Home » Modeling » M2T (model-to-text transformation) » Externalization of check messages
Externalization of check messages [message #526433] Sat, 10 April 2010 20:20 Go to next message
HI,
I wonder if there is a way to enable the externalization of messages shown when there is an error or a warning with check so i can change them easily after
Best regards
mahmoud
Re: Externalization of check messages [message #526452 is a reply to message #526433] Sun, 11 April 2010 05:46 Go to previous messageGo to next message
hello mahmoud,
i don't know a direct way to do this but you can easy achive something similar by moving the message producing part of the check to a separate extension file.
metamodel/checks.chk
extension metamodel::messages;
context metamodel::Model ERROR msgABC() :
	false;
metamodel/messages.ext
String msgABC() : "There is an error";
or with some extra stuff you could even use java resource bundles
package metamodel;
import java.text.MessageFormat;
import java.util.List;
import java.util.ResourceBundle;
public class I18NHelper {
	public static String msg(String key, List<Object> args) {
		return MessageFormat.format(ResourceBundle.getBundle("messages").getString(key), args.toArray());
messages.properties
ABC=Böser Fehler
String msg(String key, List args) :
	JAVA metamodel.I18NHelper.msg(java.lang.String, java.util.List);
context metamodel::Model ERROR msg("ABC",{}) :
	false;
may not be perfect but working
Re: Externalization of check messages [message #526499 is a reply to message #526452] Sun, 11 April 2010 18:51 Go to previous messageGo to next message
Hi Christian,
Thanks for the reply, but i was looking exactly for your second answer, can i have more details about java resource bundles, i dont have any idea how to perform this,
thanks
mahmoud
Re: Externalization of check messages [message #526516 is a reply to message #526499] Mon, 12 April 2010 02:21 Go to previous messageGo to next message
ResourceBundle is a std java lib class so have a look at the javadoc for this
[Updated on: Mon, 12 April 2010 02:22] by Moderator
Re: Externalization of check messages [message #529684 is a reply to message #526516] Mon, 26 April 2010 14:26 Go to previous messageGo to next message
hi Christian,
i tried to perform the example but i couldnt make it woks.
I create the bundle but i dint understand how to make it work with I18NHelper
package com.validation;
import org.eclipse.osgi.util.NLS;
public class Messages extends NLS {
private static final String BUNDLE_NAME = "com.netfective.validation.messages"; //$NON-NLS-1$
public static String ddd_0;
static {
// initialize resource bundle
NLS.initializeMessages(BUNDLE_NAME, Messages.class);
private Messages() {
in my extension file this this :
JAVA com.validation.I18NHelper.msg(java.lang.String, java.util.List);
end last in my check file i have :
context DSLMetaModel::Attribute ERROR msg("ddd_0",{}) :
this.type.name!= null;
i know that its my fault because i forget something
mahmoud
Re: Externalization of check messages [message #529812 is a reply to message #529684] Tue, 27 April 2010 06:55 Go to previous messageGo to next message
Hi, you mix Java Resource bundles (I18NHelper) with Eclipse NLS (Your Messages class that is nowhere used). That is the problem.
Just have a look at the ResourceBundle JavaDoc for how to configure it (a file messages[_locale].properties in classpath since the code says ResourceBundle.getBundle("messages"))
[Updated on: Tue, 27 April 2010 06:58] by Moderator
Re: Externalization of check messages [message #530635 is a reply to message #529812] Fri, 30 April 2010 07:53 Go to previous message
Hello christian,
i would like to share my example that works pretty fine, thanks to you:
package com.sms;
import java.util.MissingResourceException;
public class Messages {
private static final String BUNDLE_NAME = "com.sms.messages";
private static final ResourceBundle RESOURCE_BUNDLE = ResourceBundle
.getBundle(BUNDLE_NAME);
public static String getString(String key) {
try {
return RESOURCE_BUNDLE.getString(key);
} catch (MissingResourceException e) {
return '!' + key + '!';
the messages.proprties:
test.1=element must have a name
the extension file :
String msg (String s):
JAVA com.sms.Messages.getString(java.lang.String)
and the check file :
context MetaModel::Cars ERROR msg('test.1')
this.name!=null
mahmoud
Previous Topic:Acceleo : White space handling
Next Topic:[check] Problem with the metamodel
Current Time: Thu Sep 25 10:08:41 EDT 2025
Powered by FUDForum. Page generated in 0.03500 seconds
