Home » Modeling » M2T (model-to-text transformation) » [XPand][AOP][Sculptor] problem calling the metamodel
[XPand][AOP][Sculptor] problem calling the metamodel [message #525944] Thu, 08 April 2010 07:19 Go to next message
Hi everyOne!!
i started using the fornax-platform generator : sculptor .
When i wanted to add my own template ( unsing AOP Rolling Eyes ) i had some problems when calling the metamodel sculptor.
Here is my xpand :
«IMPORT sculptormetamodel»
«EXTENSION extensions::helper»
«EXTENSION extensions::properties»
«AROUND templates::DomainObject::uuidAccessor FOR DomainObject»
    // You had to add your own implementation
«ENDAROUND»
and the project didn't know my token " DomainObject " !!!
I followed the sculptor tutorial. but that didn't work !!!
any one can help me please ! Crying or Very Sad
Re: [XPand][AOP][Sculptor] problem calling the metamodel [message #525948 is a reply to message #525944] Thu, 08 April 2010 07:25 Go to previous messageGo to next message
Hello MasterBoy,
to get fast help from the Sculptor/Fornax team, please ask Sculptor/Fornax related question in the Fornax Nabble Forum: http://old.nabble.com/Fornax-Platform-f17564.html
Darius Jockel
Re: [XPand][AOP][Sculptor] problem calling the metamodel [message #525950 is a reply to message #525944] Thu, 08 April 2010 07:38 Go to previous messageGo to next message
I resolve the problem but an other one apear Very Happy
the problem was in when i tried to modify the xpand file, a message appeared :
Do you want to add the 'Xpend nature to project' myProject
if i choose yes the precedent problem appear
but if i choose no, every thing work, but i can't use "Ctrl+Space" to access my metamodel possibilities.
Re: [XPand][AOP][Sculptor] problem calling the metamodel [message #525952 is a reply to message #525944] Thu, 08 April 2010 07:44 Go to previous messageGo to next message
Hello MasterBoy.
If you do not add the XpandNature you will get no editor support.
Is a DomainObject a MetaType from Sculptor or a type you defined in your own metamodel? You have to add every metamodel you want to work with inside the Xpand template.
Darius
Re: [XPand][AOP][Sculptor] problem calling the metamodel [message #525953 is a reply to message #525944] Thu, 08 April 2010 07:47 Go to previous messageGo to next message
Hi darius ,
I don't think that the problem is in using sculptor.
the problem is in using AOP in Xpand!! Rolling Eyes
i tried that with my one projects, but that still unwork.
I just mension Sculptor to explain more my problem Cool
Re: [XPand][AOP][Sculptor] problem calling the metamodel [message #525956 is a reply to message #525953] Thu, 08 April 2010 07:52 Go to previous messageGo to next message
thx Darius,
Well when i choose yes, they appear Dslsculptor as metamodel, and not sculptormetamodel,
when i check the source code, i found that the xpand files in sculptor call sculptormetamodel !!
so DomainObject did not existe in dslsculptor !!
that confusing me Sad
Re: [XPand][AOP][Sculptor] problem calling the metamodel [message #525958 is a reply to message #525956] Thu, 08 April 2010 08:02 Go to previous messageGo to next message
Please help me in this one Darius,
I checked the xtext file, they use as name dslsculptor,
so how can they use sculptormetamodel as imported metamodel !!
can i define the imported name in an other file or there is an other way to do that !!!
Re: [XPand][AOP][Sculptor] problem calling the metamodel [message #525965 is a reply to message #525958] Thu, 08 April 2010 08:24 Go to previous messageGo to next message
Hello MasterBoy,
the Sculptor Guys use two DSLs.
The first dsl is the Sculptordsl. This DSL is used for modelling.
It is defined by an Xtext grammar and the Editor is based on this one.
But for generation a second DSL is used. This one is called sculptormetamodel. The templates are based on this metamodel.
The Sculptor workflow will parse the Xtext Sculptordsl model and transform it into an sculptormetamodel. The most types in bouth metamodels have the same name.
If you want to customize the generation output you have to select the sculptormetamodel.
Darius
Re: [XPand][AOP][Sculptor] problem calling the metamodel [message #526001 is a reply to message #525965] Thu, 08 April 2010 10:08 Go to previous messageGo to next message
thanks Darius,
That true, i tried to use sculptormetamodel and that work Very Happy
but that didn't let me to use the Ctrl+Space function!! that's look like developping with Bloc Note Shocked
is there a way to add the XpandNature manually ?
I found that sculptormetamodel is an ecore generated from sculptordsl, so if i use the appeired message from eclipse, that give me the right to add just the dsl and note the ecore! and the definition of the rules in dsl are diffirent than those used in ecore
for exemple dslDomainObject in dsl called DomainObject in the metamodel !!
[Updated on: Thu, 08 April 2010 10:27] by Moderator
Re: [XPand][AOP][Sculptor] problem calling the metamodel [message #526010 is a reply to message #526001] Thu, 08 April 2010 10:27 Go to previous messageGo to next message
MasterBoy wrote on Thu, 08 April 2010 16:08
Right click. Inside the context menu choose Configure -> Add Xpand/Xtend Nature
Re: [XPand][AOP][Sculptor] problem calling the metamodel [message #526023 is a reply to message #526010] Thu, 08 April 2010 10:43 Go to previous messageGo to next message
thank you Darius,
I think that i didn't explain my question ( because of my english i think Rolling Eyes )
as you said, sculptor use two DSL, one for xtext grammar and the other for code generation.
my problem is when i add the xpand nature, he didn't know sculptormetamodel elements!!
so i wanted to ask you if that i should make some configuration to detect the sculptormetamodel ( give him the path or something) or the XpandNature have no relation with a specific dsl!!
and thank you so much for ur help and the time you spent with me today Smile
[Updated on: Thu, 08 April 2010 11:03] by Moderator
Re: [XPand][AOP][Sculptor] problem calling the metamodel [message #526046 is a reply to message #526023] Thu, 08 April 2010 11:12 Go to previous messageGo to next message
hm, the editor do not know about the sculptormetamodel, but you can generate without problems, yes?
Please check if the emf metamodel is activated in the project properties and all needed jars are in the classpath.
Xpand will search the classpath for the selected kinds of metamodells (no path or further configuration is needed).
In some cases the editor have problems to rersolve dependencies if artifacts are placed into a jar.
It is strange because the editor knows about a sculptordsl metamodel, yes?
It sounds like it is a more genral. You can not access sculptormetamodel inside an template or extension not only inside an AROUND, or not?
What version of Xpand do you use?
Can you provide an minimal example project?
Darius
Re: [XPand][AOP][Sculptor] problem calling the metamodel [message #526103 is a reply to message #526046] Thu, 08 April 2010 12:55 Go to previous messageGo to next message
Yes i can generate without problems
Yes the emf metamodel is activated and all the jars are in the classpath
Yes he knowd about sculptordsl but not sculptormetamodel..
when i cheked the the sculptor generator project, i found sculptordsl.dsl in a package and sculptormetamodel.ecore in another package. but in the same project. is this ecore wich we call in our templates and extensions or i have to seach in another project?
Yes my problem is in calling sculptormetamodel not only inside an AROUND. that start when i tried to call it with IMPORT. I found sculptordsl but not the sculptormetamodel.
I use the last version of Xpand, wich is integrated in eclipse galileo 3.5
I just start my project, want you that i send you my project?
Re: [XPand][AOP][Sculptor] problem calling the metamodel [message #526192 is a reply to message #526103] Fri, 09 April 2010 04:11 Go to previous messageGo to next message
please open a Bugzilla and append your minimal project.
Re: [XPand][AOP][Sculptor] problem calling the metamodel [message #526558 is a reply to message #526192] Mon, 12 April 2010 05:54 Go to previous message
Sorry for the long time i took for my reply, i wasn't in my office to send you my project.
Well i resolved my problem, i add just the metamodel project to my workspace and import it to my project, Very Happy
that all.
But why he didn't know the metamodel dsl! that i ignore it Very Happy
Thank you so much for your help, and have a nice day !
Best regards
Zakariae
Previous Topic:How to call workflow from another application
Next Topic:Java Extension
Current Time: Thu Jul 31 21:45:10 EDT 2025
Powered by FUDForum. Page generated in 0.06264 seconds
