Home » Modeling » OCL » OCL related query
OCL related query [message #523267] Thu, 25 March 2010 13:31 Go to next message
I am trying to run following query on OCL Interpreter Console basically it tries to calculate Depth of Inheritance tree. From the theoritical part it looks fine, I need to define this query for my work, but it is hard to redefine it on UML metamodel , and on M2 layer. I do not find iterate(), isRoot() in the current specifications. I will be very gratefull if some body share his thougts to run it on eclipse OCL interpreter console or any other method to find DIT on OCL interpreter.
The source of this query is the following paper:
source: http://ctp.di.fct.unl.pt/QUASAR/Resources/Papers/2002/QUAOOS E2002FinalAline.pdf
Class::DIT():Integer
post: result = (if self.IsRoot() then
                   0
    else
       1 + self.Parents()->iterate(elem:Class; acc:Integer=0 |
if elem.DIT() > acc then
elem.DIT()
else
acc
endif)
    endif)
Thanks in advance,
arise
Re: OCL related query [message #523667 is a reply to message #523267] Sun, 28 March 2010 04:26 Go to previous messageGo to next message
Hi Arise
The paper you refer to is very old. Internally it refers to [OMG1997]
for OCL 1.1 and inaccurately using the same reference to an unspecified
version of UML.
Eclipse tools provide only accidental support for OCL 1.x or UML 1.x.
OCL 2.0 was a major revision.
There is no IsRoot() or isRoot() method in UML 2.x. You could define
an IsRoot query to access the parent/child properties appropriately.
The operation context preamble: "Class::DIT():Integer" is syntactically
incorrect for an OCL 2.x document. I would expect to see
"context Class::DIT():Integer".
The expression is a post-condition, which MDT/OCL will only check for
syntactic accuracy. The expression appears to be executable and so could
be changed to a body.
iterate() should not present problems. I suspect that you are being
misled by other issues.
You need to revise the paper's examples to accommodate language
evolution, perhaps building up from simpler queries as you gain
confidence in the languages and tooling.
Ed Willink
On 25/03/2010 17:31, arise76 wrote:
> source:http://ctp.di.fct.unl.pt/QUASAR/Resources/Papers/2002 /QUAOOSE2002FinalAline.pdf
> Class::DIT():Integer post: result = (if self.IsRoot() then 0 else 1 +
> self.Parents()->iterate(elem:Class; acc:Integer=0 | if elem.DIT() > acc
> then elem.DIT() else acc endif) endif)
> Thanks in advance,
> arise
Re: OCL related query [message #523698 is a reply to message #523667] Sun, 28 March 2010 17:15 Go to previous message
Hi Ed Willink,
I use OCL 2.0 syntax and I found isRoot() with the following query, but I do not now which method should I use for iteration,
I am using OCL console where I cant use context keyword, so I simply run if else block as follows.
if Class.allInstances()->exists(parents()->size()=0) then 0 -- its a root element
else 1 ---, here I do not know how can I use iteration as used in the reference paper query
endif
Arise
Re: OCL related query [message #523701 is a reply to message #523698] Sun, 28 March 2010 12:58 Go to previous message
Hi Arise
iterate() should work. You need to explain why you think it doesn't.
Ed Willink
On 28/03/2010 22:15, arise76 wrote:
> Hi Ed Willink,
> I do not now which method should I use for iteration, I am using OCL
> as follows.
> root element else 1 ---, here I do not know how can I use iteration as
> endif
> Thanks
> Arise
Previous Topic:actor, usecase relationship query
Next Topic:EMF & OCL beginner question
Current Time: Thu Jul 24 15:48:23 EDT 2025
Powered by FUDForum. Page generated in 0.04122 seconds
