Home » Eclipse Projects » Remote Application Platform (RAP) » EMF RAP and Tomcat deployment
EMF RAP and Tomcat deployment [message #523546] |
Fri, 26 March 2010 14:17  |
Hi all,
I'm new to the web app side of things and I've been trying to get a tomcat deployment of an (arbitrary) EMF model working. Here's what I've been able to accomplish:
1. Get the example WARs (non-EMF) up and running.
2. Get the EMF library example and my own custom examples working as hosted runtimes both using the editor application and the entry point approaches.
3. Read all of the docs on troubleshooting, etc..
Despite a day of fumbling around, I have not been able to get an EMF editor working on Tomcat. Nor have I been able to get the RAP ant build working OOTB, but I am able to get it working with just a little bit of fiddling. (Changing the lib and editing the config.ini.) I was able to learn a lot by tearing apart a working RAP jar and diffing that against what the builder was making. My sense is that I'm probably pretty close, but the trial and error is wearing pretty thin and the working WAR I'm looking at has pretty old dependencies so there are a lot of pieces to fiddle around with.
One of the problems is that once I get the dependency issues fixed that show up in the work dir logs and assuming that I don't have any other messed up configuration issues, I'm not seeing anything in any of the logs, just an error msg on console, e.g. : message ProxyServlet: /rapf5 "The requested resource (ProxyServlet: /rapf5) is not available."
My suspicion is that I just have something that isn't set up right on the plugin extension side or there is something missing from my deployment plugins or config.ini..no matter ow carefully one goes through that, it's easy to miss something. If I add the demos into my config.ini, I get the demos working, but if I take them out and add the library example dependencies, it doesn't.
This is all just a lead in to ask if someone has a working set of projects or even a WAR file that work for tomcat deployment of EMF so that I can dissect them.
cheers -- and I really think EMF support is an exciting development,
Miles
[Updated on: Fri, 26 March 2010 14:19] by Moderator
Re: EMF RAP and Tomcat deployment [message #524015 is a reply to message #523546] |
Tue, 30 March 2010 06:18   |
Miles,
I recommend to start with the tutorial that comes with the RAP Tooling
(Help System -> RAP Developer Guide -> Advanced Topics WAR Development)
and can also be read online
< http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .rap.help/help/html/advanced/deployment.html>.
Note that the online tutorial applies to RAP 1.2.
You will end up with a functioning WAR file that contains the RAP
workbench demo.
Based on that you should be able to add EMF and other bundles to the
feature, rebuild and update the config.ini accordingly.
The FAQ <http://wiki.eclipse.org/RAP/FAQ> also contains several hints
regarding WAR deployment.
A ready-made WAR file that contains all the RAP demo applications can be
found in the online examples:
http://rap.eclipsesource.com/rapdemo/examples
(use the "Download the Example WAR" link at the right bottom)
If you have any further question, feel free to ask here.
HTH
Rüdiger
On 26.03.2010 19:18, Miles Parker wrote:
> Hi all,
> 1. Get the example WARs (non-RAP) up and running.
> approaches.
> fiddle around with.
> Miles
Rüdiger Herrmann
http://eclipsesource.com
Re: EMF RAP and Tomcat deployment [message #524363 is a reply to message #524091] |
Wed, 31 March 2010 12:11  |
Miles,
as there is currently no ready made EMF deployment example, I would
suggest to get the deployment from the tutorial with 1.3 M5 running.
I can't find any issues with M5 and the the WAR tutorial. However,
please feel free to post your problems here.
Once you are there it should be no problem at all to add EMF and the
library example.
Rüdiger
Rüdiger Herrmann
On 30.03.2010 18:10, Miles Parker wrote:
> Hi Rüdiger,
> Please see below..
> Rüdiger Herrmann wrote on Tue, 30 March 2010 06:18
>> Miles,
>> Development) and can also be read online <
>> .rap.help/help/html/advanced/deployment.html>. Note that the online
>> workbench demo.
>> be found in the online examples:
> I followed all of those examples and docs quite closely -- see original
> msg. Unfortunately, the ready made WAR has older dependencies so there
> isn't a one to one correspondence -- i.e. I can't take the new demo
> library EMF example and simply add those dependencies to the existing
> project. What I get out of the builder example doesn't build out of the
> box with the latest release either though as I say its pretty close.
> There are enough variables to get right that it's become a matter of
> trial and error and I haven't had time to keep going through that cycle
> more for the time being and I've gotten to the point that even with all
> the FAQ hints about various logs to check, I'm getting nothing to go on
> from tomcat except for the failure itself. For example, I can't tell if
> its failing because I don't have the right dependencies (I think it
> does, because I got to the point where there weren't dependency errors
> in the log anymore) or because somehow I don't have the application
> entry stuff set up right. So really it would just be helpful to have an
> example for an EMF installation itself. Otherwise I'll just post back
> here with details on what isn't working in build process when I have
> time to experiment more.
> thanks,
> Miles
Current Time: Sat Jul 26 11:35:41 EDT 2025
Powered by FUDForum. Page generated in 0.04579 seconds
