Home » Eclipse Projects » Eclipse 4 » org.eclipse.e4.xwt.XWTException(All forms being executed throws XWTException)
org.eclipse.e4.xwt.XWTException [message #521811] |
Thu, 18 March 2010 15:04  |
I have this example from the test examples:
<Composite xmlns="http://www.eclipse.org/xwt/presentation"
xmlns:j="clr-namespace:test.ui"
xmlns:x="http://www.eclipse.org/xwt">
<Composite.layout>
<GridLayout numColumns="1" />
</Composite.layout>
<Section name="Section" x:style="Section.TITLE_BAR|Section.TWISTIE|Section.EXPANDED "
text="Section Two">
<Section.client>
<Label name="Section.Label" text="test" />
</Section.client>
</Section>
</Composite>
with the following code-behind:
package snippets.e4.forms;
import java.net.URL;
import org.eclipse.e4.xwt.IConstants;
import org.eclipse.e4.xwt.XWT;
public class Section
public static void main( String[] args )
URL url = Section.class.getResource( Section.class.getSimpleName() + IConstants.XWT_EXTENSION_SUFFIX );
try
XWT.open( url );
catch( Exception e )
e.printStackTrace();
Running the code-behind throws this exception:
org.eclipse.e4.xwt.XWTException: Type Section is not found.
at org.eclipse.e4.xwt.XWTLoader.getMetaclass(XWTLoader.java:899 )
at org.eclipse.e4.xwt.javabean.ResourceLoader.doCreate(Resource Loader.java:419)
at org.eclipse.e4.xwt.javabean.ResourceLoader.doCreate(Resource Loader.java:648)
at org.eclipse.e4.xwt.javabean.ResourceLoader.doCreate(Resource Loader.java:449)
at org.eclipse.e4.xwt.javabean.ResourceLoader.createCLRElement( ResourceLoader.java:353)
at org.eclipse.e4.xwt.internal.core.Core.createCLRElement(Core. java:606)
at org.eclipse.e4.xwt.internal.core.Core.load(Core.java:646)
at org.eclipse.e4.xwt.internal.core.Core.load(Core.java:633)
at org.eclipse.e4.xwt.XWTLoader.loadWithOptions(XWTLoader.java: 835)
at org.eclipse.e4.xwt.XWTLoader$1.run(XWTLoader.java:768)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.e4.xwt.XWTLoader.open(XWTLoader.java:762)
at org.eclipse.e4.xwt.XWTLoader.open(XWTLoader.java:714)
at org.eclipse.e4.xwt.XWT.open(XWT.java:411)
at snippets.e4.forms.Section.main(Section.java:17)
A similar exception is thown for all my forms.
My dependencies in e4 are:
javax.inject;bundle-version="1.0.0",
org.eclipse.core.resources;bundle-version="3.6.0",
org.eclipse.core.runtime;bundle-version="3.6.0",
org.eclipse.swt;bundle-version="3.6.0",
org.eclipse.core.databinding;bundle-version="1.3.0",
org.eclipse.core.databinding.beans;bundle-version="1.2.0",
org.eclipse.jface;bundle-version="3.6.0",
org.eclipse.jface.databinding;bundle-version="1.4.0",
org.eclipse.e4.ui.services;bundle-version="0.9.1",
org.eclipse.e4.ui.workbench;bundle-version="0.9.1",
org.eclipse.e4.core.services;bundle-version="0.9.1",
org.eclipse.e4.ui.workbench.swt;bundle-version="0.9.1",
org.eclipse.core.databinding.property;bundle-version="1.2.100 ",
org.eclipse.e4.ui.css.core;bundle-version="0.9.0",
org.w3c.css.sac;bundle-version="1.3.0",
org.eclipse.e4.core.commands;bundle-version="0.9.0",
org.eclipse.e4.ui.bindings;bundle-version="0.9.0",
org.junit4;bundle-version="4.7.0",
org.eclipse.e4.xwt;bundle-version="0.9.1",
com.ibm.icu;bundle-version="4.2.1",
org.eclipse.e4.xwt.tests;bundle-version="0.9.1",
org.eclipse.e4.xwt.forms;bundle-version="0.9.1",
org.eclipse.ui.forms;bundle-version="3.5.0"
I don't know exactly why the xwt and swt form packages are not being recognized.
Similarl, the form fails to be displayed in the XWT editor.
Any help will be appreciated.
Re: org.eclipse.e4.xwt.XWTException [message #521866 is a reply to message #521811] |
Thu, 18 March 2010 20:25   |
You need org.eclipse.e4.xwt.forms plugin. You can find examples in the
package org.eclipse.e4.xwt.test.forms
yves
"St Clair Clarke" <st_clair@flowja.com> wrote in message
news:hnttfe$g3b$1@build.eclipse.org...
> Hello,
> <Composite.layout>
> </Composite.layout>
> text="Section Two">
> <Section.client>
> </Section.client>
> </Section>
> </Composite>
> try
> XWT.open( url );
> Loader.java:419)
> Loader.java:648)
> Loader.java:449)
> (Realm.java:332)
> recognized.
> Thanks
Re: org.eclipse.e4.xwt.XWTException [message #522084 is a reply to message #522078] |
Fri, 19 March 2010 16:55   |
St Clair Clarke wrote on Fri, 19 March 2010 23:28 |
Thanks. And the fault was mine. Just missed that important piece of code.
Yes, this was surprise for me too.
St Clair Clarke wrote on Fri, 19 March 2010 23:28 | All the forms are now working, but I noticed something peculiar.
None of the forms are displayed in the designer. The designer just has a text saying Loading...
This is also what the cvs checkout does.
Any idea why the forms are not being rendered in the Designer?
As we know now, support for Forms lives in separate plugin which does not contribute anything into main XWT. Instead you should "pull" this support by using special renderer - XWTForms. As I can see, this is not done in org.eclipse.e4.xwt.tools.ui.designer plugin. So, no rendering for Forms.
I've noticed also that org.eclipse.e4.xwt.tools.ui.designer has class org.eclipse.e4.xwt.tools.ui.designer.loader.ResourceVisitor which is almost identical to the org.eclipse.e4.xwt.javabean.ResourceLoader in XWT library itself. So, probably, currently designer is just quick and dirty implementation to prove concept of XML based SWT UI editing and not all features are supported.
Re: org.eclipse.e4.xwt.XWTException [message #572200 is a reply to message #523603] |
Sun, 28 March 2010 10:38  |
Hello Yves,
Thanks for the reply. Please reply with a small example of how this registration should be done.
I have tried to to this in the code-behind class of the corresponding XWT forms but then the XWT.register() does not allow it.
St Clair
Current Time: Wed Jul 23 07:44:46 EDT 2025
Powered by FUDForum. Page generated in 0.08029 seconds
