Home » Eclipse Projects » EclipseLink » Communication failure
Communication failure [message #527138] Wed, 14 April 2010 04:38 Go to next message
I'm facing strange Eclipselink behavior with my web application that is running on Tomcat 6.0.26
There is a method which gets data from MS SQL Server 2000. This method throws an exception after several succesfull calling (5-7).
Can anybody help?
public List<Expedice> getExpediceList() {
EntityManagerFactory emf = Persistence.createEntityManagerFactory("metroPU");
EntityManager em = emf.createEntityManager();
Query q = em.createQuery("select e from Expedice e order by e.datum desc");
q.setHint(QueryHints.REFRESH, "true");
expediceList = q.getResultList();
em.close();
emf.close();
return expediceList;
[EL Info]: 2010-04-14 09:24:43.764--ServerSession(8532343)--EclipseLink, version: Eclipse Persistence Services - 1.1.1.v20090430-r4097
[EL Config]: 2010-04-14 09:24:43.764--ServerSession(8532343)--Connection(28617320)-- connecting(DatabaseLogin(
platform=>SQLServerPlatform
user name=> ""
connector=>JNDIConnector datasource name=>java:comp/env/jdbc/DBMetro
[EL Config]: 2010-04-14 09:24:43.78--ServerSession(8532343)--Connection(32912386)--C onnected: jdbc:microsoft:sqlserver://pha-ei:1433 ;NETADDRESS=000000000000;HOSTPROCESS=0;SENDSTRINGPARAMETERSA SUNICODE=true;LOGINTIMEOUT=0;DATABASENAME=METRO;PROGRAMNAME= ;SELECTMETHOD=direct;WSID=
User: metro
Database: Microsoft SQL Server Version: Microsoft SQL Server 2000 - 8.00.2055 (Intel X86)
Dec 16 2008 19:46:53
Copyright (c) 1988-2003 Microsoft Corporation
Standard Edition on Windows NT 5.2 (Build 3790: Service Pack 2)
Driver: SQLServer Version: 2.2.0040
[EL Config]: 2010-04-14 09:24:43.78--ServerSession(8532343)--Connection(13664178)--c onnecting(DatabaseLogin(
user name=> ""
[EL Config]: 2010-04-14 09:24:43.78--ServerSession(8532343)--Connection(15164692)--C onnected: jdbc:microsoft:sqlserver://pha-ei:1433 ;NETADDRESS=000000000000;HOSTPROCESS=0;SENDSTRINGPARAMETERSA SUNICODE=true;LOGINTIMEOUT=0;DATABASENAME=METRO;PROGRAMNAME= ;SELECTMETHOD=direct;WSID=
User: metro
[EL Info]: 2010-04-14 09:24:43.78--ServerSession(8532343)--file:/C:/Program%20File s/Apache%20Software%20Foundation/Tomcat%206.0/webapps/metro/ WEB-INF/classes/-metroPU login successful
[EL Info]: 2010-04-14 09:24:44.639--ServerSession(8532343)--Communication failure detected when attempting to perform read query outside of a transaction. Attempting to retry query.
[EL Warning]: 2010-04-14 09:24:44.639--UnitOfWork(10197552)--java.lang.NullPointerExc eption
Re: Communication failure [message #527328 is a reply to message #527138] Wed, 14 April 2010 16:29 Go to previous messageGo to next message
I would recommend creating a singleton EntityManagerFactory instead of creating and closing on on each request. You may be running into a resource issue after several of these expensive operations.
Doug
Re: Communication failure [message #527428 is a reply to message #527328] Thu, 15 April 2010 04:59 Go to previous messageGo to next message
Thanks for reply. I tried that but it didn't help. I forgot to metion that Tomcat and MS SQL Server are on the same machine. I tried to run Tomcat on other machine and everything worked fine.
Re: Communication failure [message #527509 is a reply to message #527138] Thu, 15 April 2010 09:47 Go to previous messageGo to next message
Please include the stack trace to the exception.
Re: Communication failure [message #527517 is a reply to message #527509] Thu, 15 April 2010 09:56 Go to previous messageGo to next message
javax.faces.el.EvaluationException: java.lang.NullPointerException
	at javax.faces.component.MethodBindingMethodExpressionAdapter.invoke(MethodBindingMethodExpressionAdapter.java:102)
	at com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:102)
	at javax.faces.component.UICommand.broadcast(UICommand.java:387)
	at org.ajax4jsf.component.UIDataAdaptor.broadcast(UIDataAdaptor.java:1383)
	at org.ajax4jsf.component.AjaxViewRoot.processEvents(AjaxViewRoot.java:321)
	at org.ajax4jsf.component.AjaxViewRoot.broadcastEvents(AjaxViewRoot.java:296)
	at org.ajax4jsf.component.AjaxViewRoot.processPhase(AjaxViewRoot.java:253)
	at org.ajax4jsf.component.AjaxViewRoot.processApplication(AjaxViewRoot.java:466)
	at com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:82)
	at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:100)
	at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:118)
	at javax.faces.webapp.FacesServlet.service(FacesServlet.java:265)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
	at org.ajax4jsf.webapp.BaseXMLFilter.doXmlFilter(BaseXMLFilter.java:178)
	at org.ajax4jsf.webapp.BaseFilter.handleRequest(BaseFilter.java:290)
	at org.ajax4jsf.webapp.BaseFilter.processUploadsAndHandleRequest(BaseFilter.java:390)
	at org.ajax4jsf.webapp.BaseFilter.doFilter(BaseFilter.java:517)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
	at org.apache.myfaces.webapp.filter.ExtensionsFilter.doFilter(ExtensionsFilter.java:341)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
	at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:859)
	at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:579)
	at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1555)
	at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1222)
	at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1165)
	at org.eclipse.persistence.internal.indirection.NoIndirectionPolicy.valueFromQuery(NoIndirectionPolicy.java:299)
	at org.eclipse.persistence.mappings.ForeignReferenceMapping.valueFromRowInternal(ForeignReferenceMapping.java:1473)
	at org.eclipse.persistence.mappings.OneToOneMapping.valueFromRowInternal(OneToOneMapping.java:1039)
	at org.eclipse.persistence.mappings.ForeignReferenceMapping.valueFromRow(ForeignReferenceMapping.java:1402)
	at org.eclipse.persistence.mappings.DatabaseMapping.readFromRowIntoObject(DatabaseMapping.java:1136)
	at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildAttributesIntoObject(ObjectBuilder.java:325)
	at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:652)
	at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildWorkingCopyCloneNormally(ObjectBuilder.java:574)
	at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObjectInUnitOfWork(ObjectBuilder.java:544)
	at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:485)
	at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:437)
	at org.eclipse.persistence.queries.ObjectLevelReadQuery.buildObject(ObjectLevelReadQuery.java:569)
	at org.eclipse.persistence.queries.ReadAllQuery.registerResultInUnitOfWork(ReadAllQuery.java:904)
	at org.eclipse.persistence.queries.ReadAllQuery.executeObjectLevelReadQuery(ReadAllQuery.java:490)
	at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:928)
	at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:664)
	at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:889)
	at org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAllQuery.java:458)
	at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:952)
	at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2755)
	at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1181)
	at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1139)
	at org.eclipse.persistence.internal.jpa.EJBQueryImpl.executeReadQuery(EJBQueryImpl.java:389)
	at org.eclipse.persistence.internal.jpa.EJBQueryImpl.getResultList(EJBQueryImpl.java:568)
	at cz.mediaservis.metro.ExpediceBean.pripravVykaz(ExpediceBean.java:200)
	at cz.mediaservis.metro.ExpediceBean.editaceExpedice(ExpediceBean.java:186)
	at org.apache.el.parser.AstValue.invoke(AstValue.java:191)
	at org.apache.el.MethodExpressionImpl.invoke(MethodExpressionImpl.java:276)
	at com.sun.facelets.el.TagMethodExpression.invoke(TagMethodExpression.java:68)
	at javax.faces.component.MethodBindingMethodExpressionAdapter.invoke(MethodBindingMethodExpressionAdapter.java:88)
	... 32 more
15.4.2010 15:55:51 com.sun.faces.lifecycle.InvokeApplicationPhase execute
WARNING: #{ExpediceBean.editaceExpedice}: java.lang.NullPointerException
javax.faces.FacesException: #{ExpediceBean.editaceExpedice}: java.lang.NullPointerException
	at com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:118)
Caused by: javax.faces.el.EvaluationException: java.lang.NullPointerException
	... 31 more
	... 32 more
15.4.2010 15:55:51 com.sun.faces.lifecycle.Phase doPhase
SEVERE: JSF1054: (Phase ID: INVOKE_APPLICATION 5, View ID: /seznamExpedice.xhtml) Exception thrown during phase execution: javax.faces.event.PhaseEvent[source=com.sun.faces.lifecycle.LifecycleImpl@61e987]
15.4.2010 15:55:51 org.ajax4jsf.webapp.BaseXMLFilter doXmlFilter
SEVERE: Exception in the filter chain
javax.servlet.ServletException: #{ExpediceBean.editaceExpedice}: java.lang.NullPointerException
	at javax.faces.webapp.FacesServlet.service(FacesServlet.java:277)
Caused by: javax.faces.FacesException: #{ExpediceBean.editaceExpedice}: java.lang.NullPointerException
	... 21 more
	... 31 more
	... 32 more
Re: Communication failure [message #528140 is a reply to message #527138] Mon, 19 April 2010 09:59 Go to previous messageGo to next message
The error seems to be occurring in this line of code,
>> databaseException.getAccessor().reestablishConnection(this);
So the accessor on the exception is null. I'm not sure why this is, but this is a bug that we are not checking for null. We should also be logging the real database exception (and allow handling) before attempting to reconnect.
Please log a bug for this.
The root of the error though is a database exception, which you probably need to fix. You could put a break-point in DatabaseException or SQLException to find out what the real error is.
Re: Communication failure [message #531524 is a reply to message #528140] Wed, 05 May 2010 06:30 Go to previous message
I temporarily solved this issue by changing JDBC resource parameter maxIdle in web.xml.
Error occurs when maxIdle="0". So I set this to 1 and it seems to be OK.
Previous Topic:Problem installing EclipseLink 2.0.2 in Eclipse 3.5/Galileo
Next Topic:jdbc connection validation query
Current Time: Sun Jul 27 08:10:18 EDT 2025
Powered by FUDForum. Page generated in 0.05403 seconds
