Home » Modeling » M2T (model-to-text transformation) » [Xpand] Invoking templates from menus?(How to invoke Xpand templates, without the user directly interacting with a workflow file?)
[Xpand] Invoking templates from menus? [message #527495] Thu, 15 April 2010 09:18 Go to next message
I'm looking to create a generation element for my dsl plug-in.
I seem to be getting on fine working with Xtext and Xpand, but want to know if there is a way I can have the user invoke a Xpand template, without having to deal directly with a workflow.
Ideally this would be a right-click menu option on the file to generate against.
I've had a search, but have only turned up this alternative: http://www.peterfriese.de/using-xpand-in-your-eclipse-wizard s/
Apologies I'm a complete novice to plug-in development, so try not to assume to much of me in your answers! Embarrassed
Many thanks
Re: [Xpand] Invoking templates from menus? [message #527507 is a reply to message #527495] Thu, 15 April 2010 09:42 Go to previous messageGo to next message
you can use JAVA. As long as your workflow is configured beforehand, you can invoke it from JAVA.
public boolean run(String workFlowFile,
ProgressMonitor theMonitor,
Map<String,String> theParams,
Map<String,?> externalSlotContents)
http://www.eclipse.org/forums/index.php?t=msg&th=165963& amp;start=0&
Re: [Xpand] Invoking templates from menus? [message #527698 is a reply to message #527507] Fri, 16 April 2010 03:15 Go to previous messageGo to next message
Xpand also provides some Java APIs (CTRL+SHIFT+T 'XpandFacade')
to call templates directly from Java code.
Sven
Maxime Lecourt schrieb:
> Quote:
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: [Xpand] Invoking templates from menus? [message #527900 is a reply to message #527698] Fri, 16 April 2010 16:30 Go to previous message
thanks guys, that should get me started.
Previous Topic:[Acceleo] Problems with AcceleoService.doGenerate
Next Topic:XPAND FILE directive - is it possible to write to an InputStream
Current Time: Wed Jul 30 18:48:50 EDT 2025
Powered by FUDForum. Page generated in 0.04879 seconds
