Home » Archived » Buckminster » headless builds with groovy
headless builds with groovy [message #525725] |
Wed, 07 April 2010 11:03  |
Originally posted by: ccarpenter.interact911.com
I'm converting a project to use buckminster to do our build, however I am
running into an issue trying to compile groovy when doing a headless
build. I can create the p2 site fine when running inside eclipse as I
have the groovy plugin installed. But I am not able to install the groovy
plugin on buckminster for my headless build, and when I compile the
groovy classes before the build they are removed my the build and I get
an error. Does anyone have any experience doing headless builds with
buckminster and groovy (or any other non-java jvm language)?
Craig
Re: headless builds with groovy [message #525806 is a reply to message #525774] |
Wed, 07 April 2010 16:27   |
Craig,
Please try installing the org.codehaus.groovy17.feature in your headless
buckminster, i.e.
buckminster install http://dist.springsource.org/release/GRECLIPSE/e3.5/
*after* you have done a *regular* Buckminster headless install (i.e. with
Buckminster's headless PDE feature etc.). Do *not* install the
org.codehaus.groovy.eclipse.feature feature, since this has dependencies on
the UI, which leads to the effects you have observed. Also do *not* install
the org.eclipse.jdt feature for the same reason.
If you run into problems installing the org.codehaus.groovy17.feature,
please post the error messages you encounter. We might be able to solve this
by using the p2 director instead of Buckminster's install command.
If it installs fine, try running your build. It might just work :-) If not,
it's probably because the Groovy Eclipse plugin relies on a patch for the
JDT. This patch is built on the regular org.eclipse.jdt feature. We have no
chance of getting this to work within Buckminster headless unless we get
some help from the Groovy-Eclipse folks.
Achim
Craig Carpenter wrote:
> Thanks for the quick response
> On Wed, 07 Apr 2010 18:51:30 +0200, Thomas Hallgren wrote:
>>> am running into an issue trying to compile groovy when doing a headless
>>> groovy plugin on buckminster for my headless build,
>> Why? What issues do you run into?
> I was able to install org.eclipse.rcp and org.eclipse.platform as needed
> by the groovy plugin, however it also requires requires
> org.eclipse.jdt.debug.ui (0.0.0). I tried installing org.eclipse.jdt but
> it conflicts with the PDE headless feature
> $ ./buckminster install http://download.eclipse.org/releases/galileo
> org.eclipse.jdt
> Cannot complete the install because of a conflicting dependency.
> [0]Software being installed: Eclipse Java Development Tools
> 3.5.2.r352_v20100108-7r88FEwFI0WTuoBl0iaG0tyhfZH6
> (org.eclipse.jdt.feature.group
> 3.5.2.r352_v20100108-7r88FEwFI0WTuoBl0iaG0tyhfZH6)
> [0]Software currently installed: Buckminster - PDE support for headless
> operation 1.1.350.r11250
> (org.eclipse.buckminster.pde.headless.feature.feature.group
> 1.1.350.r11250)
> [0]Only one of the following can be installed at once:
> [0.2]Java Development Tools Core 3.5.2.v_981_R35x (org.eclipse.jdt.core
> 3.5.2.v_981_R35x)
> [0.2]Java Development Tools Core 3.5.2.v_980_R35x (org.eclipse.jdt.core
> 3.5.2.v_980_R35x)
> [0.2]Java Development Tools Core 3.5.1.v_972_R35x (org.eclipse.jdt.core
> 3.5.1.v_972_R35x)
> [0]Cannot satisfy dependency:
> [0.2]From: Buckminster - PDE support for headless operation
> 1.1.350.r11250
> 1.1.350.r11250)
> [0.2]To: org.eclipse.jdt.core [3.5.2.v_980_R35x]
> [0.2]From: Eclipse Java Development Tools
> [0.2]To: org.eclipse.jdt.core [3.5.2.v_981_R35x]
>>> an error.
>> Not sure I understand. Why is the build removing things and what kind of
>> error is it?
> As a work around I was attempting to copy the groovy compiled .class
> files into my build directory and then call buckminster build. However my
> Java classes that are importing the groovy classes fail to compile when
> the import cannot be resolved and I can see the groovy .class files are
> no longer in my build directory.
>> Regards,
>> Thomas Hallgren
>>> Does anyone have any experience doing headless builds with buckminster
>>> Thanks,
>>> Craig
> Perhaps I can use the cspex to achieve what I need? I am still new to
> buckminster. Thanks for your help.
> Craig
Re: headless builds with groovy [message #525814 is a reply to message #525806] |
Wed, 07 April 2010 16:58   |
Hi Achim,
Thanks for the suggestion. I received this message when installing
org.codehaus.groovy17.feature :
Cannot complete the install because one or more required items could not
be found.
[0]Software being installed: Groovy Compiler 1.7.0 Feature
2.0.1.20100319-1100-e35-RELEASE
(org.codehaus.groovy17.feature.feature.group 2.0.1.20100319-1100-e35-
RELEASE)
[0]Missing requirement: Groovy Compiler 1.7.0 Feature 2.0.1.20100319-1100-
e35-RELEASE (org.codehaus.groovy17.feature.feature.group
2.0.1.20100319-1100-e35-RELEASE) requires
'org.eclipse.equinox.p2.metadata.generator 1.0.100' but it could not be
found
Which I found in org.eclipse.equinox.p2.user.ui. I was able to install
that feature without errors so I tried org.codehaus.groovy17.feature
again and received
be found.
RELEASE)
[0]Missing requirement: Groovy Runtime Plug-in 1.7.0.20100319-1100-e35-
RELEASE (org.codehaus.groovy 1.7.0.20100319-1100-e35-RELEASE) requires
'bundle org.junit 0.0.0' but it could not be found
[0.2]From: Groovy Compiler 1.7.0 Feature 2.0.1.20100319-1100-e35-RELEASE
RELEASE)
[0.2]To: org.codehaus.groovy [1.7.0.20100319-1100-e35-RELEASE]
Which I believe would require org.eclipse.jdt or is there another way to
get org.junit without jdt? Thank you for your help.
Craig
On Wed, 07 Apr 2010 22:27:25 +0200, Achim Demelt wrote:
> Craig,
> buckminster, i.e.
> with Buckminster's headless PDE feature etc.). Do *not* install the
> on the UI, which leads to the effects you have observed. Also do *not*
> install the org.eclipse.jdt feature for the same reason.
> this by using the p2 director instead of Buckminster's install command.
> not, it's probably because the Groovy Eclipse plugin relies on a patch
> for the JDT. This patch is built on the regular org.eclipse.jdt feature.
> We have no chance of getting this to work within Buckminster headless
> unless we get some help from the Groovy-Eclipse folks.
> Achim
>>>> I am running into an issue trying to compile groovy when doing a
>>>> headless build. I can create the p2 site fine when running inside
>>>> eclipse as I have the groovy plugin installed. But I am not able to
>>>> install the groovy plugin on buckminster for my headless build,
>> needed by the groovy plugin, however it also requires requires
>> but it conflicts with the PDE headless feature
>> org.eclipse.jdt
>> 3.5.2.r352_v20100108-7r88FEwFI0WTuoBl0iaG0tyhfZH6) [0]Software
>> currently installed: Buckminster - PDE support for headless operation
>> 1.1.350.r11250
>> 1.1.350.r11250)
>> [0]Only one of the following can be installed at once: [0.2]Java
>> 3.5.2.v_981_R35x)
>> 3.5.2.v_980_R35x)
>> 3.5.1.v_972_R35x)
>> 1.1.350.r11250
>> 1.1.350.r11250)
>> [0.2]To: org.eclipse.jdt.core [3.5.2.v_980_R35x] [0]Cannot satisfy
>> dependency:
>> 3.5.2.r352_v20100108-7r88FEwFI0WTuoBl0iaG0tyhfZH6) [0.2]To:
>>>> get an error.
>>> of error is it?
>> my Java classes that are importing the groovy classes fail to compile
>> when the import cannot be resolved and I can see the groovy .class
>> files are no longer in my build directory.
>>> Regards,
>>> Thomas Hallgren
>>>> Thanks,
>>>> Craig
>> Craig
Re: headless builds with groovy [message #526149 is a reply to message #525873] |
Thu, 08 April 2010 19:14   |
I'm one of the Groovy-Eclipse developers and I'm just chiming in. Three things:
1. the p2 dependencies are optional. They are marked as such in the org.codehaus.groovy bundle, but not so in the org.codehaus.groovy17 feature (I don't think there is a way to mark required bundles as optional in the feature, but if I'm wrong, let me know).
2. Rather than installing the feature, you could install the bundle directly using the p2 director app (this is possible and not too difficult using a headless build).
3. However, neither of these is important since if you want to build groovy bundles headless, you need the patched JDT compiler installed in your build eclipse. You need the patched org.eclipse.jdt.core bundle, the org.eclipse.jdt.groovy.core bundle, and the org.codehaus.groovy.eclipse.core bundle.
If it is possible to install bundles, rather than features in buckminster, this may be possible. There may be some changes that we need to put in to get this working and if you let me know what they are, I might be able to help.
[Updated on: Thu, 08 April 2010 19:19] by Moderator
Re: headless builds with groovy [message #526322 is a reply to message #526149] |
Fri, 09 April 2010 12:06   |
Andrew,
Thanks for joining the conversation. Your input is extremely helpful and
very much appreciated!
As far as I can see we'll have to provide a special feature patch for
Buckminster's PDE/JDT feature, very similar to what you're doing for the
regular org.eclipse.jdt feature. I _may_ find some time over the weekend to
do this. If not, I'm afraid it'll have to wait until Friday next week or so.
Apart from the JDT patch, what would you say is the minimum set of bundles
that is required for using the Groovy builder in a headless environment? Is
it org.codehaus.groovy plus all its (transitive) dependencies?
Achim
Andrew Eisenberg wrote:
> I'm one of the Groovy-Eclipse developers and I'm just chiming in. Two
> things:
> in the feature, but if I'm wrong, let me know). 2. Rather than installing
Re: headless builds with groovy [message #529170 is a reply to message #526796] |
Fri, 23 April 2010 05:05   |
Hi Andrew,
I've finally found time to give your 3.6 distribution a try. I tried putting
together a headless feature containing the plug-ins you mentioned, i.e.
* org.codehaus.groovy
* org.codehaus.groovy.eclipse.core
* org.eclipse.jdt.groovy.core
* org.eclipse.jdt.core (our patched version)
I chose *not* to use a feature patch, because we typically don't install
features in our headless Buckminster, so simply providing the new (patched)
version of jdt.core should be sufficient.
However, I did not succeed in installing the feature because the Groovy
plug-ins have dependencies on UI bundles. We can't satisfy these
dependencies in a headless environment. These are the "culprits":
* o.c.groovy.eclipse.core depends on o.e.jface.text
* o.e.jdt.groovy.core depends on o.e.ui
I did not analyze the code if these dependencies are in fact required or if
they're just oversights in the MANIFEST. I'd greatly appreciate if you could
take a look at that.
Moreover, would it be possible that you provided that headless feature on
your p2 site? If not, I fear we'll have logistical problems when building
our own site. That's because our regular features must include the vanilla
o.e.jdt bundle, whereas the Groovy feature requires the patched version.
We'd need separate builds that operate on separate target platforms to
accommodate this. Opposed to that, I believe it would be very easy to
include that feature in your builds, since you already have the patched
o.e.jdt version, anyway.
That said, I can work around that problem for now. The most pressing issue
is the UI dependencies. Once that's solved, we can tackle the problem of
provisioning the feature.
Achim
> Initial drop of 3.6 support is available here:
http://dist.codehaus.org/groovy/distributions/greclipse/snap shot/e3.6/groovy-
update-site-e36.zip
> Download and point your p2 update manager to install. Or, if you are
> using the director app, then download, unzip and point the p2 director to
> the unzipped location.
> Let me know if this works for you.
Current Time: Sat Sep 20 18:02:58 EDT 2025
Powered by FUDForum. Page generated in 0.06210 seconds
