NoClassDefFoundError for IBM's SimpleDataFormat when integrating [message #523407] |
Fri, 26 March 2010 06:43  |
I am attempting to integrate the reporting engine into my existing web application (currently deployed on Tomcat 5.5.).
My project is a maven project and as far as I understand BIRT is still not 'mavenised'...so I followed the instructions on another post in this forum and manually added to our repository the following artifacts:
- core-api (jar)
- engine-api (jar)
- model-api (jar)
- Report Engine (directory zipped up and extracted when added to my WEB-INF dir)
The BIRT versions I have tried with each of these artifacts are 2.5.1 and 2.5.2.
I added some code (that depended on the first 3 artifact's to compile) to my project that started up the platform, instantiated the IReportEngine and then attempted to call IReportEngine.openReportDesign(String rptDesign).
The platform is told that the ReportEngine directory is in the WEB-INF directory and starts up successfully. Then the report engine object is also successfully initialised. All the jar artifacts are correctly placed in the WEB-INF/lib directory.
The exception (below) is thrown on the line calling openReportDesign()...I have found this bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=299718
Is it exactly the same? Is there anyway of getting this to work?
Attempting to follow the work around mentioned in the bug report didn't help...things I tried:
- Deleting anything, except config.ini, in the config directory (in ReportEngine) whenever I restarted the webapp.
- Deleting com.ibm.icu_4.0.1.v20090822.jar from the lib directory and on a separate attempt, from the plugins directory
- Ensuring the com.ibm.icu_4.0.1.v20090822.jar was identical in both directories, i.e. copying jar from lib directory and overwritting one in plugins directory
- Deleting the org.eclipse.birt.api jar from the plugins directory (failed to then instantiate the IReportEngine object)
- Modifying the manifest file of the org.eclipse.birt.api jar numerous times - deleted any IBM jar listed in the export packages, removed just the IBM text jar, ...
Any ideas?
The exception:
java.lang.NoClassDefFoundError: com/ibm/icu/text/SimpleDateFormat
at org.eclipse.birt.report.model.metadata.DateTimePropertyType.<clinit>(DateTimePropertyType.java:62)
at org.eclipse.birt.report.model.metadata.MetaDataDictionary.<init>(MetaDataDictionary.java:237)
at org.eclipse.birt.report.model.metadata.MetaDataDictionary.<clinit>(MetaDataDictionary.java:111)
at org.eclipse.birt.report.model.api.impl.DesignEngineImpl.newSessionHandle(DesignEngineImpl.java:143)
at org.eclipse.birt.report.model.api.DesignEngine.newSessionHandle(DesignEngine.java:108)
at org.eclipse.birt.report.engine.parser.ReportParser.getDesignHandle(ReportParser.java:143)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.getReportDesignHandle(ReportEngineHelper.java:254)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:273)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:195)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:129)
at org.eclipse.birt.report.engine.api.impl.ReportEngine.openReportDesign(ReportEngine.java:294)
at com.test.reporting.servlet.TestReportServlet.doGet(TestReportServlet.java:58)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:627)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
Thanks in advance.
Re: NoClassDefFoundError for IBM's SimpleDataFormat when integrating [message #523716 is a reply to message #523407] |
Sun, 28 March 2010 15:52   |
Ed,
I worked with Shaun on this issue in the bug you referred to. Can you
download the all in one and replace icu plugin in your runtime with the
one that is in the all in one?
Jason
Ed Slocombe wrote:
> core-api (jar)
> engine-api (jar)
> model-api (jar)
> WEB-INF dir)
> and 2.5.2.
> plugins directory
> Any ideas?
> The exception:
> at
> org.eclipse.birt.report.model.metadata.DateTimePropertyType. <clinit>(DateTimePropertyType.java:62)
> at
> org.eclipse.birt.report.model.metadata.MetaDataDictionary.<init >(MetaDataDictionary.java:237)
> at
> org.eclipse.birt.report.model.metadata.MetaDataDictionary.<clinit >(MetaDataDictionary.java:111)
> at
> org.eclipse.birt.report.model.api.impl.DesignEngineImpl.newS essionHandle(DesignEngineImpl.java:143)
> at
> org.eclipse.birt.report.model.api.DesignEngine.newSessionHan dle(DesignEngine.java:108)
> at
> org.eclipse.birt.report.engine.parser.ReportParser.getDesign Handle(ReportParser.java:143)
> at
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.g etReportDesignHandle(ReportEngineHelper.java:254)
> at
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:273)
> at
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:195)
> at
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:129)
> at
> org.eclipse.birt.report.engine.api.impl.ReportEngine.openRep ortDesign(ReportEngine.java:294)
> at
> com.test.reporting.servlet.TestReportServlet.doGet(TestRepor tServlet.java:58)
> at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:269)
> at
> org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:188)
> Thanks in advance.
Re: NoClassDefFoundError for IBM's SimpleDataFormat when integrating [message #1738640 is a reply to message #523407] |
Thu, 21 July 2016 11:28  |
I am attempting to integrate the reporting engine into my desktop application
i'am using eclipse Version: Mars.2 Release (4.5.2) , and i manually added to our repository the following artifacts:
core-api (jar)
engine-api (jar)
model-api (jar)
The BIRT versions I have tried with each of these artifacts are 4.5.0 . i did use
this code to integrate my repport to my application.
// code//
try {
System.out.println("Lancement du moteur de génération"); // Lancement du moteur de génération
EngineConfig config = new EngineConfig();
config.setBIRTHome("C://Program Files//birt-runtime-2_3_1//ReportEngine");
// config.setBIRTHome("C://Program Files//birt-runtime-2_1_1//ReportEngine");
Platform.startup(config);
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY);
IReportEngine engine = factory.createReportEngine(config);
System.out.println("Récupération du report (.rptdesign)");
// Chemin ou se trouve le report
String chemin = "C://Users//MH//workspace2//SID//new_report";
//String chemin2 = "C://Users//MH//workspace2//P//src//new_report_1";
// Récupération du rptDesign
IReportRunnable design = engine.openReportDesign(chemin+".rptdesign");
//IReportRunnable design = engine.openReportDesign(chemin+".rptdesign");
System.out.println("Exécution et génération du report en reporting document (.rptdocument)");
// Exécution
IRunTask runTask = engine.createRunTask(design);
runTask.run(chemin+".rptdocument");
System.out.println("Récupération du reporting document");
// Récupération du rptDocument
IReportDocument doc = engine.openReportDocument(chemin+".rptdocument");
System.out.println("Génération du fichier pdf ");
// Rendu
IRenderTask renderTask = engine.createRenderTask(doc);
IRenderOption option = new RenderOption();
option.setOutputFileName(chemin+".pdf"); // Nom du fichier de sortie
option.setOutputFormat("pdf"); // Format du fichier de sortie
renderTask.setRenderOption(option) ; // Chargement du fichier
//renderTask.render(); // Création du fichier
//renderTask.run();
//process = runtime.exec(new String[]{"open", chemin +".html"});
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
/* Fin de la préparation */
/* Création PDF */
//option.setOutputFileName("Chemin C"); //Nom du fichier de sortie
task.setRenderOption(option); //Chargement du fichier
/* Fin création PDF */
((IRunAndRenderTask) renderTask).run(); //Déclenchement de l'édition
catch(BirtException ex)
ex.printStackTrace();
but The exception (below) is thrown on the line IReportRunnable design = engine.openReportDesign(chemin+".rptdesign");
//Exception//
Exception in thread "main" java.lang.NoClassDefFoundError: com/ibm/icu/text/SimpleDateFormat
at org.eclipse.birt.report.model.metadata.DateTimePropertyType.<clinit>(DateTimePropertyType.java:63)
at org.eclipse.birt.report.model.metadata.MetaDataDictionary.<init>(MetaDataDictionary.java:258)
at org.eclipse.birt.report.model.metadata.MetaDataDictionary.<clinit>(MetaDataDictionary.java:122)
at org.eclipse.birt.report.model.api.impl.DesignEngineImpl.newSessionHandle(DesignEngineImpl.java:151)
at org.eclipse.birt.report.model.api.DesignEngine.newSessionHandle(DesignEngine.java:120)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:253)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:193)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:127)
at org.eclipse.birt.report.engine.api.impl.ReportEngine.openReportDesign(ReportEngine.java:327)
at sid.main(sid.java:35)
Caused by: java.lang.ClassNotFoundException: com.ibm.icu.text.SimpleDateFormat
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
... 11 more
[Updated on: Thu, 21 July 2016 11:33] by Moderator
FUDForum. Page generated in 0.11524 seconds
