.omx.domx.%",
> executable.
> Diags.setMaskMeta only after close() of all packages is complete. The
> Regards
> Badri
FUDForum. Page generated in 0.02889 seconds
