Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Multi meta models and i don't know them
[Acceleo] Multi meta models and i don't know them [message #527855] |
Fri, 16 April 2010 12:37  |
Hi i'm coding a software generating Acceleo templates (meta generation ?
and i don't know in advance which metamodel will be used. I know the
meta model of the selection (context) for example an UML element. But
the user of my software can access to elements of another meta model.
For example 'CustomMetaModel'. I don't want to force my users to fill
the uri of the metamodel. But they can write a code like this :
-- this is a uml call
[self.name /]
[for self.packagedElement /]
-- this is a call to my custom meta model
property : [self.myCustomProperty/]
[/for]
Is it possible to write this template without declaring the
CustomMetaModel ? is it plan ? do i have to force my users :( ?
Tristan FAURE
Re: [Acceleo] Multi meta models and i don't know them [message #528318 is a reply to message #528137] |
Tue, 20 April 2010 03:23   |
Hi Laurent,
thank you to take a look on my problem.
Actually in my case. I have a module referencing UML metamodel and the
model browsed is an instance of Sysml metamodel.
The generator recognizes UML metamodel because it takes the metamodel of
the selected object (a Package for example).
But when i browse the child of my packages i need to cast to a Block or
anything else from Sysml metamodel. And as i write this I recognize it's
not quite evident ^^
I think i will try other solutions to insert my metamodels :p
Tristan FAURE
Le 19/04/2010 15:55, Laurent Goubet a écrit :
> Hi Tristan,
> I must admit I am quite puzzled as to what you're trying to achieve.
> I'll use my usual scattershot to answer :p.
> Acceleo doesn't force you to write the URI of the metamodel you're
> defining a module for ... if the types can be inferred from the "main"
> metamodel. For example if you define a module on Genmodel (the
> metamodel), and you have a variable of type "GenPackage", you can use
> the following : [genPack.ecorePackage.nsURI/] without declaring the
> Ecore metamodel for your module (even though "ecorePackage" is of type
> "EPackage" and "nsURI" a property defined on EPackage in the ecore
> metamodel, not in the genmodel metamodel).
> However if your "custom meta model" cannot be inferred from anything
> else, for example if [self.myCustomProperty/] needs "self" to be cast
> to the accurate type beforehand, then you cannot do this with
> Acceleo... In fact I wouldn't know how this would be possible at all
> since we can't understand what the type of "self" is ... and thus
> can't determine which structural features it proposes.
> On the other hand, you can use EMF reflection to achieve this with
> [self.eGet(self.eClass().getEStructuralFeature('myCustomProp erty'))/]
> or Acceleo's shorthand : [self.eGet('myCustomProperty')/].
> Laurent Goubet
> Obeo
>> generation ? :) )
>> [self.name /]
>> [/for]
>> Regards
>> Tristan FAURE
Re: [Acceleo] Multi meta models and i don't know them [message #528351 is a reply to message #528318] |
Tue, 20 April 2010 04:33   |
--------------030608000603090504090401
Tristan,
As what you're doing is navigating a reference, and this is what causes
the switch from one metamodel to the next, I believe that should be
understood by Acceleo (that is, if "the child of my packages" is an
accurately typed reference in your metamodel and not a genericaly typed
reference to "EJavaObject" or the sort).
I have some fixes pending to have Acceleo be a little more permissive
than OCL in terms of context (inferring OCL context from other
elements). Maybe your use case could be allowed by tweaks from Acceleo too.
Do you have any way to provide us with a minimal example of your use
case (Acceleo module and an example model)? Preferably through an
enhancement request on the bugzilla :).
Laurent Goubet
Obeo
> Hi Laurent,
> Regards
> Tristan FAURE
>> Hi Tristan,
>> Laurent Goubet
>> Obeo
>>> generation ? :) )
>>> [self.name /]
>>> [/for]
>>> Regards
>>> Tristan FAURE
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------030608000603090504090401--
Re: [Acceleo] Multi meta models and i don't know them [message #528758 is a reply to message #528351] |
Wed, 21 April 2010 12:32   |
--------------060905040907020007050403
these are my sample files. In my environment they don't compile :/
Tristan FAURE
Le 20/04/2010 10:33, Laurent Goubet a écrit :
> Tristan,
> causes the switch from one metamodel to the next, I believe that
> should be understood by Acceleo (that is, if "the child of my
> packages" is an accurately typed reference in your metamodel and not a
> genericaly typed reference to "EJavaObject" or the sort).
> too.
> Laurent Goubet
> Obeo
>> Hi Laurent,
>> the model browsed is an instance of Sysml metamodel.
>> of the selected object (a Package for example).
>> or anything else from Sysml metamodel. And as i write this I
>> recognize it's not quite evident ^^
>> Regards
>> Tristan FAURE
>>> Hi Tristan,
>>> "main" metamodel. For example if you define a module on Genmodel
>>> (the metamodel), and you have a variable of type "GenPackage", you
>>> can use the following : [genPack.ecorePackage.nsURI/] without
>>> declaring the Ecore metamodel for your module (even though
>>> "ecorePackage" is of type "EPackage" and "nsURI" a property defined
>>> on EPackage in the ecore metamodel, not in the genmodel metamodel).
>>> cast to the accurate type beforehand, then you cannot do this with
>>> [self.eGet(self.eClass().getEStructuralFeature('myCustomProp erty'))/] or
>>> Laurent Goubet
>>> Obeo
>>>> generation ? :) )
>>>> the meta model of the selection (context) for example an UML
>>>> element. But the user of my software can access to elements of
>>>> another meta model.
>>>> fill the uri of the metamodel. But they can write a code like this :
>>>> [self.name /]
>>>> [/for]
>>>> Regards
>>>> Tristan FAURE
name="generate.mtl"
filename="generate.mtl"
W2NvbW1lbnQgZW5jb2RpbmcgPSBDcDEyNTIgL10NClttb2R1bGUgZ2VuZXJh dGUoJ2h0dHA6
Ly93d3cuZWNsaXBzZS5vcmcvdW1sMi8zLjAuMC9VTUwnKS9dDQoNClt0ZW1w bGF0ZSBwdWJs
aWMgZ2VuZXJhdGUocCA6IFBhY2thZ2UpXQ0KCQ0KCVtjb21tZW50IEBtYWlu IC9dDQoJW2Zp
bGUgKHAubmFtZSwgZmFsc2UsICdDcDEyNTInKV0NCgkJW2ZvciAoYjpCbG9j a3xzZWxmLm93
bmVkRWxlbWVudCldDQoJCQlbZS5uYW1lL10NCgkJWy9mb3JdDQoJWy9maWxl XQ0KCQ0KWy90
ZW1wbGF0ZV0NCg==
Content-Type: text/xml;
name="test.sysml"
filename="test.sysml"
<uml:Model xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:sysML="http://www.topcased.org/2.0/sysML" xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML" xmi:id="idModel" name="test">
<packagedElement xmi:type="uml:Package" xmi:id="idPackage" name="monPackage">
<packagedElement xmi:type="sysML:Block" xmi:id="_L_eKkE1iEd-rMMnUyELmzA" name="Block1"/>
<packagedElement xmi:type="sysML:Block" xmi:id="_MBQ6W01iEd-rMMnUyELmzA" name="Block2"/>
<packagedElement xmi:type="sysML:Block" xmi:id="_MFboq01iEd-rMMnUyELmzA" name="Block3"/>
<packagedElement xmi:type="sysML:Block" xmi:id="_MItmIE1iEd-rMMnUyELmzA" name="Block4"/>
<packagedElement xmi:type="sysML:Block" xmi:id="_MQBIC01iEd-rMMnUyELmzA" name="Block5"/>
<packagedElement xmi:type="sysML:Block" xmi:id="_MSZtoE1iEd-rMMnUyELmzA" name="Block6"/>
<packagedElement xmi:type="sysML:Block" xmi:id="_MVrrK01iEd-rMMnUyELmzA" name="Block7"/>
<packagedElement xmi:type="sysML:Block" xmi:id="_MYqGoE1iEd-rMMnUyELmzA" name="Block8"/>
</packagedElement>
<profileApplication xmi:type="uml:ProfileApplication" xmi:id="idProfileApplication">
<eAnnotations xmi:type="ecore:EAnnotation" xmi:id="idProfileAnnotation" source="http://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage" href=" ../../../plugin/org.topcased.modeler.sysml/templates/activit ydiagram/profile/SysMLActivityExtensionsProfile.uml#ProfileC ontentId "/>
</eAnnotations>
<appliedProfile xmi:type="uml:Profile" href=" ../../../plugin/org.topcased.modeler.sysml/templates/activit ydiagram/profile/SysMLActivityExtensionsProfile.uml#Activity ProfileId "/>
</profileApplication>
</uml:Model>
--------------060905040907020007050403--
Re: [Acceleo] Multi meta models and i don't know them [message #528881 is a reply to message #528758] |
Thu, 22 April 2010 05:29   |
--------------070603050904040801080101
Tristan,
In this particular case, the cast to Block isn't necessary ... but I
believe this isn't always true ^^.
Anyway ... I believe (at least it works with Acceleo 3.0M6 in Helios)
that you can use qualified names to work around your issue. For example
in this example :
[for (b : sysML::Block | self.ownedElement)]
[b.name/]
[/for]
Does that seem like an acceptable workaround?
Laurent Goubet
Obeo
> Hi
> Regards
> Tristan FAURE
>> Tristan,
>> too.
>> Laurent Goubet
>> Obeo
>>> Hi Laurent,
>>> Regards
>>> Tristan FAURE
>>>> Hi Tristan,
>>>> Laurent Goubet
>>>> Obeo
>>>>> generation ? :) )
>>>>> another meta model.
>>>>> [self.name /]
>>>>> [/for]
>>>>> Regards
>>>>> Tristan FAURE
--------------070603050904040801080101--
Re: [Acceleo] Multi meta models and i don't know them [message #528883 is a reply to message #528881] |
Thu, 22 April 2010 05:46  |
It works thank you very much !
Tristan
Le 22/04/2010 11:29, Laurent Goubet a écrit :
> Tristan,
> example in this example :
> [b.name/]
> [/for]
> Laurent Goubet
> Obeo
>> Hi
>> Regards
>> Tristan FAURE
>>> Tristan,
>>> a genericaly typed reference to "EJavaObject" or the sort).
>>> permissive than OCL in terms of context (inferring OCL context from
>>> other elements). Maybe your use case could be allowed by tweaks from
>>> Acceleo too.
>>> Laurent Goubet
>>> Obeo
>>>> Hi Laurent,
>>>> metamodel of the selected object (a Package for example).
>>>> Block or anything else from Sysml metamodel. And as i write this I
>>>> Regards
>>>> Tristan FAURE
>>>>> Hi Tristan,
>>>>> achieve. I'll use my usual scattershot to answer :p.
>>>>> defined on EPackage in the ecore metamodel, not in the genmodel
>>>>> metamodel).
>>>>> anything else, for example if [self.myCustomProperty/] needs
>>>>> "self" to be cast to the accurate type beforehand, then you cannot
>>>>> do this with Acceleo... In fact I wouldn't know how this would be
>>>>> possible at all since we can't understand what the type of "self"
>>>>> is ... and thus can't determine which structural features it
>>>>> proposes.
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> generation ? :) )
>>>>>> another meta model.
>>>>>> [self.name /]
>>>>>> [/for]
>>>>>> Regards
>>>>>> Tristan FAURE
Current Time: Thu Sep 25 10:10:17 EDT 2025
Powered by FUDForum. Page generated in 0.06966 seconds
