Home » Archived » M2M (model-to-model transformation) » [QVTo] Standalone transformation
[QVTo] Standalone transformation [message #524713] Thu, 01 April 2010 20:15 Go to next message
Hi all,
I've been working on a transformation for quite some time, it is finally finished. Now I would like to write a Java program that transforms any input-model to an output model by using my transform.qvto file.
I read somewhere on the Forums this should be possible. I looked at a few pages:
http://wiki.eclipse.org/QVTOML/Examples/InvokeInJava
http://wiki.eclipse.org/index.php/EMF-FAQ#How_do_I_use_EMF_i n_standalone_applications_.28such_as_an_ordinary_main.29.3F
My knowledge about Java is very basic: I just use a text editor like notepad to write simple main-classes and compile them with javac in a terminal.
From the above links I understood I have to include several Jar files:
org.eclipse.emf.ecore_2.6.0.v200912121603.jar
org.eclipse.emf.common_2.6.0.v200912121603.jar
org.eclipse.emf.ecore.xmi_2.5.0.v200912121603.jar
net.sourceforge.lpg.lpgjavaruntime_1.1.0.v200803061910.jar
org.eclipse.ocl_3.0.0.v200912161120.jar
org.eclipse.ocl.ecore_3.0.0.v200912161120.jar
-- QVTo jars ----------
org.eclipse.m2m.qvt.oml
org.eclipse.m2m.qvt.oml.common
org.eclipse.m2m.qvt.oml.cst.parser
org.eclipse.m2m.qvt.oml.emf.util
org.eclipse.m2m.qvt.oml.ecore.imperativeocl
However, my ecore.jar version is "org.eclipse.emf.ecore_2.5.0.v200906151043.jar" (I just updated Eclipse by clicking Help -> Check for Updates)?
Furthermore, how can I include those files? When I use "import ...jar" it doesn't work.
Next, I could write the transformation call by using the TransformationExecutor class. I have to refer to the qvto file and specify locations for input- and output files. Is it possible to parametrize this information? I would like to be able to use arguments in the terminal and specify which input model to use.
Finally the used meta-models must be registered in some way, but I don't understand how I should do this.
I hope somebody can provide me with a basic example and some explanation Smile
Re: [QVTo] Standalone transformation [message #524950 is a reply to message #524713] Sun, 04 April 2010 13:00 Go to previous messageGo to next message
Hi PBarendrecht ,
Comments are in-lined below.
Sergey.
PBarendrecht wrote:
> Hi all,
> few pages:
> terminal.
> Quote:
You have mixed up two different topics - (1) running QVTo transformation
as standalone application and (2) ordinary execution of QVTo
transformation from Java source.
I suppose your case is (2). Then you should create Java plug-in in your
Eclipse workspace and put Java code for QVTo invocation (mentioned in
http://wiki.eclipse.org/QVTOML/Examples/InvokeInJava) in some Java method.
As I already wrote to you in email there's perfect complete example of
such task in "org.eclipse.m2m.qvt.oml.econ2009.tutorial" plug-in.
Eclipse CVS:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.qvtoml/examples/org.eclipse.m2m.qvt.oml.econ2009.tu torial/?root=Modeling_Project
Handy way for using that tutorial:
- check out tutorial plug-in from CVS to workspace
- launch new Eclipse instance
- call "New Other.." (Ctrl+N) wizard and browse for "QVT Operationl
EclipseCon2009 Tutorial" located in "QVT Operational Tutorials" folder
> it doesn't work.
Yes, it's possible. Try the sample from
"org.eclipse.m2m.qvt.oml.econ2009.tutorial".
Just create your metamodel and generate Java-code for it. Then in new
Eclipse instance it'll be accessible just like Ecore or UML models.
> I hope somebody can provide me with a basic example and some explanation :)
Re: [QVTo] Standalone transformation [message #525239 is a reply to message #524950] Mon, 05 April 2010 15:28 Go to previous messageGo to next message
Hi Sergey,
Thanks for your reply. I completely overlooked the part about Java in your e-mail, I'm sorry.
I'm not sure how I should use the mentioned plug-in. When I create a .editor of an own model in Eclipse, I can right-click it and choose "Run As -> Eclipse Application". However, when I right-click the tutorial directory or any subdirectory, this option isn't available, neither is it in the "new -> Other" window.
Furthermore, I'm not sure I understand the difference between the Java plug-in and a standalone. Isn't it possible to create a standalone Java application (by including the used JAR files)?
The intention is that I can use the terminal to transform models conforming to a certain meta-model, for example like this:
java -jar Transform.jar -t MyTransformation.qvto -i inputmodel -o outputmodel -p parameter1=value,parameter2=value
I know I have to include the meta-models in some kind of Java format, but it would be nice to have a "flexible transformation (qvto) file", i.e. the possibility to slightly change the transformation (but of course still use the same included meta-models).
Is this possible?
[Updated on: Mon, 05 April 2010 15:33] by Moderator
Re: [QVTo] Standalone transformation [message #559447 is a reply to message #525239] Thu, 16 September 2010 11:58 Go to previous messageGo to next message
Hi PBarendrecht ,
If you have not given up, I hope that I can give you some clue
You just need to create a new Eclipse plugin project, say HelloWorld. Some examples:
http://www.eclipse.org/articles/Article-Your%20First%20Plug- in/YourFirstPlugin.html
http://www.ibm.com/developerworks/library/os-ecplug/
Then, use some part of the code in qvto.ecore2uml.invoke of "org.eclipse.m2m.qvt.oml.econ2009.tutorial", for using TransformationExecutor
Run your edited HelloWorld eclipse plugin
I think it is necessary to create an Eclipse plugin in order to use the TransformationExecutor because the URIs of your local files can only be referred to in runtim of an Eclipse plugin
Hope that helps
Re: [QVTo] Standalone transformation [message #723005 is a reply to message #559447] Wed, 07 September 2011 08:14 Go to previous message
Hey have you got the solution of this problem? could you give me some clue if so? i have been trapped by this for several days:(
Previous Topic:[ATL]: how do you debug you transformations
Next Topic:[QVT] Replacing entities in a transformation
Current Time: Sat Jul 19 09:20:30 EDT 2025
Powered by FUDForum. Page generated in 0.04464 seconds
