Home » Archived » BIRT » create a report in code
create a report in code [message #518045] Tue, 02 March 2010 15:44 Go to next message
I like to know if it is possible (any sample helpful) to create a report in java code, ie without a pre-existing report file.
Re: create a report in code [message #518087 is a reply to message #518045] Tue, 02 March 2010 19:31 Go to previous messageGo to next message
As far as I know, the Design API is what you want.
Unfortunately I've find the available info to be obscure and not very helpful.
If its helpful to you, check this out where you may find some examples and a bit of resources.
Hope that helps.
Re: create a report in code [message #518211 is a reply to message #518045] Wed, 03 March 2010 08:53 Go to previous messageGo to next message
Robert Jenkin wrote on Tue, 02 March 2010 15:44
Yes it would be very good to see an example of a table with a chart for instance. There is simply no good documentation of the Chart API.
Just a "Hello World"-chart that works would be great!
Here is an example that is pretty good:
http://wiki.eclipse.org/Java_-_Build_Dynamic_Table_%28BIRT%2 9
And I'm trying right now to connect it to a chart but with no success. If there are any help, please advice!
Re: create a report in code [message #518314 is a reply to message #518211] Wed, 03 March 2010 12:52 Go to previous messageGo to next message
I did a webinar on the DE-API
http://www.birt-exchange.com/be/news-events/resources/?artic leid=17456
Take a look at these examples from the webinar:
http://www.birt-exchange.org/devshare/designing-birt-reports /409-deapi-examples-from-birt-exchange-webinar/#description
I also did one on the chart api:
http://www.birt-exchange.com/be/info/chartingapi-websem/
You may want to look over the list:
http://www.birt-exchange.com/be/news-events/webinars/archive d-webinars/
There are also plenty of examples in the dev share at birt-exchange
Attached is a simple example that creates a chart:
Jason
import java.io.IOException;
import java.util.Iterator;
import org.eclipse.birt.chart.model.Chart;
import org.eclipse.birt.chart.model.ChartWithAxes;
import org.eclipse.birt.chart.model.attribute.AxisType;
import org.eclipse.birt.chart.model.attribute.DataType;
import org.eclipse.birt.chart.model.attribute.GroupingUnitType;
import org.eclipse.birt.chart.model.attribute.IntersectionType;
import org.eclipse.birt.chart.model.attribute.SortOption;
import org.eclipse.birt.chart.model.attribute.TickStyle;
import org.eclipse.birt.chart.model.attribute.impl.ColorDefinitionI mpl;
import org.eclipse.birt.chart.model.component.Axis;
import org.eclipse.birt.chart.model.component.Series;
import org.eclipse.birt.chart.model.component.impl.SeriesImpl;
import org.eclipse.birt.chart.model.data.Query;
import org.eclipse.birt.chart.model.data.SeriesDefinition;
import org.eclipse.birt.chart.model.data.SeriesGrouping;
import org.eclipse.birt.chart.model.data.impl.QueryImpl;
import org.eclipse.birt.chart.model.data.impl.SeriesDefinitionImpl;
import org.eclipse.birt.chart.model.impl.ChartWithAxesImpl;
import org.eclipse.birt.chart.model.layout.Plot;
import org.eclipse.birt.chart.model.type.LineSeries;
import org.eclipse.birt.chart.model.type.impl.LineSeriesImpl;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.core.script.ScriptExpression;
import org.eclipse.birt.data.engine.api.querydefn.ComputedColumn;
import org.eclipse.birt.report.model.api.ComputedColumnHandle;
import org.eclipse.birt.report.model.api.DataSetHandle;
import org.eclipse.birt.report.model.api.DesignConfig;
import org.eclipse.birt.report.model.api.DesignFileException;
import org.eclipse.birt.report.model.api.ElementFactory;
import org.eclipse.birt.report.model.api.ExtendedItemHandle;
import org.eclipse.birt.report.model.api.IDesignEngine;
import org.eclipse.birt.report.model.api.IDesignEngineFactory;
import org.eclipse.birt.report.model.api.OdaDataSetHandle;
import org.eclipse.birt.report.model.api.OdaDataSourceHandle;
import org.eclipse.birt.report.model.api.PropertyHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.ScriptDataSetHandle;
import org.eclipse.birt.report.model.api.SessionHandle;
import org.eclipse.birt.report.model.api.SimpleMasterPageHandle;
import org.eclipse.birt.report.model.api.StructureFactory;
import org.eclipse.birt.report.model.api.activity.SemanticException ;
import org.eclipse.birt.report.model.api.command.ContentException;
import org.eclipse.birt.report.model.api.command.NameException;
import
org.eclipse.birt.report.model.api.elements.structures.Proper tyBinding;
import com.ibm.icu.util.ULocale;
public class SimpleChart
private ReportDesignHandle reportDesignHandle = null;
private ElementFactory elementFactory = null;
private OdaDataSourceHandle odaDataSourceHandle = null;
private String dataSourceName = "datasource";
private String dataSetName = "maindataset";
private SessionHandle sessionHandle =null;
private String query = "SELECT SIMS.ROLES.\"CREATOR\",
SIMS.ROLES.\"RID\" FROM SIMS.ROLES";
org.eclipse.birt.report.model.api.elements.structures.Comput edColumn
cs1, cs2 = null;
public static void main(String args[])
try {
new SimpleChart().createReport();
} catch (Exception e) {
e.printStackTrace();
public void createReport() throws SemanticException, IOException
System.out.println("Start");
init();
createMasterPages();
//createDataSources();
//createDataSets();
buildDataSource();
buildDataSet();
createBody();
String outputPath = "C:/work";
reportDesignHandle.saveAs("output/desample/simplechart.rptdesign ");
try
reportDesignHandle = sessionHandle.openDesign(
"output/desample/simplechart.rptdesign" );//$NON-NLS-1$
catch ( DesignFileException e )
e.printStackTrace( );
ExtendedItemHandle eih = (ExtendedItemHandle)
reportDesignHandle.getBody( )
.getContents( ).get( 0 );
for ( Iterator iter = eih.getColumnBindings( )
.iterator( ); iter.hasNext( ); )
ComputedColumnHandle cch = (ComputedColumnHandle) iter.next( );
//if( cch.getExpression().contains("_Sum") ){
//cch.drop();
//}else{
System.out.println("opened report "+cch.getExpression());
//reportDesignHandle.save();
System.out.println("End");
private void init(){
DesignConfig config = new DesignConfig( );
config.setBIRTHome("C:/birt/birt-runtime-2_5_0/birt-runtime-2_5_0/ReportEngine ");
IDesignEngine engine = null;
try {
Platform.startup(config);
IDesignEngineFactory factory = (IDesignEngineFactory) Platform
..createFactoryObject(IDesignEngineFactory.EXTENSION_DESIGN_ ENGINE_FACTORY);
engine = factory.createDesignEngine(config);
} catch (Exception ex) {
ex.printStackTrace();
// we need a handle of session of design engine
sessionHandle = engine.newSessionHandle(ULocale.ENGLISH);
reportDesignHandle = sessionHandle.createDesign();
elementFactory = reportDesignHandle.getElementFactory();
private void createMasterPages() throws ContentException, NameException
SimpleMasterPageHandle simpleMasterPage =
elementFactory.newSimpleMasterPage("Master Page");
reportDesignHandle.getMasterPages().add(simpleMasterPage);
void buildDataSource( ) throws SemanticException
OdaDataSourceHandle dsHandle = elementFactory.newOdaDataSource(
"Data Source", "org.eclipse.birt.report.data.oda.jdbc" );
dsHandle.setProperty( "odaDriverClass",
"org.eclipse.birt.report.data.oda.sampledb.Driver" );
dsHandle.setProperty( "odaURL", "jdbc:classicmodels:sampledb" );
dsHandle.setProperty( "odaUser", "ClassicModels" );
dsHandle.setProperty( "odaPassword", "" );
PropertyBinding pb = new PropertyBinding();
reportDesignHandle.getDataSources( ).add( dsHandle );
void buildDataSet( ) throws SemanticException
OdaDataSetHandle dsHandle = elementFactory.newOdaDataSet( dataSetName,
"org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" );
dsHandle.setDataSource( "Data Source" );
String qry = "Select PRODUCTCODE, QUANTITYORDERED from orderdetails
where ordernumber = 10104";
dsHandle.setQueryText( qry );
reportDesignHandle.getDataSets( ).add( dsHandle );
private void createDataSets() throws SemanticException
String dataSetType =
"org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet";
OdaDataSetHandle dataSetHandle = null;
dataSetHandle = elementFactory.newOdaDataSet(dataSetName,
dataSetType);
dataSetHandle.setDataSource(dataSourceName);
dataSetHandle.setQueryText(query);
reportDesignHandle.getDataSets().add(dataSetHandle);
private void createDataSources() throws SemanticException
// type of the data source
String extensionID = "org.eclipse.birt.report.data.oda.jdbc";
String driverClassName = "oracle.jdbc.driver.OracleDriver";
String driverURL = "jdbc:oracle:thin:@192.168.174.25:1521:BDEV";
String userName = "mferdous";
String userPassword = "anabase";
// now make a data source with the dataSourceName and extensionID.
elementFactory.newOdaDataSource(dataSourceName,
extensionID);
odaDataSourceHandle.setProperty("odaDriverClass", driverClassName);
odaDataSourceHandle.setProperty("odaURL", driverURL);
odaDataSourceHandle.setProperty("odaUser", userName);
odaDataSourceHandle.setProperty("odaPassword", userPassword);
reportDesignHandle.getDataSources().add(odaDataSourceHandle) ;
private void createBody() throws SemanticException
ExtendedItemHandle extendedItemHandle =
elementFactory.newExtendedItem("Simple Chart", "Chart");
extendedItemHandle.setWidth("700px");
extendedItemHandle.setHeight("500px");
extendedItemHandle.setProperty(ExtendedItemHandle.DATA_SET_P ROP,
dataSetName);
extendedItemHandle.setProperty("outputFormat","GIF");
Chart c = createChart();
extendedItemHandle.getReportItem().setProperty(
"chart.instance", c );
reportDesignHandle.getBody().add(extendedItemHandle);
//PropertyHandle computedSet = extendedItemHandle.getColumnBindings( );
//computedSet.clearValue();
cs1 = StructureFactory.createComputedColumn( );
cs1.setName( "PRODUCTCODE" );
cs1.setExpression( "dataSetRow[\"PRODUCTCODE\"]");
cs1.setDataType( "string" );
cs1.setAggregateOn(null);
cs2 = StructureFactory.createComputedColumn( );
cs2.setName( "QUANTITYORDERED" );
cs2.setExpression( "dataSetRow[\"QUANTITYORDERED\"]");
cs2.setDataType( "integer" );
extendedItemHandle.addColumnBinding(cs1, true);
extendedItemHandle.addColumnBinding(cs2, true);
private Chart createChart() {
ChartWithAxes cwaLine = ChartWithAxesImpl.create();
cwaLine.setType( "Line Chart" ); //$NON-NLS-1$
cwaLine.setSubType( "Overlay" ); //$NON-NLS-1$
cwaLine.getBlock().getBounds().setWidth(600);
cwaLine.getBlock().getBounds().setHeight(400);
// Plot
cwaLine.getBlock().setBackground( ColorDefinitionImpl.WHITE() );
Plot p = cwaLine.getPlot();
p.getClientArea().setBackground( ColorDefinitionImpl.create(
255, 255,
225 ) );
// Title
cwaLine.getTitle().getLabel().getCaption().setValue("Overlay
test Line Chart" );
cwaLine.getTitle().setVisible(true);
// Legend
cwaLine.getLegend().setVisible( true );
// X-Axis
Axis xAxisPrimary = cwaLine.getPrimaryBaseAxes()[0];
xAxisPrimary.setType( AxisType.TEXT_LITERAL );
//xAxisPrimary.getMajorGrid().setTickStyle(
TickStyle.BELOW_LITERAL );
//xAxisPrimary.getOrigin().setType( IntersectionType.MIN_LITERAL );
// Y-Axis
Axis yAxisPrimary = cwaLine.getPrimaryOrthogonalAxis(
xAxisPrimary );
yAxisPrimary.setType(AxisType.LINEAR_LITERAL);
//yAxisPrimary.getMajorGrid().setTickStyle(
TickStyle.RIGHT_LITERAL );
//yAxisPrimary.getLabel().getCaption().setValue("TEST");
yAxisPrimary.getLabel().setVisible(true);
// X-Series
Series seCategory = SeriesImpl.create( );
// seCategory.setDataSet( categoryValues );
// Set category expression.
seCategory.getDataDefinition( )
.add( QueryImpl.create( "row[\"PRODUCTCODE\"]" ) );
SeriesDefinition sdX = SeriesDefinitionImpl.create( );
sdX.getSeriesPalette( ).shift( 0 );
sdX.setSorting(SortOption.ASCENDING_LITERAL);
// Set default grouping.
SeriesGrouping grouping = sdX.getGrouping( );
grouping.getAggregateExpression();
grouping.setEnabled( true );
grouping.setGroupType( DataType.TEXT_LITERAL );
grouping.setGroupingUnit( GroupingUnitType.STRING_PREFIX_LITERAL );
grouping.setGroupingInterval( 1 );
grouping.setAggregateExpression( "Sum" ); // Set Count aggregation.
//$NON-NLS-1$
xAxisPrimary.getSeriesDefinitions( ).add( sdX );
sdX.getSeries( ).add( seCategory );
// Y-Series
LineSeries bs1 = (LineSeries) LineSeriesImpl.create( );
bs1.getDataDefinition( ).add( QueryImpl.create(
"row[\"QUANTITYORDERED\"]" ) );
bs1.getLabel( ).setVisible( true );
SeriesDefinition sdY = SeriesDefinitionImpl.create( );
sdY.getGrouping().setEnabled(false);
yAxisPrimary.getSeriesDefinitions( ).add( sdY );
sdY.getSeries( ).add( bs1 );
return cwaLine;
Re: create a report in code [message #518599 is a reply to message #518314] Thu, 04 March 2010 10:25 Go to previous messageGo to next message
All right I finally got it to work!
http://pastebin.com/VUvyDsgW
It took a long time to see the problems, but this is what the application does:
1) Fully configurable paths and database selection
2) Make charts (pie, line and 3d bars)
3) Save it to design, report and html
4) View the html in a JEditorPane
The application will use the test database to retrieve data with some restrictions. Only the two first columns from the sql-selection will be used, and the first one must be in string-format.
You need to include the follwing jar-files (included in birt engine, model and chart api):
engineapi.jar
coreapi.jar
com.ibm.icu...jar
modelapi.jar
js.jar
org.apache.commons.codec...jar
org.eclipse.birt.chart.engine...jar
org.eclipse.birt.chart.reportitem.source...jar
org.eclipse.emf.ecore...jar
org.eclipse.emf.common...jar
org.eclipse.emf.ecore.xmi...jar
scriptapi.jar
Ignore the icons or make your own (png-files made in paint).
Re: create a report in code [message #518639 is a reply to message #518599] Thu, 04 March 2010 06:50 Go to previous messageGo to next message
Carl,
If would be good if you could add your example to Birt-Exchange.com dev
share.
Jason
> application does:
> engineapi.jar
> coreapi.jar
> com.ibm.icu...jar
> modelapi.jar
> js.jar
> scriptapi.jar
Re: create a report in code [message #518853 is a reply to message #518639] Fri, 05 March 2010 05:03 Go to previous messageGo to next message
Done.
The code works but is ugly. Easy job to fix though.
http://www.birt-exchange.org/devshare/deploying-birt-reports /1171-charts-example-with-jdbc/#description
Re: create a report in code [message #519036 is a reply to message #518853] Fri, 05 March 2010 14:12 Go to previous messageGo to next message
Thanks for doing this
Carl Emmoth wrote:
> Done.
Re: create a report in code [message #527053 is a reply to message #519036] Tue, 13 April 2010 16:05 Go to previous messageGo to next message
I have been playing around with this sample and got it working.
I figured out how to change to landscape and how to change the sizes of the data columns.
I changed the output to pdf.
now I am trying to figure out how to change the font used by the report, any ideas?
thanks
bob
Re: create a report in code [message #527255 is a reply to message #527053] Wed, 14 April 2010 11:11 Go to previous messageGo to next message
Bob,
You can set properties directly
data = elementFactory.newDataItem( null );
data.setProperty( StyleHandle.FONT_FAMILY_PROP,"Arial");
or modify the default report style property
reportDesignHandle.findStyle("report").setProperty(StyleHandle.FONT_FAMILY_PROP,
"Arial");
or use a new style. To create a style use the ElementFactory like:
private void createStyles( ) throws SemanticException
StyleHandle labelStyle = elementFactory.newStyle( "Label" );
labelStyle.setProperty( StyleHandle.FONT_WEIGHT_PROP,
DesignChoiceConstants.FONT_WEIGHT_BOLD );
labelStyle.setProperty( StyleHandle.FONT_FAMILY_PROP, "Arial Black" );
labelStyle.setProperty( StyleHandle.COLOR_PROP, "#008000" );
StyleHandle dataStyle = elementFactory.newStyle( "Data" );
dataStyle.setProperty( StyleHandle.FONT_WEIGHT_PROP,
dataStyle.setProperty( StyleHandle.FONT_FAMILY_PROP, "Century"
);//$NON-NLS-1$
dataStyle.setProperty( StyleHandle.COLOR_PROP, "#009B9B" );
reportDesignHandle.getStyles( ).add( labelStyle );
reportDesignHandle.getStyles( ).add( dataStyle );
Then set the style on an element like:
CellHandle tcell = (CellHandle) header.getCells( ).get( 0 );
LabelHandle label = elementFactory.newLabel( null );
label.setText( "Product" );
label.setStyleName( "Label" );
tcell.getContent( ).add( label );
Jason
> the data columns.
> any ideas?
> thanks
> bob
Re: create a report in code [message #658610 is a reply to message #518853] Wed, 09 March 2011 04:17 Go to previous messageGo to next message
Here's a updated link:
"Charts Example with JDBC"
Home / DevShare / Deploying BIRT Reports
http://www.birt-exchange.org/org/devshare/deploying-birt-rep orts/1171-charts-example-with-jdbc/
And Pastbin:
[Updated on: Wed, 09 March 2011 04:18] by Moderator
Re: create a report in code [message #658717 is a reply to message #658610] Wed, 09 March 2011 10:27 Go to previous message
Thanks for posting.
Jason
Previous Topic:Simple Java Application Creating and Saving Different Charts
Next Topic:Can't get year from date using getYear or getFullYear
Current Time: Sun Jul 27 09:15:27 EDT 2025
Powered by FUDForum. Page generated in 0.07256 seconds
