Home » Eclipse Projects » Rich Client Platform (RCP) » How to? / RCP with service plug-in and EJB3 interaction
icon5.gif  How to? / RCP with service plug-in and EJB3 interaction [message #523696] Sun, 28 March 2010 16:39 Go to next message
I'm quite unsure about how to design an RCP using a service plug-in which interacts with an EJB service bean. Maybe you have a quite good idea?
Here the general overview:
On the backend side there's an EJB3 pojo representing a project containing the fields id and name, which is made persistent using a database (CMP).
There's a stateless session bean providing services via RMI, let's name it ProjectServiceBean.
Now, an RCP should be developed to create/read/write project pojo's managed by the EJB3 service/container.
The project object is not revealed to EJB client, i.e. a value transfer object ist used: ProjectValue.
Now, the RCP application shall access those projects and interact with the ProjectServiceBean to get all projects (list), add, remove and change.
For EJB abstraction another plug-in is to be developed to provide services to other plugins via framework.
So OSGi-service would provide actually the same services like list, add, remove, change.
Questions
So how would you encapsulate/present the data on the model-side?
Would you wrap-up that ProjectValue using another wrapper pojo? Especially with regards to databinding maybe in a table viewer using PropertyChangeSupport.
Would you use a bean within the rcp model shown below and update that repository using events of/to OSGi-service?
public class ProjectValueWrapper {
	PropertyChangeSupport changeSupport = new PropertyChangeSupport(this);
	private ProjectValue value;
	private Set<ProjectValueWrapper > list;
	public ProjectValueWrapper (String text) {
                value = new ProjectValue();
		list = new HashSet<ProjectValueWrapper>();
	public void addPropertyChangeListener(PropertyChangeListener listener) {
		changeSupport.addPropertyChangeListener(listener);
	public void removePropertyChangeListener(PropertyChangeListener listener) {
		changeSupport.removePropertyChangeListener(listener);
	public String getText() {
		return value.getText();
	public void setText(String text) {
                String t = getText();
                value.setText(text);
		changeSupport.firePropertyChange("text", t, text);
	public Set<ProjectValueWrapper> getList() {
		if (list == null)
			return null;
		return new HashSet<ProjectValueWrapper>(list);
	public void setList(Set<ProjectValueWrapper> list) {
		if (list != null)
			list = new HashSet<ProjectValueWrapper>(list);
		changeSupport.firePropertyChange("list", this.list, this.list = list);
	public boolean hasListeners(String propertyName) {
		return changeSupport.hasListeners(propertyName);
What is your opinion on that issue particularly with regards to best practises?
Sebastian
[Updated on: Sun, 28 March 2010 17:07] by Moderator
Re: How to? / RCP with service plug-in and EJB3 interaction [message #523763 is a reply to message #523696] Mon, 29 March 2010 04:49 Go to previous message
Hey,
I was just thinking on the whole thing again and came to the following conclusion:
1. EJB3 entity bean still a pojo
2. Adding PropertyChangeSupport to transfer object
3. DTO will be used in UI/by OSGi service, which itself interacts with the EJB service
Would you think this to be a good approach?
Sebastian
Previous Topic:Export to Multiple Platforms
Next Topic:Restart after an update?
Current Time: Sat Jul 26 04:38:01 EDT 2025
Powered by FUDForum. Page generated in 0.08430 seconds
