Home » Eclipse Projects » Standard Widget Toolkit (SWT) » JVM crashes on Solaris sparc 5.10 with Eclipse 3.4 and some plugins(JVM crash with a Fontconfig error: Cannot load default config file )
JVM crashes on Solaris sparc 5.10 with Eclipse 3.4 and some plugins [message #524174] |
Wed, 31 March 2010 00:20  |
When I try to open eclipse workbench (Java 1.6) on solaris sparc 5.10 with a few plugins (JDT,PDE,eclipseShell,emf,sdo,GEF,JEM ,Apache.batik,tomcatPlugin, wtp, xsd), I get the error
[exec] #
[exec] # A fatal error has been detected by the Java Runtime Environment:
[exec] #
[exec] # SIGSEGV (0xb) at pc=0xb32c7380, pid=15561, tid=2
[exec] #
[exec] # JRE version: 6.0_17-b04
[exec] # Java VM: Java HotSpot(TM) Server VM (14.3-b01 mixed mode solaris-sparc )
[exec] # Problematic frame:
[exec] # C [libfontconfig.so.1+0x27380] FcPatternGetCharSet+0x2c
[exec] #
[exec] # An error report file with more information is saved as:
[exec] # /export/home/autobnp/testS1_BL_830/installation/ISC/eclipse/ plugins/hs_err_pid15561.log
While it works fine on linux and windows. I checked that the fonts.conf file is present in /etc/fonts and its readable. I also tried many other things that I found on the internet relating to fontconfig loading but nothing helped.
Then I downlaoded eclispe 3.6 and there it working fine without any JVM crash.
Is this the only way to solve the problem? I appreciate any pointers on this.
We have developed many plugins for eclipse which currently work on eclispe 3.4 but with eclipse 3.6, none of our perspectives are opening as is...may be we need to change many things to bring it up, I was trying to find a workaround for elcispe 3.4 instead as we are running short of time for a release.
Re: JVM crashes on Solaris sparc 5.10 with Eclipse 3.4 and some plugins [message #524463 is a reply to message #524322] |
Thu, 01 April 2010 00:15   |
Here is the dump from hs_err_pid..log
# SIGSEGV (0xb) at pc=0xb3197380, pid=23422, tid=2
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x00030000): JavaThread "main" [_thread_in_native, id=2, stack(0xfe300000,0xfe380000)]
siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR), si_addr=0x079332d8
Registers:
O0=0x00000000 O1=0xb31a4c8c O2=0xb31b6000 O3=0x00019000
O4=0x00000400 O5=0xb31a4c8c O6=0xfe37cd88 O7=0xb319737c
G1=0xb3197354 G2=0xb33ee800 G3=0x00000018 G4=0x00006400
G5=0x049b0d40 G6=0x00000000 G7=0xff362400 Y=0x00000000
PC=0xb3197380 nPC=0xb31b6938
Top of Stack: (sp=0xfe37cd88)
0xfe37cd88: 00000000 01e4ccb7 00f2665b 00000000
0xfe37cd98: 079332d8 01e4ccb7 01e4ccb8 00000000
0xfe37cda8: 02cc3c38 b31a4c8c 00000000 fe37ceb4
0xfe37cdb8: 00000003 00e1499c fe37cde8 b3192a78
0xfe37cdc8: ffff00ff b39c00ff ffff00ff 00030d08
0xfe37cdd8: 00000003 00000000 b2fd402b b3591688
0xfe37cde8: 01e4d0e0 00000000 00e147cc 0000031f
0xfe37cdf8: 00e14750 fe37ceb4 00e141c8 00000000
Instructions: (pc=0xb3197380)
0xb3197370: 92 10 00 19 a5 3d 60 01 a9 2c a0 03 40 00 7d 6f
0xb3197380: d0 05 00 13 80 a2 20 00 22 80 00 13 80 a4 a0 00
Stack: [0xfe300000,0xfe380000], sp=0xfe37cd88, free space=499k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [libfontconfig.so.1+0x22a80] FcFontSetSort+0xaf0
C [libfontconfig.so.1+0x22c44] FcFontSort+0x74
C [libpangoft2-1.0.so.0.501.1+0x85ac]
C [libpangoft2-1.0.so.0.501.1+0x882c]
C [libpango-1.0.so.0.501.1+0x176fc] pango_context_get_metrics+0xcc
C [libswt-pi-gtk-3449.so+0x48190] Java_org_eclipse_swt_internal_gtk_OS__1pango_1context_1get_1 metrics+0x14
j org.eclipse.swt.internal.gtk.OS._pango_context_get_metrics(I II)I+0
j org.eclipse.swt.internal.gtk.OS.pango_context_get_metrics(II I)I+10
j org.eclipse.swt.graphics.GC.getFontMetrics()Lorg/eclipse/swt /graphics/FontMetrics;+58
j org.eclipse.jface.layout.LayoutConstants.initializeConstants ()V+26
j org.eclipse.jface.layout.LayoutConstants.getSpacing()Lorg/ec lipse/swt/graphics/Point;+0
j org.eclipse.jface.layout.GridLayoutFactory.fillDefaults()Lor g/eclipse/jface/layout/GridLayoutFactory;+18
j org.eclipse.jface.dialogs.PopupDialog.<clinit>()V+11
v ~StubRoutines::call_stub
V [libjvm.so+0x151b9c]
V [libjvm.so+0x1810a8]
V [libjvm.so+0x4c93f8]
V [libjvm.so+0x13fbe4]
V [libjvm.so+0x1339bc]
V [libjvm.so+0x1e2084]
V [libjvm.so+0x1b8288]
C [libjava.so+0xdd44] Java_java_lang_Class_forName0+0x130
j java.lang.Class.forName0(Ljava/lang/String;ZLjava/lang/Class Loader;)Ljava/lang/Class;+0
j java.lang.Class.forName(Ljava/lang/String;)Ljava/lang/Class; +5
j org.eclipse.jface.resource.JFaceResources.initializeDefaultI mages()V+330
j org.eclipse.jface.resource.JFaceResources.getImageRegistry() Lorg/eclipse/jface/resource/ImageRegistry;+22
j org.eclipse.jface.wizard.Wizard.<init>()V+41
j com.thegoldensource.deployment.base.ui.wizards.tasks.Abstrac tTaskWizard. <init> (Lcom/thegoldensource/deployment/base/deploy/tasks/ITask;)V+ 1
j com.thegoldensource.deployment.base.ui.wizards.tasks.XmlSqlT askWizard. <init> (Lcom/thegoldensource/deployment/base/deploy/tasks/ITask;)V+ 2
V [libjvm.so+0x739ab8]
V [libjvm.so+0x1af5a8]
V [libjvm.so+0x1af770]
C [libjava.so+0xdde0] Java_sun_reflect_NativeConstructorAccessorImpl_newInstance0+ 0x14
j sun.reflect.NativeConstructorAccessorImpl.newInstance0(Ljava /lang/reflect/Constructor;[Ljava/lang/Object;)Ljava/lang/Obj ect;+0
j sun.reflect.NativeConstructorAccessorImpl.newInstance([Ljava /lang/Object;)Ljava/lang/Object;+72
J sun.reflect.DelegatingConstructorAccessorImpl.newInstance([L java/lang/Object;)Ljava/lang/Object;
j java.lang.reflect.Constructor.newInstance([Ljava/lang/Object ;)Ljava/lang/Object;+92
j com.thegoldensource.deployment.base.ui.wizards.tasks.TaskWiz ardFactory.getTaskWizard(Lcom/thegoldensource/deployment/bas e/deploy/tasks/ITask;)Lcom/thegoldensource/deployment/base/u i/extensions/ITaskWizard;+61
j com.thegoldensource.deployment.commandline.InstallPackage.in itTasks(Lcom/thegoldensource/deployment/base/deploy/Deployme ntProcessor;)V+63
j com.thegoldensource.deployment.commandline.InstallPackage.ex ecute()V+609
j com.thegoldensource.deployment.scenario.ScenarioProcessor.ha ndleInstallation(Lorg/eclipse/core/runtime/IProgressMonitor; )V+640
j com.thegoldensource.deployment.scenario.ScenarioProcessor.ru n(Lcom/thegoldensource/deployment/base/scenario/Installation Status;Lorg/eclipse/core/runtime/IProgressMonitor;)V+384
j com.thegoldensource.deployment.scenario.ScenarioInstallerApp lication.start(Lorg/eclipse/equinox/app/IApplicationContext; )Ljava/lang/Object;+1317
j org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/ lang/Object;)Ljava/lang/Object;+135
j org.eclipse.equinox.internal.app.MainApplicationLauncher.run (Ljava/lang/Object;)Ljava/lang/Object;+19
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(Ljava/lang/Object;)Ljava/lang/Object;+103
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Ljava/lang/Object;)Ljava/lang/Object;+29
j org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/la ng/Object;)Ljava/lang/Object;+149
j org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/l ang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+183
V [libjvm.so+0x20d280]
V [libjvm.so+0x20b7b0]
C [libjava.so+0x10ca4] Java_sun_reflect_NativeMethodAccessorImpl_invoke0+0x18
j sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/refl ect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/ Object;+0
j sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Objec t;[Ljava/lang/Object;)Ljava/lang/Object;+87
j sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/O bject;[Ljava/lang/Object;)Ljava/lang/Object;+6
j java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lan g/Object;)Ljava/lang/Object;+161
j org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lan g/String;[Ljava/net/URL;)V+211
j org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/Strin g;)V+114
j org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+ 4
j org.eclipse.equinox.launcher.Main.main([Ljava/lang/String;)V +10
V [libjvm.so+0x1f5afc]
C [java+0x3ab8]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x03ba2800 JavaThread "Worker-0" [_thread_blocked, id=42, stack(0xb4200000,0xb4280000)]
0x02146c00 JavaThread "Provisioning Event Dispatcher" daemon [_thread_blocked, id=39, stack(0xb4400000,0xb4480000)]
0x00635400 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=37, stack(0xb5280000,0xb5300000)]
0x00e60400 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=35, stack(0xb5380000,0xb5400000)]
0x0026e000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=32, stack(0xb5700000,0xb5780000)]
0x0026b400 JavaThread "CompilerThread1" daemon [_thread_blocked, id=31, stack(0xb5800000,0xb5880000)]
0x00268c00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=30, stack(0xb5900000,0xb5980000)]
0x00267400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=29, stack(0xb5a00000,0xb5a80000)]
0x00255000 JavaThread "Finalizer" daemon [_thread_blocked, id=28, stack(0xb5d80000,0xb5e00000)]
0x00250400 JavaThread "Reference Handler" daemon [_thread_blocked, id=27, stack(0xb5e80000,0xb5f00000)]
=>0x00030000 JavaThread "main" [_thread_in_native, id=2, stack(0xfe300000,0xfe380000)]
Other Threads:
0x0024c800 VMThread [stack: 0xb5f80000,0xb6000000] [id=26]
0x0026f800 WatcherThread [stack: 0xb5600000,0xb5680000] [id=33]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen total 285760K, used 112815K [0xe6400000, 0xfbc00000, 0xfbc00000)
eden space 220288K, 49% used [0xe6400000,0xece69760,0xf3b20000)
from space 65472K, 5% used [0xf3b20000,0xf3ee2690,0xf7b10000)
to space 64064K, 0% used [0xf7d70000,0xf7d70000,0xfbc00000)
PSOldGen total 106496K, used 86713K [0xbb800000, 0xc2000000, 0xe6400000)
object space 106496K, 81% used [0xbb800000,0xc0cae480,0xc2000000)
PSPermGen total 36864K, used 34534K [0xb7800000, 0xb9c00000, 0xbb800000)
object space 36864K, 93% used [0xb7800000,0xb99b9958,0xb9c00000)
Dynamic libraries:
0x00010000 /opt1/jdk1.6.0_17/bin/java
0xff3f8000 /lib/libthread.so.1
0xff380000 /opt1/jdk1.6.0_17/bin/../jre/lib/sparc/jli/libjli.so
0xff3a0000 /lib/libdl.so.1
0xff200000 /lib/libc.so.1
0xff350000 /platform/SUNW,Sun-Fire-T200/lib/libc_psr.so.1
0xfe400000 /opt1/jdk1.6.0_17/jre/lib/sparc/server/libjvm.so
0xff310000 /lib/libsocket.so.1
0xff340000 /usr/lib/libsched.so.1
0xff1e0000 /lib/libm.so.1
0xff1a0000 /usr/lib/libCrun.so.1
0xff180000 /lib/libdoor.so.1
0xff080000 /lib/libnsl.so.1
0xfef80000 /lib/libm.so.2
0xff150000 /lib/libscf.so.1
0xff060000 /lib/libuutil.so.1
0xfef60000 /lib/libmd5.so.1
0xfef40000 /lib/libmp.so.2
0xfeed0000 /opt1/jdk1.6.0_17/jre/lib/sparc/libverify.so
0xfee90000 /opt1/jdk1.6.0_17/jre/lib/sparc/libjava.so
0xfee60000 /opt1/jdk1.6.0_17/jre/lib/sparc/native_threads/libhpi.so
0xfe3c0000 /lib/nss_files.so.1
0xfe390000 /opt1/jdk1.6.0_17/jre/lib/sparc/libzip.so
0xb5b00000 /usr/lib/locale/en_US.UTF-8/en_US.UTF-8.so.3
0xfe2d0000 /usr/lib/locale/en_US.UTF-8/methods_en_US.UTF-8.so.3
0xfe020000 /opt1/jdk1.6.0_17/jre/lib/sparc/libj2pkcs11.so
0xfbfc0000 /usr/lib/libpkcs11.so
0xfbd60000 /usr/lib/libcryptoutil.so.1
0xfbd30000 /usr/lib/security/pkcs11_kernel.so
0xb5580000 /usr/lib/security/pkcs11_softtoken.so
0xfbc50000 /opt1/jdk1.6.0_17/jre/lib/sparc/libnet.so
0xfbd10000 /opt1/jdk1.6.0_17/jre/lib/sparc/libnio.so
0xfbc20000 /lib/librt.so.1
0xb77e0000 /lib/libaio.so.1
0xb77c0000 /usr/lib/libsendfile.so.1
0xb77a0000 /export/home/autobnp/testS1_BL_830/installation/ISC/eclipse/ plugins/org.eclipse.equinox.launcher.gtk.solaris.sparc_1.0.1 01.R34x_v20080731/eclipse_1115.so
0xb3a10000 /export/home/autobnp/testS1_BL_830/installation/ISC/eclipse/ configuration/org.eclipse.osgi/bundles/312/1/.cp/libswt-gtk- 3449.so
0xb3980000 /export/home/autobnp/testS1_BL_830/installation/ISC/eclipse/ configuration/org.eclipse.osgi/bundles/312/1/.cp/libswt-pi-g tk-3449.so
0xb3600000 /usr/lib/libgtk-x11-2.0.so.0
0xb3950000 /usr/lib/libgthread-2.0.so.0
0xb3920000 /usr/openwin/lib/libXtst.so.1
0xb35d0000 /usr/lib/libgdk_pixbuf-2.0.so.0
0xb3500000 /usr/lib/libgdk-x11-2.0.so.0
0xb3900000 /usr/lib/libgmodule-2.0.so.0
0xb3400000 /usr/lib/libglib-2.0.so.0
0xb3380000 /usr/lib/libgobject-2.0.so.0
0xb34d0000 /usr/lib/libatk-1.0.so.0
0xb35a0000 /usr/lib/libpangoxft-1.0.so.0
0xb3330000 /usr/lib/libpango-1.0.so.0
0xb3310000 /usr/lib/libpangox-1.0.so.0
0xb32d0000 /usr/openwin/lib/libXft.so.2
0xb3200000 /usr/sfw/lib/libfreetype.so.6
0xb31d0000 /usr/sfw/lib/libXrender.so.1
0xb3170000 /usr/lib/libfontconfig.so.1
0xb3080000 /usr/openwin/lib/libX11.so.4
0xb1c00000 /usr/lib/libmlib.so.2
0xb3140000 /usr/X11/lib/libXrandr.so.2
0xb3050000 /usr/openwin/lib/libXi.so.5
0xb3010000 /usr/openwin/lib/libXext.so.0
0xb2fd0000 /usr/lib/libpangoft2-1.0.so.0
0xb0400000 /usr/lib/cpu/sparcv8plus/libmlib.so.2
0xb2f60000 /usr/sfw/lib/libexpat.so.0
0xb2f30000 /usr/lib/libz.so.1
0xb2f10000 /usr/lib/iconv/UTF-8%8859-1.so
0xb1b40000 /lib/nss_dns.so.1
0xb1ae0000 /lib/libresolv.so.2
VM Arguments:
jvm_args: -Xmx1024m -DignoreInstRepVersion=on
java_command: org.eclipse.equinox.launcher_1.0.101.R34x_v20080819.jar -os solaris -ws gtk -arch sparc -clean -consoleLog -application com.thegoldensource.deployment.commandline.ScenarioInstaller -data /export/home/autobnp/testS1_BL_830/installation/ISC/eclipse/ workspace -forceDataOverride true -scenarioFile /export/home/autobnp/testS1_BL_830/scenario/scenarioDefiniti on.xml -runtimeConfigurationFile /export/home/autobnp/testS1_BL_830/installation/temp/runtime Config.xml -databaseType Oracle,DB2 for z/OS -databaseDriverLibs_DB2 for z/OS JDBC driver library=/opt/IBM/db2/V8.1//java/db2jcc.jar,JDBC driver license=/opt/IBM/db2/V8.1//java/db2jcc_license_cisuz.jar -db2ClientPath /home/${env.DB2INSTANCE}/sqllib/ -db2Alias IN04 -databaseDriverLibs_Oracle JDBC driver library=/opt/oracle/product/10.2.0.4//jdbc/lib/ojdbc14.jar -oracleClientPath /opt/oracle/product/10.2.0.4/ -overallStatusXmlFile /export/home/autobnp/testS1_BL_830/installation/temp/status_ InstallCenter.xml -logInitializationException true
Launcher Type: SUN_STANDARD
Environment Variables:
JAVA_HOME=/opt/Java_1.6.0/
PATH=/usr/openwin/bin:/usr/X11R6/bin:/usr/atria/bin:/usr/atr ia/etc/utils:/usr/apache-ant-1.6.5//bin:/opt/oracle/product/ 10.2.0.4//bin:/opt/oracle/product/10.2.0.4//lib:/opt/Java_1. 6.0//bin:.:/bin:/usr/bin:/usr/sbin:/opt/Java_1.6.0//bin:/opt /oracle/product/10.2.0.4//bin:/usr/X/bin:/opt/Java_1.5.0//bi n:/usr/bin::/usr/local/bin:/etc:/opt/EMCpower/bin/64:/etc/em c/bin:/export/home/autobnp/bin:/opt/oracle/product/10.2.0.4/ /bin:/usr/apache-ant-1.6.5//bin:/usr/local/bin:/usr/bin:/opt /SUNWspro/bin
LD_LIBRARY_PATH=/opt1/jdk1.6.0_17/jre/lib/sparc/server:/opt1 /jdk1.6.0_17/jre/lib/sparc:/opt1/jdk1.6.0_17/jre/../lib/spar c:/opt/oracle/product/10.2.0.4//lib:
SHELL=/bin/ksh
DISPLAY=:1
Signal Handlers:
SIGSEGV: [libjvm.so+0x808f44], sa_mask[0]=0xffbffeff, sa_flags=0x0000000c
SIGBUS: [libjvm.so+0x808f44], sa_mask[0]=0xffbffeff, sa_flags=0x0000000c
SIGFPE: [libjvm.so+0x1b8724], sa_mask[0]=0xffbffeff, sa_flags=0x0000000c
SIGPIPE: [libjvm.so+0x1b8724], sa_mask[0]=0xffbffeff, sa_flags=0x0000000c
SIGXFSZ: [libjvm.so+0x1b8724], sa_mask[0]=0xffbffeff, sa_flags=0x0000000c
SIGILL: [libjvm.so+0x1b8724], sa_mask[0]=0xffbffeff, sa_flags=0x0000000c
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGQUIT: [libjvm.so+0x6f7fec], sa_mask[0]=0xffbffeff, sa_flags=0x00000004
SIGHUP: [libjvm.so+0x6f7fec], sa_mask[0]=0xffbffeff, sa_flags=0x00000004
SIGINT: [libjvm.so+0x6f7fec], sa_mask[0]=0xffbffeff, sa_flags=0x00000004
SIGTERM: [libjvm.so+0x6f7fec], sa_mask[0]=0xffbffeff, sa_flags=0x00000004
SIG39: [libjvm.so+0x6fba70], sa_mask[0]=0x00000000, sa_flags=0x00000008
SIG40: [libjvm.so+0x1b8724], sa_mask[0]=0xffbffeff, sa_flags=0x0000000c
--------------- S Y S T E M ---------------
OS: Solaris 10 11/06 s10s_u3wos_10 SPARC
Copyright 2006 Sun Microsystems, Inc. All Rights Reserved.
Use is subject to license terms.
Assembled 14 November 2006
uname:SunOS 5.10 Generic_118833-36 sun4v (T2 libthread)
rlimit: STACK 8192k, CORE infinity, NOFILE 65536, AS infinity
load average:2.00 2.52 2.73
CPU:total 32 has_v8, has_v9, has_vis1, is_sun4v, is_niagara1
Memory: 8k page, physical 8380416k(1479504k free)
vm_info: Java HotSpot(TM) Server VM (14.3-b01) for solaris-sparc JRE (1.6.0_17-b04), built on Oct 11 2009 01:35:37 by "" with Workshop 5.8
time: Thu Mar 25 16:31:51 2010
elapsed time: 316 seconds
Re: JVM crashes on Solaris sparc 5.10 with Eclipse 3.4 and some plugins [message #524623 is a reply to message #524463] |
Thu, 01 April 2010 06:54   |
It looks like you're seeing
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201611 . I've added a comment
to it about your Java 5/Java 6 observation, perhaps it will provide a
workaround for the original reporter and give a clue to the contact. In the
meantime I would suggest CC'ing yourself to the report to be notified of its
progress. I don't know of a workaround to suggest, other than to use Java 5
if possible.
Grant
"Vidya Ram" <vidyaram@gmail.com> wrote in message
news:hp16l4$e6k$1@build.eclipse.org...
si_addr=0x079332d8
> Registers:
code)
mages()V+330
tTaskWizard. <init>
askWizard. <init>
ntProcessor;)V+63
ecute()V+609
ect;+1317
..runApplication(Ljava/lang/Object;)Ljava/lang/Object;+103
..start(Ljava/lang/Object;)Ljava/lang/Object;+29
> C [java+0x3ab8]
mages()V+330
tTaskWizard. <init>
askWizard. <init>
ntProcessor;)V+63
ecute()V+609
ect;+1317
> Other Threads:
> Heap
0xfbc00000)
0xe6400000)
0xbb800000)
> Dynamic libraries:
> VM Arguments:
JDBC driver
> SHELL=/bin/ksh
> DISPLAY=:1
> Signal Handlers:
Current Time: Wed Jul 23 12:11:49 EDT 2025
Powered by FUDForum. Page generated in 0.04739 seconds
