Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Tabs in texteditor do not indent
Tabs in texteditor do not indent [message #527615] Thu, 15 April 2010 14:16 Go to next message
Originally posted by: agranov.allmail.net
Hi!
Why would texteditor do not tabulate at all - zero space is added on
existing or added tab cahracters - if we turn on "show whitespace
characters" - the tab character overlays with text that was added after
the tab.
The text editor in question is DLTK extension of eclipse texteditor.
We had it once in 3.4 - we removed workspace and it did not happen again.
in 3.5 we have it all the time!
Any suspects :)
Thank you very much!
Gennady
Re: Tabs in texteditor do not indent [message #527644 is a reply to message #527615] Thu, 15 April 2010 17:55 Go to previous messageGo to next message
Gennady Agranov wrote:
> Hi!
> the tab.
> Any suspects :)
> Gennady
How many spaces are your tabs set to show? (Window->Preferences,
General/Editors/Text Editors, Displayed tab width)
Re: Tabs in texteditor do not indent [message #527671 is a reply to message #527615] Fri, 16 April 2010 01:04 Go to previous messageGo to next message
Hi Gennady,
Probably it's a bug in the indentation code.
Could you please provide more details about DLTK version and what
particular language provided by DLTK do you use?
Thank you,
Alex
On 16/04/10 01:16, Gennady Agranov wrote:
> Hi!
> the tab.
> Any suspects :)
> Gennady
Re: Tabs in texteditor do not indent [message #527825 is a reply to message #527644] Fri, 16 April 2010 10:57 Go to previous messageGo to next message
Thanks!
4
All other texteditors - e.g. java - are fine - just dltk one has this issue
>> Hi!
>> after the tab.
>> Any suspects :)
>> Gennady
Re: Tabs in texteditor do not indent [message #527826 is a reply to message #527644] Fri, 16 April 2010 10:57 Go to previous messageGo to next message
Thanks!
4
>> Hi!
>> after the tab.
>> Any suspects :)
>> Gennady
Re: Tabs in texteditor do not indent [message #527827 is a reply to message #527671] Fri, 16 April 2010 11:06 Go to previous messageGo to next message
1. we use DLTK that came with 352 bundle and we have our own language
2. we do extend DLTK ScriptEditor - just barely - to point to our
preference store and our texttools.
3. Thanks!
installed dltk plugins:
org.eclipse.dltk.console.ui_1.0.0.v20090610-1638.jar
org.eclipse.dltk.console_1.0.0.v20090610-1638.jar
org.eclipse.dltk.core_1.0.2.v20100209-1928.jar
org.eclipse.dltk.debug.ui_1.0.1.v20091111-1837.jar
org.eclipse.dltk.debug_1.0.0.v20090613-1432.jar
org.eclipse.dltk.formatter_1.0.1.v20090903-2153.jar
org.eclipse.dltk.launching_1.0.1.v20090910-1601.jar
org.eclipse.dltk.testing_1.0.0.v20090610-1638.jar
org.eclipse.dltk.ui_1.0.2.v20100209-1928.jar
org.eclipse.dltk.validators.core_1.0.0.v20090610-1638.jar
org.eclipse.dltk.validators.externalchecker_1.0.0.v20090610- 1638.jar
org.eclipse.dltk.validators.ui_1.0.0.v20090610-1638.jar
org.eclipse.dltk_1.0.1.v20090903-2153.jar
Alex Panchenko wrote:
> Hi Gennady,
> Thank you,
> Alex
>> Hi!
>> the tab.
>> Any suspects :)
>> Gennady
Re: Tabs in texteditor do not indent [message #529121 is a reply to message #527827] Fri, 23 April 2010 02:30 Go to previous messageGo to next message
Hi Gennady,
I am not sure what happens in your environment.
You should check that
- your preference store has values for preferences listed in
org.eclipse.dltk.ui.CodeFormatterConstants
- your IAutoEditStrategies/VerifyKeyListeners handle tab key correctly
Or just debug it.
Alex
> 3. Thanks!
>> Hi Gennady,
>> Thank you,
>> Alex
>>> Hi!
>>> the tab.
>>> again.
>>> Any suspects :)
>>> Gennady
Re: Tabs in texteditor do not indent [message #532855 is a reply to message #529121] Tue, 11 May 2010 07:32 Go to previous messageGo to next message
Same issue here. I have my own DLTK editor and no tabs are shown.
When a tab is hit the source gets modified, but the modification is not visible. Cursor position remains the same and no indentation is done.
When extending AbstractDLTKUILanguageToolkit I needed to implement a getPreferenceStore() method, which gives me the default IPreferencesStore from AbstracUIPlugin (Activator) - which should be fine.
ScriptEditor (DLTK) calls this from createCombinedPreferenceStore().
I do not think that my local PreferencesStore needs to have some properties regarding tabbing. Should be handled by the base classes, right?
Might be a bug...
Re: Tabs in texteditor do not indent [message #532858 is a reply to message #527615] Tue, 11 May 2010 07:45 Go to previous messageGo to next message
Ran into the same issue just now.
There is a property in the preferences store called
"formatter.tabulation.size", which is set to 0 by default. This means a tab is inserted, but it is 0 spaces in length. Not a very useful default value Sad
Still there is an easy way to fix this:
In your IDLTKUILanguageToolkit implementation there should be a method called
public IPreferenceStore getPreferenceStore()
Wherever you get your preferences from, make sure "formatter.tabulation.size" is set to a useful value like 4.
You can do this by adding
getPreferenceStore().setValue("formatter.tabulation.size", 4);
to your code. Even better provide a preferences page to set this!
regards
Re: Tabs in texteditor do not indent [message #532878 is a reply to message #532858] Tue, 11 May 2010 09:01 Go to previous messageGo to next message
Hi Christian,
The recommended way to initialized preferences is as follows:
public class myUIPreferenceInitializer extends AbstractPreferenceInitializer {
	public void initializeDefaultPreferences() {
		IPreferenceStore store = myUI.getDefault().getPreferenceStore();
		store.setDefault(CodeFormatterConstants.FORMATTER_TAB_CHAR, CodeFormatterConstants.SPACE);
		store.setDefault(CodeFormatterConstants.FORMATTER_TAB_SIZE, "2");
		store.setDefault(CodeFormatterConstants.FORMATTER_INDENTATION_SIZE, "2");
and
<extension point="org.eclipse.core.runtime.preferences">
<initializer class="....myUIPreferenceInitializer"/>
</extension>
Alex
Re: Tabs in texteditor do not indent [message #532882 is a reply to message #532878] Tue, 11 May 2010 09:12 Go to previous message
And the preference page:
import org.eclipse.dltk.ui.preferences.AbstractConfigurationBlockPreferencePage;
import org.eclipse.dltk.ui.preferences.EditorConfigurationBlock;
import org.eclipse.dltk.ui.preferences.IPreferenceConfigurationBlock;
import org.eclipse.dltk.ui.preferences.OverlayPreferenceStore;
public class myEditorPreferencesPage extends AbstractConfigurationBlockPreferencePage {
	protected void setPreferenceStore() {
		setPreferenceStore(myUI.getDefault().getPreferenceStore());
	protected IPreferenceConfigurationBlock createConfigurationBlock(OverlayPreferenceStore overlayPreferenceStore) {
		return new EditorConfigurationBlock(this, overlayPreferenceStore);
Previous Topic:[BUILD] S-2.0M7-201005050456
Next Topic:[BUILD] I-I201005130427-201005130427
Current Time: Sat Jul 26 19:08:26 EDT 2025
Powered by FUDForum. Page generated in 0.69755 seconds
