Home » Eclipse Projects » Rich Client Platform (RCP) » Icon Sharing between plugins(I want a central plugin to hold my standard icons)
Icon Sharing between plugins [message #527355] Wed, 14 April 2010 20:08 Go to next message
Hello there, my team is building an RCP application. We have a standard common plugin that has our common libraries and classes that all of our other plugins use. I would like to keep commonly used icons, for example the delete icon, in this common plugin.
This is not very difficult to do with a programmatic approach. However, I am having trouble using these icons through the plugin.xml when I export the jar files. Right now I manually put in the full path of the icon, and that works great when I run the program straight out of eclipse. I see the problem when I export the application and run it from the jar files. There are several icons that do not show up anymore, that did show up when running from eclipse.
So I am assuming that I am doing something wrong. Can this be done in this manner? Is there a better solution that I am not thinking about? I would really like to have the standard icons in one place, that makes it so much easier if you need to change one. Well thank you for taking a look at this,
Dwain
Re: Icon Sharing between plugins [message #527371 is a reply to message #527355] Thu, 15 April 2010 01:44 Go to previous message
> this manner?
There exists already a standard way to refer to the resources of other
plugins. Just use the notation:
platform:/plugin/${plugin_id}/${relative_path_within_plugin}
One example is:
platform:/plugin/org.eclipse.ui/icons/full/obj16/delete_obj. gif
HTH & Greetings from Bremen,
Daniel Krügler
Previous Topic:How to show a job's progress within a wizard
Next Topic:Widgets inside a view
Current Time: Sat Jul 19 04:56:39 EDT 2025
Powered by FUDForum. Page generated in 0.03311 seconds
