Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Setting cell focus in TableViewer(SWT Table)
Setting cell focus in TableViewer [message #523255] Thu, 25 March 2010 12:38 Go to next message
I've seen a couple other posting references but most are several years old.
Is there a way to set focus on a particular cell in a table? I've tried everything I can think of and had no luck.
Thanks.
Re: Setting cell focus in TableViewer [message #523361 is a reply to message #523255] Fri, 26 March 2010 03:44 Go to previous messageGo to next message
Maybe org.eclipse.jface.viewers. FocusCellOwnerDrawHighlighter is what your looking for?
Here's an example:
http://dl.dropbox.com/u/2610519/TestTable.zip
Re: Setting cell focus in TableViewer [message #523362 is a reply to message #523255] Thu, 25 March 2010 23:10 Go to previous messageGo to next message
Snippet036FocusBorderCellHighlighter in JFace snippets might be helpful
for your scenario.
Re: Setting cell focus in TableViewer [message #523462 is a reply to message #523255] Fri, 26 March 2010 05:40 Go to previous messageGo to next message
At the swt level this is done with TableCursor, for an example see
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet96.java?view=co .
Grant
"Brian" <nebulour@gmail.com> wrote in message
news:hog3ir$ttr$1@build.eclipse.org...
old.
> Thanks.
Re: Setting cell focus in TableViewer [message #523850 is a reply to message #523255] Mon, 29 March 2010 11:40 Go to previous message
Thanks for the replies. I've looked at some of the examples and I'll keep experimenting but I was hoping for a relatively simple way to programatically put the focus in a particular cell.
Say if I have 5 rows and 4 columns, put the focus (as if a mouse click) in row 2, column 3.
It doesn't seem like it should be that difficult.
Previous Topic:Set sorting column using keyboard
Next Topic:Treeviewer Scrollbar vanishing act
Current Time: Sun Aug 31 12:08:35 EDT 2025
Powered by FUDForum. Page generated in 0.03901 seconds
