Adding a command to view's tool bar throws java.lang.IllegalArgumentException: Index out of bounds [message #527032] |
Tue, 13 April 2010 15:02  |
I have problem adding a command to view's tool bar. Same command works
fine when I add it to the main tool bar and menu. Stack trace and
relevant part of the plugin.xml are below
==================plugin.xml================================
<extension
point="org.eclipse.ui.views">
<view
name="Example List"
icon="icons/sample3.gif"
class="com.viithiisys.example.views.ExampleListView"
id="com.viithiisys.example.views.exampleListView">
</view>
</extension>
<extension
point="org.eclipse.ui.commands">
<category
name="Example"
id="com.viithiisys.example.category">
</category>
<command
name="Edit Example"
description="Opens Example editor"
categoryId="com.viithiisys.example.category"
id="com.viithiisys.example.commands.openExampleEditor"
defaultHandler="com.viithiisys.example.actions.OpenEditorHandler ">
</command>
</extension>
<extension
point="org.eclipse.ui.menus">
<menuContribution
locationURI="toolbar:com.viithiisys.example.views.exampleListView ">
<toolbar
id="menu-contribution.toolbars.sampleToolbar">
<command
commandId="com.viithiisys.example.commands.openExampleEditor "
icon="icons/sample.gif"
tooltip="Say hello world"
id="menu-contribution.toolbars.sampleCommand">
</command>
</toolbar>
</menuContribution>
</extension>
=======================stack trace==========================
!STACK 0
at org.eclipse.swt.SWT.error(SWT.java:3084)
at org.eclipse.swt.SWT.error(SWT.java:3018)
at org.eclipse.swt.SWT.error(SWT.java:2989)
at org.eclipse.swt.internal.widgets.ItemHolder.getItem(ItemHold er.java:102)
at org.eclipse.swt.widgets.ToolBar.getItem(ToolBar.java:132)
at
org.eclipse.rap.internal.design.example.managers.ViewToolBar Manager.update(ViewToolBarManager.java:161)
at org.eclipse.ui.internal.ViewPane.updateActionBars(ViewPane.j ava:462)
at
org.eclipse.ui.internal.ViewActionBars.updateActionBars(View ActionBars.java:59)
at
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:419)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:230)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:31 2)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:54 4)
at
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:185)
at
org.eclipse.rap.internal.design.example.stacks.ViewStackPres entation.selectPart(ViewStackPresentation.java:957)
at
org.eclipse.rap.ui.interactiondesign.internal.ConfigurableSt ackProxy.selectPart(ConfigurableStackProxy.java:425)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1267)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1220)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 19)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:659)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:585)
at
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:569)
at
org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:267)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:930)
at
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2494)
at
org.eclipse.ui.internal.WorkbenchWindow$22.run(WorkbenchWind ow.java:2926)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:66)
at
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:2907)
at
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:720)
at
org.eclipse.ui.internal.Workbench$18.runWithException(Workbe nch.java:976)
at
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:32)
at
org.eclipse.rwt.internal.lifecycle.UICallBackManager.addSync (UICallBackManager.java:115)
at org.eclipse.swt.widgets.Display$2.run(Display.java:931)
at
org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler. runNonUIThreadWithFakeContext(UICallBackServiceHandler.java: 460)
at
org.eclipse.rwt.lifecycle.UICallBack.runNonUIThreadWithFakeC ontext(UICallBack.java:44)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:929)
at
org.eclipse.ui.internal.StartupThreading.runWithWorkbenchExc eptions(StartupThreading.java:55)
at
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:972)
at
org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1799)
at
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1735)
at
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:188)
at
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:790)
at
org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1341)
at
at
at
at
at
org.eclipse.ui.internal.StartupThreading.runWithoutException s(StartupThreading.java:110)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1336)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2317)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:22 06)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:424)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.jface.internal.databinding.realmadapter.RealmAda pter.run(RealmAdapter.java:44)
at
org.eclipse.rap.ui.internal.RealmAdapterHook.runWithDefault( RealmAdapterHook.java:48)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:427)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:157)
at com.viithiisys.example.Application.start(Application.java:20 )
at
org.eclipse.rap.ui.internal.application.EntrypointApplicatio nWrapper.createUI(EntrypointApplicationWrapper.java:27)
at
org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:253)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:117)
at java.lang.Thread.run(Thread.java:619)
at org.eclipse.rwt.internal.lifecycle.UIThread.run(UIThread.jav a:80)
FUDForum. Page generated in 0.13142 seconds
