Home » Eclipse Projects » Rich Client Platform (RCP) » update RCP application problem
update RCP application problem [message #526207] Fri, 09 April 2010 05:00 Go to next message
Hi again
I have a problem with using the update system. I can provide new updates to my app by updating my feature and it's plugins. My application finds the update on the update site and installs the update. But after the restart my app still uses the old version... if i go check the features and plugin folder i see all my features(actually just one feature that is update 3 times, so i see 3 feature folders) and in my plugins folder i see my updated plugin, but also the old plugin that is still used, but shouldn't be used anymore...
can anyone help me with solving my problem?
Re: update RCP application problem [message #526912 is a reply to message #526207] Tue, 13 April 2010 09:34 Go to previous messageGo to next message
anyone?
Re: update RCP application problem [message #526936 is a reply to message #526207] Tue, 13 April 2010 10:18 Go to previous messageGo to next message
After the restart, is there anything in your error log? Are you using
Help>Check For Updates to update your RCP app? Are you using p2, or the
legacy update manager?
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: update RCP application problem [message #527421 is a reply to message #526207] Thu, 15 April 2010 04:38 Go to previous message
I am using the legacy update manager.
the only relevant message related to update in my log is:
!ENTRY org.eclipse.update.configurator 4 0 2010-04-09 10:05:45.857
!MESSAGE Could not install bundle plugins/com.entol.bl.common_1.0.0.jar Bundle "com.entol.bl.common" version "1.0.0" has already been installed from: reference:file:plugins/com.entol.bl.common_1.0.0.jar
Previous Topic:Widgets inside a view
Next Topic:How to share plugins between several applications?
Current Time: Mon Jul 21 10:35:04 EDT 2025
Powered by FUDForum. Page generated in 0.08782 seconds
