Home » Archived » XML Schema Definition (XSD) » i miss the old schema viewer (who's idea was it to change it??)
Re: i miss the old schema viewer [message #525937 is a reply to message #525884] |
Thu, 08 April 2010 06:35   |
The WebTools project provides the editor, so I'm redirecting your
comment to that newsgroup/forum. In general, complaining on newsgroups
isn't likely to produce results. A bugzilla feature requeste stated in
the form of a constructive suggestion for what you'd like to see is more
likely to produce results and certainly ensures that your issue is
recorded properly.
elhanan wrote:
> hi..
> the current graphical representation of xml xsd, is horrible, unlike
> the old one, where it expanded the entire model like an erd, this one,
> you can't make heads or tails, xml spy's had it right, so did eclipse
> but for the last couple of versions, it unusable.
Re: i miss the old schema viewer [message #526044 is a reply to message #525937] |
Thu, 08 April 2010 11:04  |
Thanks Ed.
elhanan, there's an enhancement already opened for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=151058 Feel free to add any
additional suggestions in the bugzilla.
Regards, Valentin
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:hpkbhg$mq8$2@build.eclipse.org...
> The WebTools project provides the editor, so I'm redirecting your comment
> to that newsgroup/forum. In general, complaining on newsgroups isn't
> likely to produce results. A bugzilla feature requeste stated in the form
> of a constructive suggestion for what you'd like to see is more likely to
> produce results and certainly ensures that your issue is recorded
> properly.
> elhanan wrote:
>> hi..
>> the current graphical representation of xml xsd, is horrible, unlike the
>> old one, where it expanded the entire model like an erd, this one, you
>> can't make heads or tails, xml spy's had it right, so did eclipse but
Re: i miss the old schema viewer [message #604582 is a reply to message #525937] |
Thanks Ed.
Regards, Valentin
> properly.
> elhanan wrote:
>> hi..
Current Time: Wed Jul 23 07:43:45 EDT 2025
Powered by FUDForum. Page generated in 0.05050 seconds
