Home » Archived » BIRT » Integrating BIRT report with a standalone RCP application
Integrating BIRT report with a standalone RCP application [message #525625] Wed, 07 April 2010 05:05 Go to next message
I've created a report using the Report Designer Full Eclipse Install
(version 3.4.1). This works fine during design time. I now want to integrate
this report in an Eclipse IDE (Eclipse Ganymede - 3.4.1) which does not have
BIRT installed. I'm using the BIRT runtime 2.5.2 for this. The steps I have
followed are as follows-
1. Windows->Preferences->Plug-in Development->Target Platform and added all
the plug-ins available in the runtime plug-ins folder.
2. These are the dependencies I've added-
org.eclipse.ui
org.eclipse.core.runtime
org.eclipse.birt.core (2.5.2)
org.eclipse.birt.report.engine (2.5.2)
org.eclipse.birt.report.engine.emitter.html (2.5.2)
org.eclipse.birt.report.engine.script.javascript (2.5.2)
org.eclipse.birt.report.data.oda.jdbc (2.5.2)
3. I then tried running the RCP application containing the report. However,
nothing happens... the report is not getting generated. When I tried
debugging, I'm getting the following error-
java.lang.NoClassDefFoundError:
org.eclipse.birt.report.model.metadata.MetaDataDictionary (initialization
failure)
However, I can see this class in the list of Plug-in Dependencies.
Can you please help me in figuring out what the problem is?
Thanks and regards,
Nikita
Re: Integrating BIRT report with a standalone RCP application [message #525803 is a reply to message #525625] Wed, 07 April 2010 15:54 Go to previous messageGo to next message
Nikita,
Are you using the Birt RE API to generate the report? If you are
building an RCP application you can always use the Birt Viewer Plugin.
Jason
Nikita wrote:
> org.eclipse.ui
> failure)
> Thanks and regards,
> Nikita
Re: Integrating BIRT report with a standalone RCP application [message #525870 is a reply to message #525803] Thu, 08 April 2010 02:07 Go to previous messageGo to next message
Hi Jason,
Yes, I'm using the Birt RE API to generate the report. I need to know how to
integrate this with the RCP application.
"Jason Weathersby" <jasonweathersby@windstream.net> wrote in message
news:hpinlu$vmj$2@build.eclipse.org...
> Nikita,
> Are you using the Birt RE API to generate the report? If you are building
> Jason
> Nikita wrote:
>> Hi,
>> integrate this report in an Eclipse IDE (Eclipse Ganymede - 3.4.1) which
>> does not have BIRT installed. I'm using the BIRT runtime 2.5.2 for this.
>> The steps I have followed are as follows-
>> all the plug-ins available in the runtime plug-ins folder.
>> org.eclipse.ui
>> However, nothing happens... the report is not getting generated. When I
>> tried debugging, I'm getting the following error-
>> failure)
>> Thanks and regards,
>> Nikita
Re: Integrating BIRT report with a standalone RCP application [message #526020 is a reply to message #525870] Thu, 08 April 2010 10:42 Go to previous messageGo to next message
Nikita,
Download the examples from this link.
http://www.birt-exchange.org/devshare/deploying-birt-reports /1187-eclipsecon-2010-birt-metal-ppt/#description
There is an example of the hello world rcp app that uses the engine and
one that uses the viewer and one that uses the chart engine.
Jason
Nikita wrote:
> Hi Jason,
>> Nikita,
>> Jason
>> Nikita wrote:
>>> Hi,
>>> org.eclipse.ui
>>> failure)
>>> Thanks and regards,
>>> Nikita
Re: Integrating BIRT report with a standalone RCP application [message #526234 is a reply to message #526020] Fri, 09 April 2010 05:58 Go to previous message
Thank you so much for your help Jason... I tried using the runtime 2.3.1
instead of 2.5.2 and its working...
news:hpkpvm$iek$2@build.eclipse.org...
> Nikita,
> Jason
> Nikita wrote:
>> Hi Jason,
>> to integrate this with the RCP application.
>>> Nikita,
>>> Jason
>>> Nikita wrote:
>>>> Hi,
>>>> which does not have BIRT installed. I'm using the BIRT runtime 2.5.2
>>>> for this. The steps I have followed are as follows-
>>>> org.eclipse.ui
>>>> (initialization failure)
>>>> Thanks and regards,
>>>> Nikita
Previous Topic:BIRT is very slow compared to Jasper
Next Topic:integrate BIRT WebViewer in existing web Application works partially
Current Time: Sun Jul 20 23:53:08 EDT 2025
Powered by FUDForum. Page generated in 0.07189 seconds
