Home » Eclipse Projects » EGit / JGit » CPU consumed with many projects
CPU consumed with many projects [message #526360] Fri, 09 April 2010 16:07 Go to next message
I am trying to use EGit with a git repository that has ~20 Eclipse projects. After importing these projects into Eclipse, if I select a project and choose Team : Commit... then my CPU is consumed for many minutes before Eclipse responds.
I am curious if this is a known issue or perhaps there is a workaround for making EGIt work well with many projects in a single repository?
This occurred on:
* Windows 7 Professional - 64 bit
* Eclipse 3.5.2
* EGit 0.7.1
Thank you.
-David McNeil
[Updated on: Fri, 09 April 2010 16:08] by Moderator
Re: CPU consumed with many projects [message #526395 is a reply to message #526360] Sat, 10 April 2010 05:01 Go to previous messageGo to next message
Using Linux is one way :) Checking the status of all files takes a lot
of time and Linux is much faster.
The other answer is that we probably can make things faster, but the 20 or
so second delay when committing with 20-25 projects has not forced me there
yet. One of the reasons for slow speed is that we do not trust that Eclipse
is up-to-date on what resources have been changed on disk, so we force a
check and the major reason is that most EGit, and in particular the
developers use C Git every now and then, which means that Eclipse will be
unrefreshed very often. There are multiple ways of dealing with this and we
haven't made our minds up on how yet. When all operations are usable (merge
in particular), we may be able to start trusting Eclipse notion of
modification status.
-- robin
Re: CPU consumed with many projects [message #526410 is a reply to message #526395] Sat, 10 April 2010 11:31 Go to previous messageGo to next message
Measuring on Linux gave me the following quickfix. A guess is that is
helps even more on Windows. If you can please test and provide feedback.
http://egit.eclipse.org/r/#change,538
strace-ing Eclipse indicates more opportunities exists :)
-- robin
Re: CPU consumed with many projects [message #526417 is a reply to message #526410] Sat, 10 April 2010 13:30 Go to previous messageGo to next message
You are going to love this one: http://egit.eclipse.org/r/#change,539
Despite all my bad excuses we had some really inefficient code in there.
-- robin
Re: CPU consumed with many projects [message #526644 is a reply to message #526417] Mon, 12 April 2010 09:49 Go to previous messageGo to next message
Robin - Thank you for your responses. I will switch to the nightly build to see if your changes fix the issue for me.
Thanks.
-David
Re: CPU consumed with many projects [message #526659 is a reply to message #526360] Mon, 12 April 2010 10:18 Go to previous message
Robin - I tried the nightly build from yesterday and it seems the issue is resolved. Invoking the "Commit..." option in Eclipse now only takes ~6 seconds.
Thank you!
-David
Re: CPU consumed with many projects [message #579111 is a reply to message #526395] Sat, 10 April 2010 11:31 Go to previous message
-- robin
Re: CPU consumed with many projects [message #579128 is a reply to message #526410] Sat, 10 April 2010 13:30 Go to previous message
-- robin
Re: CPU consumed with many projects [message #579262 is a reply to message #526417] Mon, 12 April 2010 09:49 Go to previous message
Thanks.
-David
Previous Topic:Stashing in EGit
Next Topic:CPU consumed with many projects
Current Time: Thu Jul 24 11:21:31 EDT 2025
Powered by FUDForum. Page generated in 0.09009 seconds
