Home » Eclipse Projects » Equinox » use bundle.properties file from another plugin(How can I use a bundle.properties from another plugin?)
use bundle.properties file from another plugin [message #524146] Tue, 30 March 2010 18:50 Go to next message
Hello all,
I have the following plugin structure:
plugin A
plugin B (depends on A)
so A defines a menu called "X Menu" and B Defines a view Called "X View"
What I would like to do is to make X a translateable string. By following the "externalize strings" wizard, I am able to externalize the string, however the wizard creates a bundle.properties file in plugin A.
By creating the bundle.properties file in plugin A, I am going to affect all children of A by making changes to the bundle.properties file.
This is undesireable. What I would really like is to have the plugin which specified the product, to define a bundle.properties file, in a sense, I want this bundle.properties file to be something dynamic, rather than hard coded in the build.properties file of plugin A.
Does anyone have any suggestions?
Re: use bundle.properties file from another plugin [message #524309 is a reply to message #524146] Wed, 31 March 2010 09:48 Go to previous messageGo to next message
Are you referring to the strings translated in your plugin.xml? If so then the bundle.properties (plugin.properties is the default name I thought) is specific to the bundle it is contained in (bundle A). Bundle B can have its own bundle.properties that is only used to translate its extensions defined in its own plugin.xml file.
Fragments are typically used to deliver additional properties files for other languages (e.g. bundle_fr_FR.properties). The extension registry uses the same translation files as the bundle manifest localization. See section 3.10.2 "Manifest Localization" from the OSGi Core Specification for more information.
Tom.
Re: use bundle.properties file from another plugin [message #524377 is a reply to message #524309] Wed, 31 March 2010 13:17 Go to previous messageGo to next message
Yes,
I am referring to strings translated in the plugin.xml
It is quite unfortunate that there is no way to provide an alternate .properties file from another plugin to be used.
Re: use bundle.properties file from another plugin [message #524598 is a reply to message #524377] Thu, 01 April 2010 05:56 Go to previous messageGo to next message
As Tom mentioned, you can use a fragment to supply the actual properties
file. If product 1 includes fragment A1 and product 2 includes fragment
A2 then you will have a different menu label used per-product. Is that
what you are trying to do?
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: use bundle.properties file from another plugin [message #524673 is a reply to message #524598] Thu, 01 April 2010 14:34 Go to previous messageGo to next message
Before I officially reply to your suggestion let make sure we're on the same page. To rephrase my original query, we have 30+ plugins that all use the same string "X" and we would like to avoid having to have either 30 plugin.properties files or 30 fragments to replace "X" with some other string "Y" everywhere "X" occurs.
so basically we want one place to specify the value of the replacement for "X"
Re: use bundle.properties file from another plugin [message #524676 is a reply to message #524673] Thu, 01 April 2010 14:44 Go to previous message
There is nothing available to do what you are suggesting. We have the same issue in most all of our bundles where our provider string is identical for all bundles included in the Eclipse SDK. We currently duplicate the string in each bundle.
Previous Topic:Drools and OSGi
Next Topic:Start equinox using jar
Current Time: Sat Jul 26 08:57:49 EDT 2025
Powered by FUDForum. Page generated in 0.10360 seconds
