[Xpand] unresolved proxy between ecore models [message #524576] |
Thu, 01 April 2010 04:46  |
I have a problem quite similar to the one described in a previous post
news://news.eclipse.org:119/hkrcji$d3d$1@build.eclipse.org
I am trying tt generate code with XPAND from an Ecore file in which I
have references to EClass objects defined in another Ecore file.
When I generate code, externally referenced Eclass object end up having
null name fields and cause my generator to produce invalid code.
I followed the advices of Karsten, however the proposed solution which
consist in adding mapping information in the MWE workflow doesn't work
for me
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup" >
<uriMap from=URI to=URI />
</bean>
After modifying the MWE file, I still have this problem.
Did I missed something obvious ?
Steven
FUDForum. Page generated in 0.08161 seconds
