| Eclipse 3.5: Tomcat server was unable to start.. [message #526242] |
Fri, 09 April 2010 06:43  |
When I start Tomcat server from Eclipse, it shows no errors, but when the start timeout goes off it says "Server Tomcat v6.0 Server at localhost was unable to start within %start_timeout% seconds". Though "localhost:8080" in my browser shows Tomcat error page, so it is actually running. The same goes on with J2EE Preview server.
PS I am running Debian Squeeze/sid.
[Updated on: Mon, 12 April 2010 14:42] by Moderator
| Re: Eclipse 3.5: Tomcat server was unable to start.. [message #526709 is a reply to message #526685] |
Mon, 12 April 2010 12:17  |
n0weak wrote:
> I'm glad you are willing to help, Eclipse 3.5.2, WTP 3.1.1, timeout was
> set to default value for tomcat - 45 sec. I switched from openjdk-6 to
> sun-java6-jdk and my problem was fixed.
I'm glad you found a workaround. It may be that that openjdk-6 runtime
is implemented in a way that doesn't work well with how the WTP Tomcat
support pings the server. I will give openjdk-6 a try sometime, just to
see the nature of the issue. I don't know if it will be practical to do
something about it.
Larry
FUDForum. Page generated in 0.07485 seconds
