Home » Eclipse Projects » Eclipse Platform » Missing META-INF folder in build result (eclipse SDK)(META-INF folder is missing in the zip file after eclipse SDK build execution)
Missing META-INF folder in build result (eclipse SDK) [message #527130] |
Wed, 14 April 2010 04:13  |
Dear forum members,
Please let me know if I'm posting a duplicated topic, or posting a topic to a wrong forum. So far I haven't found any similar topic.
I'm building eclipse SDK by using build scripts in org.eclipse.releng.eclipsebuilder project. Source files are checked out from CVS repository and invoking build with buildFromSource.xml file. So far I used map files from eclipse 3.6 M3 and M6 version.
Now I'm getting the resulting zip file. I can run eclipse with extracted binary, but META-INF folders in feature folders are missing. If I check the folder structure of production version (eclipse-SDK-3.6M3-win32.zip or so), there are META-INF folder under each feature directory.
Here my question is, why I'm not getting META-INF folder in my build result?
==== Environment Info ====
Platform: Windows 7 professional / Windows XP Professional
Build methodology: org.eclipse.releng.eclipsebuilder
Source files: Fetched from eclipse CVS as per M3 / M6 map files
Thanks in advance and best regards,
Mitsuki Touno
Re: Missing META-INF folder in build result (eclipse SDK) [message #527344 is a reply to message #527169] |
Wed, 14 April 2010 17:39   |
Dear Ed-san,
Thanks for your reply. Actually we have not modified any build.properties of features, so they are as they are in CVS repository.
For example, below is the entries of build.properties for org.eclipse.sdk feature.
BTW, there is META-INF folder in each feature folder of production version of eclipse SDK which I downloaded from eclipse download page. I need to generate completely same folder structure and same binaries.
Please let me know what is required to generate META-INF folder, if any specific configuration is necessary.
Thanks regards,
Mitsuki
==== FROM HERE ====
# Copyright (c) 2000, 2009 IBM Corporation and others.
# All rights reserved. This program and the accompanying materials
# are made available under the terms of the Eclipse Public License v1.0
# which accompanies this distribution, and is available at
# http://www.eclipse.org/legal/epl-v10.html
# Contributors:
# IBM Corporation - initial API and implementation
bin.includes=epl-v10.html,eclipse_update_120.jpg,feature.xml ,feature.properties,license.html
generate.feature@org.eclipse.platform.source=org.eclipse.platform,feature@org.eclipse.rcp.source,feature@org.eclipse.equinox.p2.user.ui.source;optional="true",plugin@org.eclipse.platform.doc.isv;unpack="false",\
plugin@org.apache.ant.source;version=1.7.1.qualifier;unpack="false",\
plugin@com.jcraft.jsch.source;version=0.1.41.qualifier;unpack="false",\
exclude@org.eclipse.platform.doc.user
generate.feature@org.eclipse.jdt.source=org.eclipse.jdt, plugin@org.eclipse.jdt.doc.isv;unpack="false",\
plugin@org.junit.source;version=3.8.2.qualifier;unpack="false",\
plugin@org.junit.source;version=4.8.1.qualifier;unpack="false",\
plugin@org.hamcrest.core.source;version=1.1.0.qualifier;unpack="false",\
exclude@org.eclipse.jdt.doc.user
generate.feature@org.eclipse.pde.source=org.eclipse.pde,plugin@org.objectweb.asm.source;version=3.2.0.qualifier;unpack="false",\exclude@org.eclipse.pde.doc.user
generate.feature@org.eclipse.pde.p2.source=org.eclipse.pde.p2
generate.feature@org.eclipse.cvs.source=org.eclipse.cvs
generate.feature@org.eclipse.help.source=org.eclipse.help,\
plugin@javax.servlet.source;version=2.5.0.qualifier;unpack="false",\
plugin@javax.servlet.jsp.source;version=2.0.0.qualifier;unpack="false",\
plugin@org.apache.jasper.source;version=5.5.17.qualifier;unpack="false",\
plugin@org.apache.commons.el.source;version=1.0.0.qualifier;unpack="false",\
plugin@org.apache.commons.logging.source;version=1.0.4.qualifier;unpack="false",\
plugin@org.apache.lucene.source;version=1.9.1.qualifier;unpack="false",\
plugin@org.apache.lucene.analysis.source;version=1.9.1.qualifier;unpack="false",\
plugin@org.mortbay.jetty.util.source;version=6.1.15.qualifier;unpack="false",\
plugin@org.mortbay.jetty.server.source;version=6.1.15.qualifier;unpack="false"
generatedVersionLength=45
==== TO HERE ====
Re: Missing META-INF folder in build result (eclipse SDK) [message #527740 is a reply to message #527685] |
Fri, 16 April 2010 06:14   |
--------------050705050509050003050701
Mitsuki,
It's not mentioned in the build.properties and if it's not in CVS, it
must be generated. From the comments one gets the impression that Ant
is being used to create it
Manifest-Version: 1.0
Ant-Version: Apache Ant 1.7.1
Created-By: 2.3 (IBM Corporation)
It's not a bundle manifest like the ones that appears in bundles/plugins.
So I guess the underlying question is: what build script generates these
things? I'm not sure the release engineers for the platform read this
newsgroup/forum...
Mitsuki Touno wrote:
> If anyone has idea about this, please let us know.
> Thanks regards,
> Mitsuki
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
<title></title>
</head>
Mitsuki,<br>
<br>
is being used to create it<br>
<blockquote>Manifest-Version: 1.0<br>
Ant-Version: Apache Ant 1.7.1<br>
Created-By: 2.3 (IBM Corporation)<br>
</blockquote>
bundles/plugins.<br>
<br>
these things? I'm not sure the release engineers for the platform read
this newsgroup/forum...<br>
<br>
<br>
<blockquote cite="mid:hq91ae$vjp$1@build.eclipse.org" type="cite">Hi, <br>
If anyone has idea about this, please let us know. <br>
Thanks regards, <br>
Mitsuki <br>
<br>
</blockquote>
</body>
</html>
--------------050705050509050003050701--
Current Time: Sat Jul 26 11:02:17 EDT 2025
Powered by FUDForum. Page generated in 0.09028 seconds
