Home » Eclipse Projects » EclipseLink » strange behaviour(JavaSE app)
strange behaviour [message #524782] Fri, 02 April 2010 09:20 Go to next message
Hi !
I am running this code:
public class Test {
        Persistence.createEntityManagerFactory("MyPersistenceUnit");
Then the environemnt outputs (near exactly):
run-single:
2010-4-2 0:35:05 javax.persistence.spi.PersistenceProviderResolverHolder$DefaultPersistenceProviderResolver log�
WARNING: javax.persistence.spi::No valid providers found using:�
WARNING: javax.persistence.spi::潲朮散汩灳攮灥牳楳瑥湣攮橰愮健牳楳瑥湣敐牯癩摥�
 - jar:file:/D:/NetBeans/java3/modules/ext/eclipselink/eclipselink-2.0.0.jar!/META-INF/services/javax.persistence.spi.PersistenceProvider�
 - jar:file:/D:/Java/project%20workspace/Identity/dist/lib/eclipselink-2.0.0.jar!/META-INF/services/javax.persistence.spi.PersistenceProvider�
 - jar:file:/D:/Java/project%20workspace/Utilities/dist/lib/eclipselink-2.0.0.jar!/META-INF/services/javax.persistence.spi.PersistenceProvider�
Exception in thread "main" javax.persistence.PersistenceException: No Persistence provider for EntityManager named MyPersistenceUnit�
Java Result: 1
BUILD SUCCESSFUL (total time: 0 seconds)
Whats going on ?
I am using Netbeans 6.8.
Thanks !
[Updated on: Fri, 02 April 2010 09:22] by Moderator
Re: strange behaviour [message #524797 is a reply to message #524782] Fri, 02 April 2010 10:40 Go to previous messageGo to next message
how looks your persistence.xml?
IMO a minimum version of a persistence.xml is needed, e.g.:
<?xml version="1.0" encoding="utf-8"?>
<persistence xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
  xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_2_0.xsd"
  version="2.0" xmlns="http://java.sun.com/xml/ns/persistence">
  <persistence-unit name="MyPersistenceUnit" transaction-type="RESOURCE_LOCAL">
    <provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
    <exclude-unlisted-classes>false</exclude-unlisted-classes>
  </persistence-unit>
</persistence>
From now you can configure all in your java code or using the xml feature.
Hope this helps.
Best regards
Christian
[Updated on: Fri, 02 April 2010 10:40] by Moderator
Re: strange behaviour [message #524851 is a reply to message #524797] Fri, 02 April 2010 19:29 Go to previous messageGo to next message
Yes, the "error" appears provided the persistence.xml is present.
An interesting fact is that my code runs when in testcase and not in the main source code place.
E.g.
(in test case code)
void test(){
    MainClass.main(null);
Note that the MainClass here corresponds to Test in the code from my last post.
[Updated on: Fri, 02 April 2010 19:30] by Moderator
Re: strange behaviour [message #525326 is a reply to message #524851] Tue, 06 April 2010 05:01 Go to previous messageGo to next message
Are your tests and main sources in different jar files? If so, maybe the persistence.xml is present in the "test.jar" but not in the "main-src.jar".
all the best,
Christian
Re: strange behaviour [message #525704 is a reply to message #524782] Wed, 07 April 2010 09:58 Go to previous message
It is.
I am using spring framework, is this a factor anyway?
Previous Topic:Cannot merge entity when there is other entity extends
Next Topic:New with JPA
Current Time: Sat Jul 26 01:14:29 EDT 2025
Powered by FUDForum. Page generated in 0.58262 seconds
