Home » Modeling » Amalgam » couple of useability questions
couple of useability questions [message #525126] |
Tue, 21 April 2009 11:41  |
I've just started using amalgam and I like it.
I have previously used a commercial GMF based tool & the vanilla
Eclipse. I liked the commercial product but it seems that amalgam gives
a bit better low level support ie creation of gmfmap and generator
models when doing complex things.
I noticed that when I create a gmfmap diagram that my DSL attributes are
not automatically created unlike in commercial tools. This may be a bit
of a pain if I need to recreate the file. Is there an easier way of
doing adding attributes?
Also I note that if I make changes to the gmfmap etc, the gmfgen doesn't
seem to be updated automatically. Is there a way of ensuring my
gmfgen is updated?
I had a look but I didn't notice a way of creating figure gallery (as
found in the commercial tools - does this exist? I'm thinking of the
ability to set RGB colours etc ;)
regards
Steve
Re: couple of useability questions [message #525127 is a reply to message #525126] |
Tue, 21 April 2009 11:59   |
Hi Steve (or is it Bill?),
If I'm thinking of the right commercial product you're referring to, and I
think I am, I've tried to answer your questions below...
Best,
Rich
On 4/21/09 11:41 AM, in article gskpfh$1lo$1@build.eclipse.org, "Bill Hinge"
<steve.orobec@btopenworld.com> wrote:
> Hi
Well, the commercial tool provided the same capabilities, though hidden by
default.
Not really. Aside from the wizard provided by GMF, there is nothing more
related to this in Amalgam.
> gmfgen is updated?
Sorry, that's another commercial-only feature. You'll need to manually
regenerate the gmfgen from the gmfmap when you make changes.
Sorry again, the concept of a figure gallery is also commercial-only.
Really, it's just a fancy gmfgraph editor.
> regards
> Steve
Rich
Re: couple of useability questions [message #525128 is a reply to message #525127] |
Tue, 21 April 2009 12:37   |
Hi Rich
Yes it is Steve (Bill Hinge is a web alias I often use - I was born in a
place called Billinge ;-). Still pushing the case for GMF and seem to be
making progress
Thanks for the quick responses.
I tried to import across into the commercial product (am I allowed to
mention it ?) but I had a few inconsistencies. I've normally stuck with
the default wizard settings but I have tried several of the features.
I may try again next week if I have more time but the manual method
on amalgam seems to be working. There is a crude satisfaction in doing
everything manually though ;)
I may have some other questions later on if you don't mind. I split my
DSL into several ecore files and I'm using references to UML and Ecore
plugins etc. So far I've created a couple of gmf editors based on two of
the ecores so I think I'm getting a feel for how things may work.
I've now got a paper copy of your book to work from so that should help.
regards
Steve
> Best,
> Rich
>> Hi
> default.
>> gmfgen is updated?
>> regards
>> Steve
Re: couple of useability questions [message #525129 is a reply to message #525127] |
Hi Rich
making progress
regards
Steve
> Best,
> Rich
>> Hi
> default.
>> gmfgen is updated?
>> regards
>> Steve
Re: couple of useability questions [message #562502 is a reply to message #525126] |
Best,
Rich
> Hi
default.
> gmfgen is updated?
> regards
> Steve
Rich
Re: couple of useability questions [message #562523 is a reply to message #525127] |
Hi Rich
making progress
regards
Steve
> Best,
> Rich
>> Hi
> default.
>> gmfgen is updated?
>> regards
>> Steve
Re: couple of useability questions [message #562548 is a reply to message #525127] |
Hi Rich
making progress
regards
Steve
> Best,
> Rich
>> Hi
> default.
>> gmfgen is updated?
>> regards
>> Steve
Current Time: Sun Jul 27 06:39:51 EDT 2025
Powered by FUDForum. Page generated in 0.03556 seconds
