Home » Eclipse Projects » Eclipse Platform » is there extension points which affects cvs plugin behavior?
is there extension points which affects cvs plugin behavior? [message #518825] Fri, 05 March 2010 03:28 Go to next message
Hi, everyone
I am using zend studio 7.x, and I found that cvs plugin didn't work well
since 7.x.
It can't operate recursively. First, I thought this is caused by the update
of eclipse, and then I tried with pure eclipse, and found it was ok.
Now I think this is definitely caused by some plugin in zend studio, so
I wonder, is there any extension point which can affect cvs plugin behavior?
Thanks very much!
Re: is there extension points which affects cvs plugin behavior? [message #524002 is a reply to message #518825] Tue, 30 March 2010 00:14 Go to previous messageGo to next message
Nobody knows?
"Hoping White" <baihaoping@gmail.com> д
Re: is there extension points which affects cvs plugin behavior? [message #524263 is a reply to message #524002] Wed, 31 March 2010 07:14 Go to previous messageGo to next message
> Nobody knows?
hard to know what Zend Studio does with the Eclipse CVS; if it works with plain vanilla
Eclipse, you should probably ask over here:
http://forums.zend.com/viewforum.php?f=59
Greetings,
Ralf
http://www.ralfebert.de/blog/eclipsercp/
Re: is there extension points which affects cvs plugin behavior? [message #525316 is a reply to message #524263] Mon, 05 April 2010 23:24 Go to previous message
ok, forget about zend studio.
My question is is there any extension point which affects cvs plugin
behavior, such as operation recursive.
Thanks!
"Ralf Ebert" <info@ralfebert.de> д
Previous Topic:Looking for plug-in org.eclipse.jdt.ui on CVS
Next Topic:Recognize syntax constructions in text
Current Time: Sat Jul 26 15:19:31 EDT 2025
Powered by FUDForum. Page generated in 0.28451 seconds
