Loading EPF libraries outside of EPF [message #518177] |
Wed, 03 March 2010 06:12  |
Originally posted by: Patrick.Schoenbach.robustsoft.de
I am to write a program that analyzes EPF libraries and that generates
some reports from these analyzes. Preferably, the program should run
independently from Eclipse?
How can I load the EPF library models? Would it be necessary or possible
to reuse some EPF code?
Patrick
Re: Loading EPF libraries outside of EPF [message #599316 is a reply to message #518177] |
Fri, 02 April 2010 05:59  |
Hello Patrick,
I'm working on a similar project. And am still in the research phase. So far I've come to know a few things. The following is what i've realised so far.
I've built the application using Eclipse plugin Development + RCP.
And to read the library, I've set the target platform to EPF Composer, So that the plugins are available for import.
I'll be importing those plugins related with the library ,and using the already defined methods, I can open the library.
Will let you know my progress. Also, any help from your side will be most appreciated.
Anup Chaudhari.
FUDForum. Page generated in 0.03968 seconds
