Home » Archived » M2M (model-to-model transformation) » [ATL] applyStereotypes not work programmatically(different results with Run Configurations and programmatically)
[ATL] applyStereotypes not work programmatically [message #522459] Mon, 22 March 2010 13:14 Go to next message
I realized a transformation using the Run Configurations and everything is ok. but when I try programmatically, the profile is applied but does not apply stereotypes.
Is there a necessary condition to apply stereotypes? maybe some configuration in the launch ...
thank in advance.
// Defaults
		ILauncher launcher = CoreService.getLauncher("EMF-specific VM");
		launcher.initialize(Collections.EMPTY_MAP);
		ModelFactory factory = CoreService.createModelFactory(launcher.getDefaultModelFactoryName());
		injector = CoreService.getInjector(factory.getDefaultInjectorName());
		extractor = CoreService.getExtractor(factory.getDefaultExtractorName());
		asmURL = new URL("file:/C:/.../galileo/atl/CIMtoPIM.asm"); //$NON-NLS-1$
                 // Metamodel
		umlMetamodel = factory.newReferenceModel();
		injector.inject(umlMetamodel, "http://www.eclipse.org/uml2/2.1.0/UML"); //$NON-NLS-1$
		// Creating models
		IModel outModel = factory.newModel(umlMetamodel);
		IModel inModel = factory.newModel(umlMetamodel);
		IModel profilePIMModel = factory.newModel(umlMetamodel);
		IModel profileCIMModel = factory.newModel(umlMetamodel);
		// Loading existing model
		injector.inject(inModel, "file:/C:/.../galileo/atl/model/CIM.uml");
		injector.inject(profileCIMModel, "file:/C:/.../galileo/atl/model/ProfileCIM.profile.uml");
		injector.inject(profilePIMModel, "file:/C:/.../galileo/atl/model/ProfilePIM.profile.uml");
		// addModels
		launcher.addOutModel(outModel, "OUT", "UML2"); //$NON-NLS-1$ //$NON-NLS-2$
		launcher.addInModel(inModel, "IN", "UML2"); //$NON-NLS-1$ //$NON-NLS-2$
		launcher.addInModel(profileCIMModel, "PROCIM", "UML2"); //$NON-NLS-1$ //$NON-NLS-2$
		launcher.addInModel(profilePIMModel, "PROPIM", "UML2"); //$NON-NLS-1$ //$NON-NLS-2$
		//libs
		URL lib = new URL("file:/C:/.../galileo/atl/Lib.asm");
		URL facilities = new URL("file:/C:/.../galileo/atl/ATLfacilities.asm");
		launcher.addLibrary("lib", launcher.loadModule(lib.openStream()));
		launcher.addLibrary("ATLFacilities", launcher.loadModule(facilities.openStream()));
		//options
		Map<String, Object> options = new HashMap<String, Object>();
		options.put("allowInterModelReferences", "false");
		options.put("supportUML2Stereotypes", "true");
		options.put("showSummary", "true");
		//run
		launcher.launch(ILauncher.RUN_MODE, new NullProgressMonitor(), options, asmURL.openStream());
Result programmatically:
http://img377.imageshack.us/img377/9812/out2.png
Result Run Configurations:
http://img201.imageshack.us/img201/8707/out1.png
[Updated on: Mon, 22 March 2010 13:18] by Moderator
Re: [ATL] applyStereotypes not work programmatically [message #524097 is a reply to message #522459] Tue, 30 March 2010 12:46 Go to previous messageGo to next message
not resolved yet!!!
help me!
Re: [ATL] applyStereotypes not work programmatically [message #524211 is a reply to message #522459] Wed, 31 March 2010 04:05 Go to previous messageGo to next message
You could try to use platforms uri. This should work as this is the behavior used in the launch configuration.
Re: [ATL] applyStereotypes not work programmatically [message #524418 is a reply to message #524211] Wed, 31 March 2010 16:37 Go to previous message
No chance!
Error loading uri:http://www.eclipse.org/uml2/3.0.0/UML: java.net.MalformedURLException: unknown protocol: uri
Previous Topic:[ATL] Launching ATL from Java, 'Content is not allowed in prolog'.
Next Topic:Doing M2M with Xtend ?
Current Time: Sun Jul 27 12:56:43 EDT 2025
Powered by FUDForum. Page generated in 0.02995 seconds
