Home » Modeling » Epsilon » Problem resolving object slots from ECL
Problem resolving object slots from ECL [message #526864] Tue, 13 April 2010 06:44 Go to next message
Originally posted by: c.k.holmes.lboro.ac.uk
I have an increasingly refined model structure of the form:
Project A
Package A1
Package A2
Where Package A2 has a 'ref' relationship to a class defined in Package
A1 (I suspect this detail is irrelevant to this query).
Project B
Package B1
Although Package B1 actually comprises a nested hierarchy of packages it
extends some of the concepts introduced in Package A2.
Package A2 comprises a tree structured hierarchy of classes (the
examples below are contrived):
class Catalogue {
attr String name = "";
val Component[*] contains;
class Component {
val SubComponent[*] contains;
class SubComponent {
Package B1 comprises:
class Specification extends A2.Catalogue {
<more attributes>
class SpecifiedSubComponent extends A2.SubComponent {
<more attributes>
I want to compare two instances of the same metamodel. My ECL looks like
this:
pre {
post {
rule Specification
match left : Left!Specification
with right : Right!Specification {
compare {
return left.name = right.name;
do {
if(LoggingEnabled) {
('specification matched on: ' + left.name).println();
rule Component
match left : Left!Component
with right : Right!Component {
compare {
do {
('component matched on: ' + left.name).println();
rule SpecifiedSubComponent
match left : Left!SpecifiedSubComponent
with right : Right!SpecifiedSubComponent {
compare {
do {
('specified sub-component matched on: ' + left.name).println();
The ECL reports a failure at the compare statement block for the rule
Component, stating that property 'name' can't be found in class
Component. However the logging trace shows that the message:
'component matched on: aComponnetName' has been ejected to the console,
hence it has resolved the name attribute of the 'left' object (I can
switch left and right objects, it makes no difference).
If I remove rule Component then the ECL runs to completion without
raising an exception.
I can't see an error in my ECL, and my suspicion is that there is
something awry in the way ECL is dealing with the model hierarchy. I am
running the ECL from an Ant script.
Chris
Re: Problem resolving object slots from ECL [message #526866 is a reply to message #526864] Tue, 13 April 2010 06:49 Go to previous messageGo to next message
Hi Chris,
Could you please put together a minimal example that reproduces this
behaviour and send it to me by email so that I can have closer look?
Dimitris
On 13/04/2010 13:44, Chris Holmes wrote:
> Project A
> Package A1
> Package A2
> Project B
> Package B1
> class Catalogue {
> class Component {
> <more attributes>
> <more attributes>
> this:
> pre {
> post {
> rule Specification
> compare {
> do {
> rule Component
> compare {
> do {
> compare {
> do {
> Regards
> Chris
Re: Problem resolving object slots from ECL [message #526928 is a reply to message #526866] Tue, 13 April 2010 10:06 Go to previous messageGo to next message
Hi Dimitris,
I'm not sure that such a minimal example is such a small undertaking
(for me!;)). I have amended my metamodel such that I have a new class
'SpecifiedComponent' in package B1 extending from 'Component' in package
A2, and the ECL now executes to completion. Hence, I assume that the
problem is something to do with ECL acquiring the appropriate package
level visibility of the components in the metamodel(s).
I can demonstrate the problem on the complete model set when I'm next in
York, currently planned to be Fri 30-Apr - will you be there?
Best Wishes
Chris
Dimitris Kolovos wrote:
> Hi Chris,
> Cheers,
> Dimitris
>> Hi,
>> Project A
>> Package A1
>> Package A2
>> Project B
>> Package B1
>> class Catalogue {
>> class Component {
>> <more attributes>
>> <more attributes>
>> this:
>> pre {
>> post {
>> rule Specification
>> compare {
>> do {
>> rule Component
>> compare {
>> do {
>> compare {
>> do {
>> Regards
>> Chris
Re: Problem resolving object slots from ECL [message #527046 is a reply to message #526928] Tue, 13 April 2010 15:35 Go to previous message
Hi Chris,
Pleas see comments below:
On 13/04/2010 17:06, Chris Holmes wrote:
> Hi Dimitris,
In case it helps, all languages in Epsilon reuse the same model
connectivity layer so the problem should be reproducible using plain EOL.
Yes. Let's have a look at it then.
> Best Wishes
> Chris
Dimitris
>> Hi Chris,
>> Cheers,
>> Dimitris
>>> Hi,
>>> Project A
>>> Package A1
>>> Package A2
>>> Project B
>>> Package B1
>>> class Catalogue {
>>> class Component {
>>> <more attributes>
>>> <more attributes>
>>> this:
>>> pre {
>>> post {
>>> rule Specification
>>> compare {
>>> do {
>>> rule Component
>>> compare {
>>> do {
>>> compare {
>>> do {
>>> Regards
>>> Chris
Re: Problem resolving object slots from ECL [message #588275 is a reply to message #526864] Tue, 13 April 2010 06:49 Go to previous message
Hi Chris,
Dimitris
> Project A
> Package A1
> Package A2
> Project B
> Package B1
> class Catalogue {
> class Component {
> <more attributes>
> <more attributes>
> this:
> pre {
> post {
> rule Specification
> compare {
> do {
> rule Component
> compare {
> do {
> compare {
> do {
> Regards
> Chris
Re: Problem resolving object slots from ECL [message #588286 is a reply to message #526866] Tue, 13 April 2010 10:06 Go to previous message
Hi Dimitris,
Best Wishes
Chris
> Hi Chris,
> Cheers,
> Dimitris
>> Hi,
>> Project A
>> Package A1
>> Package A2
>> Project B
>> Package B1
>> class Catalogue {
>> class Component {
>> <more attributes>
>> <more attributes>
>> this:
>> pre {
>> post {
>> rule Specification
>> compare {
>> do {
>> rule Component
>> compare {
>> do {
>> compare {
>> do {
>> Regards
>> Chris
Re: Problem resolving object slots from ECL [message #588294 is a reply to message #526928] Tue, 13 April 2010 15:35 Go to previous message
Hi Chris,
> Hi Dimitris,
> Best Wishes
> Chris
Dimitris
>> Hi Chris,
>> Cheers,
>> Dimitris
>>> Hi,
>>> Project A
>>> Package A1
>>> Package A2
>>> Project B
>>> Package B1
>>> class Catalogue {
>>> class Component {
>>> <more attributes>
>>> <more attributes>
>>> this:
>>> pre {
>>> post {
>>> rule Specification
>>> compare {
>>> do {
>>> rule Component
>>> compare {
>>> do {
>>> compare {
>>> do {
>>> Regards
>>> Chris
Previous Topic:Problem resolving object slots from ECL
Next Topic:Passing Parameters into ETL from Ant
Current Time: Sat Jul 26 08:05:45 EDT 2025
Powered by FUDForum. Page generated in 0.08131 seconds
