Home » Eclipse Projects » Remote Application Platform (RAP) » Browser.setUrl(Str) does not work with local files(Browser.setUrl(Str) does not work with local files)
Browser.setUrl(Str) does not work with local files [message #525013] Mon, 05 April 2010 06:43 Go to next message
On contrary to SWT, Browser.setUrl(Str) does not work with local file URLS (file:///C.... ). I need to display a html file generated by jasper reports but the browser does not seem to accept the file:/// url. I have tried all options (e.g. without file: , with \\ etc) and checked all the security issues. The method returns true even if i specify a wrong path. The result is always a blank / nothing page.
I added a location listener which correctly passes the url in the event.
Any ideas?
Re: Browser.setUrl(Str) does not work with local files [message #525288 is a reply to message #525013] Tue, 06 April 2010 02:15 Go to previous messageGo to next message
Hi, you can register the generated file(s) as resources at the
HttpService and then pass a relative URL to the Browser widget.
Stefan.
> URLS (file:///C... ). I need to display a html file generated by jasper
> Any ideas?
Re: Browser.setUrl(Str) does not work with local files [message #525310 is a reply to message #525013] Tue, 06 April 2010 03:56 Go to previous message
file URLs do not work for a good reason. A website is not allowed to
access resources from the client's file system. If you're trying to
access a file on the server, you need to make it available via HTTP, as
Stefan suggested.
Best regards, Ralf
> Any ideas?
Previous Topic:Question about some proposed features' plan in RAP 1.3
Next Topic:[ANN] Slides from my EclipseCon Talk are Available
Current Time: Sat Jul 19 00:11:21 EDT 2025
Powered by FUDForum. Page generated in 0.15761 seconds
