Home » Eclipse Projects » EclipseLink » Initialize EclipseLink at runtime
Initialize EclipseLink at runtime [message #523076] Wed, 24 March 2010 15:10 Go to next message
My question is if it is possible to initialize EclipseLink at runtime without making use of hardcopy files (like
persistence.xml or orm.xml). Can the mapping be supplied as an inputstream for example?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Initialize EclipseLink at runtime [message #523105 is a reply to message #523076] Thu, 25 March 2010 02:36 Go to previous messageGo to next message
On 2010-03-25 0:38, Martin Taal wrote:
> without making use of hardcopy files (like persistence.xml or orm.xml).
AFAIK Eclipselink can completely be configured using Java code. However, I'm not sure if the JPA standard requires the persistence.xml to be present (so that would be a definition issue).
Re: Initialize EclipseLink at runtime [message #523268 is a reply to message #523076] Thu, 25 March 2010 13:39 Go to previous messageGo to next message
Using the JPA Persistence class, you need to have a persistence.xml.
You could call the EclipseLink PersistenceProvider class directly, or create the EclipseLink EntityManagerFactoryImpl directly.
You would still need some way to define your persistence info and mappings. You could create your EclipseLink ServerSession and ClassDescriptor and DatabaseMappings directly through code, or use the MetadataProcessor to parse your annotations if you have that.
Why can't you have a file? Where is your mapping info coming from?
Re: Initialize EclipseLink at runtime [message #523469 is a reply to message #523268] Fri, 26 March 2010 10:01 Go to previous messageGo to next message
Thanks, I am generating the orm mapping at runtime therefore it is far more handier to not have it in a file somewhere.
The easiest would be if there is an api which just gets an inputstream or string which I can use. Does such an api exist
(this is what the MetaDataProcessor can do, correct?)?
Btw, I could not find the MetadataProcessor class (I am using Helios), where is it located?
I still would need a persistence.xml file somewhere? Or is there a way to also do that part programmatically?
gr. Martin
The Netherlands
Re: Initialize EclipseLink at runtime [message #523914 is a reply to message #523076] Mon, 29 March 2010 15:32 Go to previous message
It might be easier to build the RelationalDescriptor and DatabaseMappings directly, instead of generating an orm.xml file then parsing it.
MetadataProcessor is in,
org.eclipse.persistence.internal.jpa.metadata
Previous Topic:Bug in NOT MEMBER OF translation?
Next Topic:audit tracking
Current Time: Wed Jul 23 05:29:15 EDT 2025
Powered by FUDForum. Page generated in 0.03650 seconds
