Home » Eclipse Projects » GEF » Left Upper Context Menu Location(Left Upper Context Menu Location)
Left Upper Context Menu Location [message #524541] Thu, 01 April 2010 06:53 Go to next message
Hello, my name is Federico. I am implementing a GUI .I need to get the left upper Context menu Location.
My problem is the following: When I press the right mouse button, the contextual menu is dispalyed, after that the user is able to create several kind of objects, when the user pick in a particular option a new object must appear in the position where the user has pressed the right button.
I hope you can undertand my problem and someone can help me.
Thank you in advance!
Federico.-
Re: Left Upper Context Menu Location [message #524588 is a reply to message #524541] Thu, 01 April 2010 05:32 Go to previous messageGo to next message
> button.
> Federico.-
Hi Frederico,
you're in luck. I implemented this only yesterday...
In my Graphical Editor I added a listener for context menu clicks:
final GraphicalViewer viewer = getGraphicalViewer();
viewer.getControl().addMenuDetectListener(new MenuDetectListener() {
public void menuDetected(MenuDetectEvent e) {
Point pt = viewer.getControl().toControl(e.x, e.y);
// Do something with pt...
You must then use the x,y points in pt for your creation command.
Phil
Re: Left Upper Context Menu Location [message #524764 is a reply to message #524588] Fri, 02 April 2010 07:38 Go to previous messageGo to next message
Hello Phil,
Thank you for your help.
Please forgive me for my novice ignorance but when you say :
What is supposed I must do there?
In addition, I have not clear how to acced to the point captured for the event from the CreateCommand class.
If you could help me It would be great!
Thank you!
Federico
Re: Left Upper Context Menu Location [message #524776 is a reply to message #524764] Fri, 02 April 2010 04:14 Go to previous messageGo to next message
On 02/04/2010 12:38, fededobals@hotmail.com wrote:
> Hello Phil,
> Thank you!
> Federico
Point pt has x and y properties, pt.x and pt.y. You need to send these
x,y co-ordinates to your Menu Action which will create the Command.
Assuming you declare your Action in your GEF Editor you could set the
x,y position in your action. I use it in a "Paste" Action like this:
PasteAction action =
(PasteAction)getActionRegistry().getAction(ActionFactory.PAS TE.getId());
action.setMouseClickPosition(pt.x, pt.y);
Re: Left Upper Context Menu Location [message #524777 is a reply to message #524776] Fri, 02 April 2010 04:14 Go to previous messageGo to next message
>> Hello Phil,
>> Thank you!
>> Federico
> Hello,
Another way to do it would be to let your Action have access to the
GraphicalViewer and let it be the MenuDetectListener
Re: Left Upper Context Menu Location [message #525390 is a reply to message #524776] Tue, 06 April 2010 09:11 Go to previous message
Thank you for your help and time used to explain all these concepts.
It was a great help, finally I understood and the problem was solved. Very Happy
Please, just a last question...Where can I get a good tutorial where explain all these tricky issues about GEF? or Where did you learn all what you explained to me?
Thank you,
Federico
Re: Left Upper Context Menu Location [message #525441 is a reply to message #525390] Tue, 06 April 2010 06:24 Go to previous message
On 06/04/2010 14:11, fededobals@hotmail.com wrote:
> It was a great help, finally I understood and the problem was solved. :d
> Thank you,
> Federico
for me it is achieved through trial and error and looking through all
the GEF examples I can find. I have been thinking for some time about
there should be a Wiki for tips and tricks.
Previous Topic:Icon label parallel to connection
Next Topic:GEF documentation and examples is lacking - we need a GEF WIKI!
Current Time: Thu Jul 24 22:22:03 EDT 2025
Powered by FUDForum. Page generated in 0.09537 seconds
