Home » Archived » Buckminster » Downloading
Downloading [message #526573] Mon, 12 April 2010 06:32 Go to next message
Hey everybody,
I just want to download headless buckminster with the director using
director/director -r http://download.eclipse.org/tools/buckminster/updates-3.5 -d buckminster -p Buckminster -i org.eclipse.buckminster.cmdline.product,
but this leeds to an exception
!ENTRY org.eclipse.equinox.p2.repository 4 1002 2010-04-12 12:25:24.057
!MESSAGE Unable to connect to repository http://download.eclipse.org/tools/buckminster/updates-3.5/co ntent.xml
!STACK 0
java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.ja va:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:519)
at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEv entCreateUtil.createSocket(SocketEventCreateUtil.java:43)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient.EC FHttpClientProtocolSocketFactory.createSocket(ECFHttpClientP rotocolSocketFactory.java:81)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient.EC FHttpClientProtocolSocketFactory.createSocket(ECFHttpClientP rotocolSocketFactory.java:73)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient.EC FHttpClientProtocolSocketFactory.createSocket(ECFHttpClientP rotocolSocketFactory.java:65)
at org.apache.commons.httpclient.HttpConnection.open(HttpConnec tion.java:707)
at org.apache.commons.httpclient.MultiThreadedHttpConnectionMan ager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionM anager.java:1361)
at org.apache.commons.httpclient.HttpMethodDirector.executeWith Retry(HttpMethodDirector.java:387)
at org.apache.commons.httpclient.HttpMethodDirector.executeMeth od(HttpMethodDirector.java:171)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpC lient.java:397)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpC lient.java:346)
at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientF ileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java :204)
at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSys temBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:7 1)
!ENTRY org.eclipse.equinox.p2.core 4 0 2010-04-12 12:25:24.061
What's wrong with my call?
Greetings
M. Oley
Re: Downloading [message #526613 is a reply to message #526573] Mon, 12 April 2010 07:38 Go to previous messageGo to next message
Hi Markus,
I see two things:
1. The update site is wrong. Use http://download.eclipse.org/tools/buckminster/headless-3.5 instead.
2. Don't use a relative path to -d. The director will do strange things unless you use an absolute path.
None of the above is the cause of your exception though. Perhaps a temporary network failure?
Thomas Hallgren
On 04/12/2010 12:32 PM, Markus Oley wrote:
> Hey everybody,
> !STACK 0
> tion.java:707)
> anager.java:1361)
> lient.java:397)
> lient.java:346)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Greetings M. Oley
Re: Downloading [message #526646 is a reply to message #526613] Mon, 12 April 2010 09:50 Go to previous message
Thanks for your reply.
The two things fixing were not the solution for my problem.
I am behind a proxy server. Can I say the director to use this proxy ?
Greetings
Markus
Previous Topic:Custom builders are not invoked in headless build
Next Topic:Ignored @SuppressWarnings("unchecked")
Current Time: Fri Jul 25 22:20:02 EDT 2025
Powered by FUDForum. Page generated in 0.03624 seconds
