Home » Newcomers » Newcomers » Getting the cursor position in the current editor
Getting the cursor position in the current editor [message #518241] Wed, 03 March 2010 10:17 Go to next message
Hi ,
I am making some application in Java in which I have to get the cursor position or a mouseclick position in the current active editor... I created a very small code to start with
public class MouseTest {
System.out.println(PlatformUI.isWorkbenchRunning());
IEditorPart editor = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().getActiveEditor();
if (editor instanceof ITextEditor) {
ISelectionProvider selectionProvider = ((ITextEditor)editor).getSelectionProvider();
ISelection selection = selectionProvider.getSelection();
if (selection instanceof ITextSelection) {
ITextSelection textSelection = (ITextSelection)selection;
int offset = textSelection.getOffset(); // etc.
System.out.println( "hi --");
But when I run this application I get an error
Exception in thread "main" java.lang.IllegalStateException: Workbench has not been created yet.
Re: Getting the cursor position in the current editor [message #518543 is a reply to message #518241] Thu, 04 March 2010 07:38 Go to previous messageGo to next message
sameer wrote on Wed, 03 March 2010 10:17
Sameer, as the error implies, the workbench is not up. Generally speaking, you cannot refer to random Eclipse APIs in the context of a generic Java application. All you have is a main method. You need to be running from an OSGi. Instead of writing a regular Java application with a main method, you should be creating plug-ins that contribute functionality instead.
Re: Getting the cursor position in the current editor [message #518885 is a reply to message #518543] Fri, 05 March 2010 06:25 Go to previous messageGo to next message
hey thanx ... I was not getting it earlier .... I was making a java application ..
I made it as a plug in and then was able to run it successfully ...
Re: Getting the cursor position in the current editor [message #519453 is a reply to message #518885] Mon, 08 March 2010 16:01 Go to previous messageGo to next message
I need to do the same thing (get the current line and columnnumber).
With textSelection.getStartLine (plus 1) I get the current line.
How about the current column where the cursor is ? I mean textSelection.getOffset returns the offset, where a tab is one position, as on the screen a tab is more then one position.
Is there a way to prevent Tab-characters in the editor-text (when the user presses the Tab-button that it is converted to the right number of spaces) ?
Re: Getting the cursor position in the current editor [message #527458 is a reply to message #519453] Thu, 15 April 2010 06:55 Go to previous messageGo to next message
Hello Kitesurfer
I make a editor too and i dont know to gets of columnos number
have you make this??
Thanks a lot
Jose
[Updated on: Thu, 15 April 2010 06:55] by Moderator
Re: Getting the cursor position in the current editor [message #527817 is a reply to message #527458] Fri, 16 April 2010 11:03 Go to previous message
With this code you can the current linenumber and offset (offset is offset in the whole editortext) :
lcSelectionProvider = ((ITextEditor)lcEditor).getSelectionProvider();
selection = lcSelectionProvider.getSelection();
offSet = textSelection.getOffset(); // etc.
lineNr = textSelection.getStartLine();
You can get the number of spaces for each tab-char in file : \WORKSPACE Java\.settings\org.eclipse.ui.editors.prefs
Lines:
spacesForTabs=true
tabWidth=13 (when it's not there its value is 4)
So with this info you can do it all.
PS. It would have been handier if they added a getColumn method to ITextSelection.
Previous Topic:referenced projects and user libraries
Next Topic:[ant] [eclipse 3.4] Build does not include external dependencies
Current Time: Sun Nov 02 22:07:46 EST 2025
Powered by FUDForum. Page generated in 0.09651 seconds
