Home » Language IDEs » ServerTools (WTP) » Eclipse 3.5: Tomcat server was unable to start..
Eclipse 3.5: Tomcat server was unable to start.. [message #526242] Fri, 09 April 2010 06:43 Go to next message
When I start Tomcat server from Eclipse, it shows no errors, but when the start timeout goes off it says "Server Tomcat v6.0 Server at localhost was unable to start within %start_timeout% seconds". Though "localhost:8080" in my browser shows Tomcat error page, so it is actually running. The same goes on with J2EE Preview server.
PS I am running Debian Squeeze/sid.
[Updated on: Mon, 12 April 2010 14:42] by Moderator
Re: Eclipse 3.5: Tomcat server was unable to start.. [message #526628 is a reply to message #526242] Mon, 12 April 2010 08:57 Go to previous messageGo to next message
What version of Eclipse and WTP are you using and what is the timeout
set to?
Larry
Re: Eclipse 3.5: Tomcat server was unable to start.. [message #526685 is a reply to message #526628] Mon, 12 April 2010 11:30 Go to previous messageGo to next message
I'm glad you are willing to help, Eclipse 3.5.2, WTP 3.1.1, timeout was set to default value for tomcat - 45 sec.
I switched from openjdk-6 to sun-java6-jdk and my problem was fixed. Also there was a trouble for tomcat to bind the port, but "sudo sysctl -w net.ipv6.bindv6only=0" solved the issue.
Re: Eclipse 3.5: Tomcat server was unable to start.. [message #526709 is a reply to message #526685] Mon, 12 April 2010 12:17 Go to previous message
> set to default value for tomcat - 45 sec. I switched from openjdk-6 to
I'm glad you found a workaround. It may be that that openjdk-6 runtime
is implemented in a way that doesn't work well with how the WTP Tomcat
support pings the server. I will give openjdk-6 a try sometime, just to
see the nature of the issue. I don't know if it will be practical to do
something about it.
Larry
Previous Topic:tagdir support in JSP Editor of WTP 1.5
Next Topic:Could not publish to the server. Eclipse 3.5 SR-2 Build id: 20100218-1602
Current Time: Fri Nov 07 16:42:36 EST 2025
Powered by FUDForum. Page generated in 0.03162 seconds
