Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EEF] Generate Architecture error(What does it mean?)
[EEF] Generate Architecture error [message #522723] |
Tue, 23 March 2010 13:55  |
I keep getting this error when I generate the EEF Architecture. Plus, the only files in src-gen folder are in the components, the parts.impl and the providers packages, and they have lots of errors.
What does this error mean:
java.lang.reflect.Invocation.TargetException
at org.eclipse.jface.operation.ModelContext.run (ModelContext.java:421)
at org.eclipse.jface.dialogs.ProgressMonitor.Dialog.run (ProgressMonitorDialog.java:507)
at org.eclipse.emf.eef.codegen.ui.generators.actions.AbstractGe nerateEEFAction.run (AbstractGenerateEEFAction.java:135)
Thanks.
Re: [EEF] Generate Architecture error [message #526309 is a reply to message #522723] |
Fri, 09 April 2010 11:20   |
I have been running into a similar problem. I read a few other threads and got to know that the prob was with Acceleo plugin, but on checking that i see that i have 0.9.0v200909291229, which i believe is the same as 0.9.0M2.
Stack Trace,
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:421)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:507)
at org.eclipse.emf.eef.codegen.ui.generators.actions.AbstractGe nerateEEFAction.run(AbstractGenerateEEFAction.java:139)
at org.eclipse.emf.eef.codegen.ui.generators.actions.AbstractGe nerateEEFAction.run(AbstractGenerateEEFAction.java:79)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
Caused by: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/acceleo/mtl/3.0' not found. (platform:/plugin/org.eclipse.emf.eef.codegen/org/eclipse/em f/eef/codegen/components/SubPropertiesEditionComponent.emtl, 3, 52)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at org.eclipse.emf.eef.codegen.components.SubPropertiesEditionC omponent.createResource(SubPropertiesEditionComponent.java:3 64)
at org.eclipse.emf.eef.codegen.components.SubPropertiesEditionC omponent.load(SubPropertiesEditionComponent.java:330)
at org.eclipse.emf.eef.codegen.components.SubPropertiesEditionC omponent. <init>(SubPropertiesEditionComponent.java:170)
at org.eclipse.emf.eef.codegen.ui.generators.common.GenerateAll $1. <init>(GenerateAll.java:116)
at org.eclipse.emf.eef.codegen.ui.generators.common.GenerateAll .doGenerate(GenerateAll.java:116)
at org.eclipse.emf.eef.codegen.ui.generators.actions.AbstractGe nerateEEFAction$1.run(AbstractGenerateEEFAction.java:108)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/acceleo/mtl/3.0' not found. (platform:/plugin/org.eclipse.emf.eef.codegen/org/eclipse/em f/eef/codegen/components/SubPropertiesEditionComponent.emtl, 3, 52)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2590)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2421)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1299)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1468)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1019)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:169)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at org.eclipse.acceleo.model.mtl.resource.EMtlResourceImpl.doLo ad(EMtlResourceImpl.java:67)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1282)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
... 8 more
Root exception:
... 8 more
Aditya
Re: [EEF] Generate Architecture error [message #526531 is a reply to message #526309] |
Mon, 12 April 2010 03:55   |
Hi Aditya,
these error means you have to upgrade your acceleo version to 3.0.0M6 .
it can be found here :
http://www.eclipse.org/modeling/m2t/downloads/?project=accel eo
Aditya Gupta a écrit :
> as 0.9.0M2.
> Stack Trace,
> on.java:251)
> (Realm.java:332)
> bench.java:493)
> tarter.java:368)
> tarter.java:179)
> LHandler.java:1468)
> Handler.java:1019)
> Handler.java:87)
> ndler.java:1001)
> ndler.java:712)
> ndler.java:169)
> Source)
> ourceImpl.java:180)
> ceImpl.java:1494)
> ceImpl.java:1282)
> .. 8 more
> Root exception:
> LHandler.java:1468)
> Handler.java:1019)
> Handler.java:87)
> ndler.java:1001)
> ndler.java:712)
> ndler.java:169)
> Source)
> ourceImpl.java:180)
> ceImpl.java:1494)
> ceImpl.java:1282)
> .. 8 more
> Regards,
> Aditya
Stéphane Bouchet, OBEO
Re: [EEF] Generate Architecture error [message #534476 is a reply to message #530406] |
Wed, 19 May 2010 06:03  |
hi Aditya,
sorry to reply so lately, i didn't see your message untill today.
You are facing a known problem, that is your EEF models are not valid.
You must ensure by hand that every editor as a representation.
in the furture will will improve the generation to validate first the
model ( and add these validations, too )
> Hi Stephane,
> Thanks for the update on eclipse wiki, it worked.
> I am facing another problem when i try to generate the EEF architecture.
> The architecture generation gives me a components, parts.impl and
> providers package. Which obviously generates a lot of compile time
> errors as the parts and parts.forms packages are not created.
> To check the sanctity of my EEF installation i imported the emf library
> example and then generated the architecture again. This time it worked
> without any glitches, and i was also able to implement the
> TabbedPropertySheet as explained on wiki.
> I am able to generate my model, edit, editor and test code correctly
> using the same genmodel though.
> So does this imply that my genmodel is lacking something or is the error
> at some place else?
> Regards,
> Aditya
Re: [EEF] Generate Architecture error [message #622403 is a reply to message #523271] |
Mon, 29 March 2010 09:12  |
herb,
sorry of the delay but bugzilla was not responding last week..
so fill a new bug on bugzilla here :
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EMFT& ;component=EEF
describe the problem ( when creating models, there is no widget for a
reference, should be AdvancedReferenceTableComposition )
and clic on the "add an attachment" button.
upload the .ecore file there, and we will have a look.
Herb Miller a écrit :
> I added a WidgetAdvancedTableCompositon for an aggregation reference.
> I could send you the .ecorediag file, but I am not sure how to do that
> on this forum.
> Thanks.
Re: [EEF] Generate Architecture error [message #622404 is a reply to message #622403] |
Mon, 29 March 2010 14:16  |
Okay, I entered the data in Bugzilla. The attachment did not work the 1st time, but it appeared to work the 2nd time. Just in case, I added the XML of the .ecore file in the comment field of the 2nd attachment attempt.
Thanks.
Re: [EEF] Generate Architecture error [message #622522 is a reply to message #526531] |
Thu, 29 April 2010 11:11  |
Hi Stephane,
The architecture generation gives me a components, parts.impl and providers package. Which obviously generates a lot of compile time errors as the parts and parts.forms packages are not created.
To check the sanctity of my EEF installation i imported the emf library example and then generated the architecture again. This time it worked without any glitches, and i was also able to implement the TabbedPropertySheet as explained on wiki.
I am able to generate my model, edit, editor and test code correctly using the same genmodel though.
So does this imply that my genmodel is lacking something or is the error at some place else?
Aditya
Re: [EEF] Generate Architecture error [message #622911 is a reply to message #622522] |
hi Aditya,
> Hi Stephane,
> at some place else?
> Regards,
> Aditya
Current Time: Wed Jul 23 04:04:41 EDT 2025
Powered by FUDForum. Page generated in 2.58808 seconds
