Home » Eclipse Projects » DTP » H2 enablement
H2 enablement [message #526056] Thu, 08 April 2010 11:17 Go to next message
I've integrated DTP in a RCP and we need to add some connectivity to
other product than those present in enablement project.
For example, I need to provide an enablement for H2 database. I have
followed this tutorial :
http://fitzdtp.blogspot.com/2008/08/dtp-sqlite-support-conti nued-on-to.html
However, I think i've missed the xmi generation (just left the template
value) as I don't know the specification for H2. The result is that I
succeed to connect the db but i've only access to the INFORMATION_SCHEMA
tables. I didn't succeed to see public table.
Thanks for your help.
Romain
Re: H2 enablement [message #526300 is a reply to message #526056] Fri, 09 April 2010 10:36 Go to previous messageGo to next message
Hi Romain!
Did you implement the catalog loaders that article discusses? That's
where the SQL results coming back from the database are converted to the
EMF model that gets rendered in the tree.
--Fitz
Romain Bioteau wrote:
> Romain
Re: H2 enablement [message #526305 is a reply to message #526300] Fri, 09 April 2010 11:00 Go to previous messageGo to next message
Hi Fitz,
I did try to do but something but i'm stuck with the same problem that
is : I don't know what is the specificity of H2 (the tutorial is
speaking about sqlite). Is H2 the same of Sqlite for catalog loaders ?
(no schema ?)
I will try to stick to the tutorial to see if it works like SQLite.
Thanks for the help
Romain
Le 09/04/2010 16:36, Brian Fitzpatrick a écrit :
> Hi Romain!
> --Fitz
>> Hi,
>> template value) as I don't know the specification for H2. The result
>> is that I succeed to connect the db but i've only access to the
>> INFORMATION_SCHEMA tables. I didn't succeed to see public table.
>> Romain
Re: H2 enablement [message #526306 is a reply to message #526305] Fri, 09 April 2010 11:06 Go to previous message
Yeah... Understood.
A lot of what you may need seems to be listed on the H2 site:
http://www.h2database.com/html/main.html
If you look at data types, SQL grammar, etc.
--Fitz
> Hi Fitz,
> (no schema ?)
> Thanks for the help
> Romain
>> Hi Romain!
>> --Fitz
>>> Hi,
>>> Romain
Re: H2 enablement [message #597422 is a reply to message #526056] Fri, 09 April 2010 10:36 Go to previous message
Hi Romain!
--Fitz
> Romain
Re: H2 enablement [message #597428 is a reply to message #526300] Fri, 09 April 2010 11:00 Go to previous message
Hi Fitz,
(no schema ?)
Thanks for the help
Romain
> Hi Romain!
> --Fitz
>> Hi,
>> Romain
Re: H2 enablement [message #597434 is a reply to message #526305] Fri, 09 April 2010 11:06 Go to previous message
Yeah... Understood.
--Fitz
> Hi Fitz,
> (no schema ?)
> Thanks for the help
> Romain
>> Hi Romain!
>> --Fitz
>>> Hi,
>>> Romain
Previous Topic:Generic parser API
Next Topic:Re: Connection with MySQL
Current Time: Sat Jul 26 10:47:54 EDT 2025
Powered by FUDForum. Page generated in 0.06543 seconds
