Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Single Selection of the cell in Tree component(Single Selection of the cell in Tree component)
Single Selection of the cell in Tree component [message #525655] Wed, 07 April 2010 07:51 Go to next message
How to implement the Single selection of the cell in SWT Tree component. I have two four column in tree and want to select the on cell and attache event to it
Re: Single Selection of the cell in Tree component [message #525672 is a reply to message #525655] Wed, 07 April 2010 08:36 Go to previous messageGo to next message
> attache event to it
You may be successful, if you test either of these approaches (adapted
to tree instead of table):
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet110.java?view=co
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet3.java?view=co
Read the comment in the snippet carefully, because the second
approach works only for SWT.FULL_SELECTION.
You may also try this one:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet90.java?view=co
HTH & Greetings from Bremen,
Daniel Krügler
Re: Single Selection of the cell in Tree component [message #525934 is a reply to message #525672] Thu, 08 April 2010 06:42 Go to previous messageGo to next message
Thanks for the replay
In My Screen i have tree component which has around 4 columns in it. User should able to select any cell and corresponding action should fired. I mean when i select cell from second row and second column. That particular cell should highlighted and new window should get open.
Re: Single Selection of the cell in Tree component [message #525960 is a reply to message #525934] Thu, 08 April 2010 07:27 Go to previous messageGo to next message
Did you try any of the suggested approaches? IMO it should be possible
to deduce both the row and column coordinates of a given cell.
If you are working on a jface level, you could also use the method
ColumnViewer.getCell(Point). The current coordinates provided via
the Point object are typically available within a mouse-event (e.g.
MouseListener) and the returned ViewerCell instance provides the
column and row information. This is basically the same information
as obtained from SWT level, but you can do that with less code writing.
If you want to realize that a *single* cell is selected, you may
consider to use a cell editor in read-only mode to realize this. Search
for "celleditor" in
http://wiki.eclipse.org/index.php/JFaceSnippets
or look at what the focus cell manager does (search for "cellnavigation"
in the same page).
Daniel Krügler
Re: Single Selection of the cell in Tree component [message #525977 is a reply to message #525960] Thu, 08 April 2010 09:06 Go to previous messageGo to next message
We have the application which used SWT Tree component, with that single cell selection is not working. need to make it work with the minimum changes. Just want to know what is the best way i can implement this in my scenario.
Yes i have gone through the example.
Re: Single Selection of the cell in Tree component [message #526003 is a reply to message #525977] Thu, 08 April 2010 10:10 Go to previous messageGo to next message
See http://www.eclipse.org/forums/index.php?t=msg&th=163693& amp;#msg_518092 .
For an example of using TableCursor, which provides the functionality that
you want for Tables, see
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/org. eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet96. java .
Grant
<atmohsin@gmail.com> wrote in message news:hpkkd4$1m9$1@build.eclipse.org...
scenario.
> Thanks
Re: Single Selection of the cell in Tree component [message #526016 is a reply to message #526003] Thu, 08 April 2010 10:35 Go to previous messageGo to next message
Is it possible for org.eclipse.swt.widgets.Tree component. Because we are using Tree component right now i dont want to change the basic control.
Re: Single Selection of the cell in Tree component [message #526080 is a reply to message #526016] Thu, 08 April 2010 11:52 Go to previous messageGo to next message
See the first link. There's currently no TreeCursor class, but if you make
a copy of the TableCursor class and do a Find/Replace of "able" with "ree",
you'll get somewhat close to having a TreeCursor class.
To be notified of progress on the the request to add a TreeCursor class in
swt you should CC yourself to the linked bug report.
Grant
<atmohsin@gmail.com> wrote in message news:hpkpj0$h6n$1@build.eclipse.org...
Re: Single Selection of the cell in Tree component [message #526170 is a reply to message #526080] Fri, 09 April 2010 02:08 Go to previous message
There is jar file which has TreeCursor implementation and relative classes. Find the URL
http://www.java2s.com/Code/Jar/DEF/Downloadorgeclipsedebugui 330v200706071800jar.htm
I tested it is working fine with this. Only the problem with this is the selected cell color and selected row color is different. The selected row color is Grey and selected cell is white how to control the colors.
Mohsin
Previous Topic:SWT Browser Widget, no mouse events while loading
Next Topic:org.eclipse.swt.widgets.Tracker
Current Time: Sun Aug 31 19:03:31 EDT 2025
Powered by FUDForum. Page generated in 0.05244 seconds
