Home » Modeling » Amalgam » Unable to install DSL Toolkit
Unable to install DSL Toolkit [message #525187] Wed, 01 July 2009 16:54 Go to next message
I am running Galileo and trying to follow some examples in the book,
"eclipse Modeling Project: A Domain-Specific Language (DSL) Toolkit".
As part of that, I'm trying to install the DSL Toolkit from the Amalgam
project, but I get the following error:
Cannot complete the install because one or more required items could not
be found.
Software being installed: DSL Toolkit 1.0.0.v200905210858
(org.eclipse.amalgam.dsltk.product 1.0.0.v200905210858)
Missing requirement for filter
(&(osgi.os=linux)(osgi.ws=gtk)(osgi.arch=x86_64)): Eclipse RCP
3.5.0.v20090506-9SA-FwxFtqHA7O_ZPyAv-cGC (org.eclipse.rcp.feature.group
3.5.0.v20090506-9SA-FwxFtqHA7O_ZPyAv-cGC) requires
'org.eclipse.swt.gtk.linux.x86_64 [3.5.0.v3548c]' but it could not be found
Cannot satisfy dependency:
To: org.eclipse.platform.feature.group
[3.5.0.v20090513-9fEdG1HFtGcZlCVLSVqmsTcdv4RgTlPeD]
(org.eclipse.platform.feature.group
3.5.0.v20090513-9fEdG1HFtGcZlCVLSVqmsTcdv4RgTlPeD)
To: org.eclipse.rcp.feature.group
[3.5.0.v20090506-9SA-FwxFtqHA7O_ZPyAv-cGC]
Please be aware that I am running on ubuntu 9.04 AMD64 and have eclipse
for Linux 64-bit installed. I'm also a newbie to eclipse, so if that's
part of the problem, then some detail on how to correct the problem would
be much appreciated.
Many thanks, both for the solution, and your patience!
Re: Unable to install DSL Toolkit [message #525188 is a reply to message #525187] Wed, 01 July 2009 16:58 Go to previous messageGo to next message
If you're following the book, you should use the Ganymede edition:
http://download.eclipse.org/modeling/amalgam/dsltk/downloads /drops/I20081128
-0606/index.php
Unfortunately, there is no 64 bit version for Linux. I have built one for
M8 based on Galileo, but it's not promoted yet.
Best,
Rich
On 7/1/09 4:54 PM, in article
dd872609a93892e1ab06a84c944419bc$1@www.eclipse.org, "Flavelle Ballem"
> be found.
> From: DSL Toolkit 1.0.0.v200905210858
> From: Eclipse Platform
Rich
Re: Unable to install DSL Toolkit [message #525189 is a reply to message #525188] Wed, 01 July 2009 19:25 Go to previous messageGo to next message
> -0606/index.php
> Best,
> Rich
Rich:
I'm sorry, I am new to eclipse. Could you please tell me what M8 is? Is
there anyway that I could get a preview of the new code - happy to be the
tester. I have found advantages to staying with the 64-bit environment for
my applications, and I gather that 32-bit and 64-bit plugins don't mix
well.
Many thanks,
Flavelle
Re: Unable to install DSL Toolkit [message #525190 is a reply to message #525189] Wed, 01 July 2009 20:13 Go to previous messageGo to next message
Rich:
A small further thought - is there a different approach using existing
Galileo components that will allow me to proceed further with your book?
Flavelle
Re: Unable to install DSL Toolkit [message #525191 is a reply to message #525189] Thu, 02 July 2009 06:39 Go to previous messageGo to next message
M8 = Milestone 8
You can try the linux x86_64 download of the Modeling package from EPP:
http://www.eclipse.org/epp/download.php It contains most of what's in the
Amalgam DSL Toolkit, less some UI elements.
There are some differences in the Galileo version of the modeling
components, as compared to the Ganymede version the book is based on.
Mostly, things should work, but the solutions are not yet updated. The main
thing to do is replace references to the "legacy" Xpand model-to-text engine
with the new one in GMF that uses OCL and QVTO.
Best,
Rich
On 7/1/09 7:25 PM, in article
c52a18f8944b602a7a8b198ffbd46ea4$1@www.eclipse.org, "Flavelle Ballem"
>> -0606/index.php
>> Best,
>> Rich
> Rich:
> well.
> Many thanks,
> Flavelle
Rich
Re: Unable to install DSL Toolkit [message #525192 is a reply to message #525190] Thu, 02 July 2009 06:39 Go to previous messageGo to next message
See previous reply...
On 7/1/09 8:13 PM, in article
5399f1a4c1330b270649662a7bfc47b8$1@www.eclipse.org, "Flavelle Ballem"
> Rich:
> Flavelle
Rich
Re: Unable to install DSL Toolkit [message #525193 is a reply to message #525191] Thu, 02 July 2009 07:26 Go to previous message
Rich:
Thanks so much - I'll give these a try!
Flavelle
Re: Unable to install DSL Toolkit [message #577362 is a reply to message #525187] Wed, 01 July 2009 16:58 Go to previous message
-0606/index.php
Best,
Rich
> be found.
Rich
Re: Unable to install DSL Toolkit [message #577380 is a reply to message #525188] Wed, 01 July 2009 19:25 Go to previous message
> -0606/index.php
> Best,
> Rich
Rich:
well.
Many thanks,
Flavelle
Re: Unable to install DSL Toolkit [message #577400 is a reply to message #525189] Wed, 01 July 2009 20:13 Go to previous message
Rich:
Flavelle
Re: Unable to install DSL Toolkit [message #577418 is a reply to message #525189] Thu, 02 July 2009 06:39 Go to previous message
M8 = Milestone 8
Best,
Rich
>> -0606/index.php
>> Best,
>> Rich
> Rich:
> well.
> Many thanks,
> Flavelle
Rich
Re: Unable to install DSL Toolkit [message #577438 is a reply to message #525190] Thu, 02 July 2009 06:39 Go to previous message
> Rich:
> Flavelle
Rich
Re: Unable to install DSL Toolkit [message #577457 is a reply to message #525191] Thu, 02 July 2009 07:26 Go to previous message
Rich:
Flavelle
Previous Topic:Unable to install DSL Toolkit
Next Topic:DSL Book - problems with java code pg 81
Current Time: Sat Jul 26 21:21:38 EDT 2025
Powered by FUDForum. Page generated in 0.05303 seconds
