Home » Modeling » M2T (model-to-text transformation) » [Xtend] Wrong parameter type
[Xtend] Wrong parameter type [message #525412] Tue, 06 April 2010 10:21 Go to next message
Still trying my m2m transformation with Xtend, I get a problem with types.
import metamodel;
import relationnel;
extension metamodel::Extensions reexport;
extension object2relationnal::SQLExtensions reexport;
//takes a Package as parameter, and creating a Database from it
create relationnel::Base transform (metamodel::Package p) :
this.setTables(p.classes().createTable());
// transforms all classes into SQL tables
create relationnel::Table createTable (metamodel::Class c) :
this.setName(c.name) ->
this.setColumn(c.attributs().createColumn());
// create a Column for every attribute which is not a composition or agregation
create relationnel::Column createColumn(metamodel::Attribute a) :
this.setName(a.name) ->
this.setType(a.type.name);
On last line, I get "couldn't find operation 'setType(String)' for type 'relationnel::Column'
But type is an Eattribute of Column, points to Type (abstract), which is either a Domain or a Datatype.
All of those types have only one Eattribute, called name, of type EString (inherited).
So what is wrong ?
Re: [Xtend] Wrong parameter type [message #525438 is a reply to message #525412] Tue, 06 April 2010 11:04 Go to previous messageGo to next message
An EAttribute cannot refer to an EClass, only to EDatatype. If you have the need to refer to another type then ise an EReference instead of EAttribute.
So 'type' in Column should rather be an EReference.
HTH,
~Karsten
icon9.gif  Re: [Xtend] Wrong parameter type [message #525598 is a reply to message #525412] Wed, 07 April 2010 02:21 Go to previous messageGo to next message
I'm sorry, I made a dumb mistake writing my former post, type is a EReference, and references Type, it's not a EAttribute.
That is the complete message I get running the workflow.
0    INFO  WorkflowRunner     - --------------------------------------------------------------------------------------
0    INFO  WorkflowRunner     - EMF Modeling Workflow Engine 0.7.2, Build v200908120417
0    INFO  WorkflowRunner     - (c) 2005-2009 openarchitectureware.org and contributors
0    INFO  WorkflowRunner     - running workflow: C:/Documents and Settings/Lecourt/workspace/genCPP/src/object2relationnal/m2m.mwe
281  INFO  StandaloneSetup    - Registering platform uri 'C:\Documents and Settings\Lecourt\workspace'
390  INFO  StandaloneSetup    - Adding dynamic EPackage 'http://www.example.org/metamodel' from 'platform:/resource/genCPP/src/metamodel/metamodel.ecore'
390  INFO  StandaloneSetup    - Adding dynamic EPackage 'http://relationnel/1.0' from 'platform:/resource/genCPP/src/metamodel/relationnel.ecore'
484  INFO  CompositeComponent - Reader: Loading model from src/Model.xmi
500  INFO  CompositeComponent - XtendComponent: executing 'object2relationnal::object2relationnal'
812  ERROR AbstractExpressionsUsingWorkflowComponent - Error in Component  of type org.eclipse.xtend.XtendComponent:
	EvaluationException : Couldn't find operation 'setType(String)' for relationnel::Column.
	object2relationnal::object2relationnal.ext[671,25] on line 19 'this.setType(a.type.name)'
	object2relationnal::object2relationnal.ext[462,28] on line 14 'c.attributs().createColumn()'
	object2relationnal::object2relationnal.ext[284,25] on line 9 'p.classes().createTable()'
	nofile[0,16] on line 1 'transform(model)'
812  ERROR WorkflowRunner     - Workflow interrupted. Reason: Couldn't find operation 'setType(String)' for relationnel::Column.
812  ERROR WorkflowRunner     - [ERROR]: Couldn't find operation 'setType(String)' for relationnel::Column.(Element: this.setType(a.type.name); Reported by: XtendComponent: executing 'object2relationnal::object2relationnal')
812  ERROR WorkflowRunner     - [ERROR]: Couldn't find operation 'setType(String)' for relationnel::Column.(Element: this.setName(a.name)->this.setType(a.type.name); Reported by: XtendComponent: executing 'object2relationnal::object2relationnal')
812  ERROR WorkflowRunner     - [ERROR]: Couldn't find operation 'setType(String)' for relationnel::Column.(Element: c.attributs().createColumn(); Reported by: XtendComponent: executing 'object2relationnal::object2relationnal')
812  ERROR WorkflowRunner     - [ERROR]: Couldn't find operation 'setType(String)' for relationnel::Column.(Element: this.setColumn(c.attributs().createColumn()); Reported by: XtendComponent: executing 'object2relationnal::object2relationnal')
812  ERROR WorkflowRunner     - [ERROR]: Couldn't find operation 'setType(String)' for relationnel::Column.(Element: this.setName(c.name)->this.setColumn(c.attributs().createColumn()); Reported by: XtendComponent: executing 'object2relationnal::object2relationnal')
812  ERROR WorkflowRunner     - [ERROR]: Couldn't find operation 'setType(String)' for relationnel::Column.(Element: p.classes().createTable(); Reported by: XtendComponent: executing 'object2relationnal::object2relationnal')
812  ERROR WorkflowRunner     - [ERROR]: Couldn't find operation 'setType(String)' for relationnel::Column.(Element: this.setTables(p.classes().createTable()); Reported by: XtendComponent: executing 'object2relationnal::object2relationnal')
812  ERROR WorkflowRunner     - [ERROR]: Couldn't find operation 'setType(String)' for relationnel::Column.(Element: transform(model); Reported by: XtendComponent: executing 'object2relationnal::object2relationnal')
Weirdly, since yesterday, when running the workflow messages are in black and no more in red, and are displayed differently than before.
Re: [Xtend] Wrong parameter type [message #525606 is a reply to message #525598] Wed, 07 April 2010 03:25 Go to previous messageGo to next message
Hello, when type is a reference to a Type, why do you call setType with a String?
[Updated on: Wed, 07 April 2010 03:26] by Moderator
Re: [Xtend] Wrong parameter type [message #525610 is a reply to message #525606] Wed, 07 April 2010 03:47 Go to previous message
I'm only interested in the name of the type.
To simplify modelisation, I created types in my source metamodel (GBool, GInteger, and so on), but I don't need that in my destination model, which I want to use to generate SQL. I only need the name, and with Xpand I'll print the according SQL type in my sql file.
Do you think I should modify my metamodel and have the EReference Type become a EAttribute (which would be a GString) ?
I thought I could just map the types from my source model into a generic Datatype, using type (the EReference) to keep the type, and name to keep (obviously) the name.
So having a GBool called isActive in my source model, in destination model I would get a Column, of type GBool, of name isActive, and I would use that in Xpand to generate my sql file.
I guess I understand where the problem lies, GBool doesn't exist as a type in my destination metamodel. As Type is abstract, and can be a Datatype, or a Domain, I have to think about it again.
Re: [Xtend] Wrong parameter type [message #525615 is a reply to message #525598] Wed, 07 April 2010 03:11 Go to previous message
So you can't set a string, because a Type is expected.
But "this.setType(a.type.name)" sets the type's name not the type.
Sven
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Previous Topic:xpand, xtend help
Next Topic:Workflow Javadoc ?
Current Time: Wed Jul 30 21:24:05 EDT 2025
Powered by FUDForum. Page generated in 0.06674 seconds
