Home » Archived » Buckminster » Eclipse RCP plugins automated version number increment
Eclipse RCP plugins automated version number increment [message #525727] Wed, 07 April 2010 11:24 Go to next message
Hi There,
I am working on to set-up a build server for our OSS project UNICASE (http://code.google.com/p/unicase/) using hudson + buckminster.
I have a small problem as i am quite new to Buckminster.
Our project consists of several plugin based projects and they are combined together as one final product. Now the problem which i have is that i want to automate the version number increment within the Manifest file for each of the plugin before it proceeds to build the final product.
Now as the plugin within our project have cross dependency, i want this new version number to get reflected within the dependency section of the other plugins as well once changed in the Manifest of one.
I hope i was clear enough with the problem statement.
Any help or guidance is welcome!
Thanks in advance,
Nitesh
Re: Eclipse RCP plugins automated version number increment [message #525827 is a reply to message #525727] Wed, 07 April 2010 17:25 Go to previous messageGo to next message
An effective way of handling this is to use a revision number obtained
from the SCM, but it does not work with all SCM types. So, first
question - which SCM are you using?
- henrik
On 4/7/10 5:24 PM, nitesh wrote:
> Hi There,
> Thanks in advance,
> Nitesh
Re: Eclipse RCP plugins automated version number increment [message #525886 is a reply to message #525827] Thu, 08 April 2010 03:56 Go to previous messageGo to next message
Hello Henrik,
Thanks for the reply!
We are using subversion and our project is currently hosted at Google code.
Please let me know if you need some more information in order to suggest something.
Nitesh
Re: Eclipse RCP plugins automated version n umber increment [message #525907 is a reply to message #525886] Thu, 08 April 2010 04:52 Go to previous messageGo to next message
That is good! SVN has revisions, and the buckminster builds of itself
makes use of the SVN revisions. So you may want to take a look at how
'qualifier replacement' is done in buckminster's build. There is also
info in the buckminster book on this. I think there are other posts in
this forum on this topic as well.
I am on a handheld device at the moment and it is a bit difficult to
give you links to examples, but maybe someone else can paste a couple of
links...
- Henrik
nitesh <connect2nitesh@gmail.com> wrote:
> Hello Henrik,
> code.
> suggest something.
> Regards,
> Nitesh
- henrik
Re: Eclipse RCP plugins automated version n umber increment [message #525973 is a reply to message #525907] Thu, 08 April 2010 08:59 Go to previous messageGo to next message
Hello Henrik,
I followed the following tutorial to setup qualifier replacement and now finally i am getting the error given below. Any clue to fix the problem!
Doing full workspace refresh
Waiting for jobs to end
perform '-D' 'target.os=*' '-D' 'target.ws=*' '-D' 'target.arch=*' '-D' 'qualifier.replacement.*=N20100408-1 org.unicase.emfstore.feature.site#site.p2'
No attributes specified
Help text for org.eclipse.buckminster.core.perform:This command performs actions on components
usage: perform
       [{ -? | --help }]
       [{-D | --define} <key>[=<value>]]
       [{-P | --properties} <URL or Path>]
       [{-W | --maxWarnings} <n>]
       <component>#<action> [<component>#<action> ...]
--help
  Show this help text
 -D
--define
  Defines a property as a key=value pair. The value may include ant-style expansion constructs
  that will be expanded using both System properties and other properties that has been set.
 -P <URL or Path>
--properties <URL or Path>
  The URL or file system path of a properties file. The values in the file may include ant-style
  expansion constructs that will be expanded using both System properties and other properties
  that has been set.
 -W
--maxwarnings
  Give the number of warnings acceptable. If the number of warnings are higher,
  treat as error and exit with 1.
  Default is infinite warnings.
 -F
--forced
  Force all actions regardless of timestamps
 -Q
--quiet
  Don't print errors and warnings. Just exit with a non zero exit code on failure
  The component name and the action name to perform.
  Can be given multiple times in order to perform many actions in the most
  optimized way.Archiving artifacts
Finished: FAILURE
Thanks in advance.
Re: Eclipse RCP plugins automated version n umber increment [message #526112 is a reply to message #525973] Thu, 08 April 2010 13:36 Go to previous message
Nitesh,
It seems your arguments are incorrectly quoted:
should be
'qualifier.replacement.*=N20100408-1'
'org.unicase.emfstore.feature.site#site.p2'
Note the quotes to separate the arguments between '...N20100408-1' and
'org.unicase...'
Achim
nitesh wrote:
> Hello Henrik,
> http://swissdev.blogspot.com/2010/03/building-products-with. html to setup
> org.unicase.emfstore.feature.site#site.p2' Doing full workspace refresh
> Waiting for jobs to end No attributes specified
> usage: perform
> [{ -? | --help }]
> --help
> Show this help text
> -D
> --define
> -P <URL or Path>
> may include ant-style expansion constructs that will be expanded using
> -W
> --maxwarnings
> higher, treat as error and exit with 1.
> -F
> --forced
> -Q
> --quiet
> failure
> Finished: FAILURE
> Thanks in advance.
Previous Topic:Building Products with Buckminster/Hudson
Next Topic:Custom builders are not invoked in headless build
Current Time: Sun Jun 08 18:11:18 EDT 2025
Powered by FUDForum. Page generated in 0.24074 seconds
