Re: Most egit functionality grayed out... [message #578990 is a reply to message #523351] |
Thu, 08 April 2010 11:33  |
"Michael Heuberger" <michael.heuberger@binarykitchen.com> wrote in message
news:hohfol$b1b$1@build.eclipse.org...
> at org.eclipse.egit.core.op.TrackOperation.run(TrackOperation.j ava:75)
> ... 2 more
This line of code (rm.getRepository().getIndex()) indicates that EGit does
not correctly configure the git repository.
Can you point us to such a repository which causes problems? One, we could
clone ourselves to reproduce the issue?
I would suppose that EGit may have problems with some special features of
git.
Stefan
Re: Most egit functionality grayed out... [message #579017 is a reply to message #579004] |
Fri, 09 April 2010 10:42  |
> Thank you but I'm afraid I can't reveal the source of the repository
> because it's a commercial project.
I had already suspected that...
> Just tell me what else you need to know and I'll collect the information
> for you.
Lets try:
Does your repo use submodules?
Can you describe the folder structure of your repo: where are the .project
files and where are the .git folders?
Go to the project properties, select git: Is the Git directory path
displayed correctly?
If you unshare your project and share it again, is the correct repo found in
the dialog?
Thanks for you help,
Stefan
Re: Most egit functionality grayed out... [message #579059 is a reply to message #526302] |
Fri, 09 April 2010 20:29  |
Re-Hi Stefan
Here my answers:
I don't know what submodules are but I don't think my Project X has any submodules
Can you describe the folder structure of your repo: where are the .project files and where are the .git folders?
In this directory there are all the project files:
D:\Code\Zend Studio Workspace\Project X
And within lies the .git folder:
D:\Code\Zend Studio Workspace\Project X\.git
Yes, the working directory and git directory are correct.
If you unshare your project and share it again, is the correct repo found in the dialog?
No need, the correct repo is displayed.
By the way, for unknown reasons, the menu items aren't greyed out anymore. I think this happened after I have unshared and shared the project again ...
Cheers
Michael
PS: When is the merging functionality coming? I am waiting for it ... :)
Re: Most egit functionality grayed out... [message #579317 is a reply to message #579059] |
Tue, 13 April 2010 05:40  |
Hi Michael,
so you had shared/imported your project with an older version of EGit and
after upgrade to 0.7.1 you got the problems?
Do you know which version you had before?
If you newly import the repo and the projects do you still have this
problems? Can you work now without errors?
Thanks and Regards,
Stefan
Re: Most egit functionality grayed out... [message #579477 is a reply to message #526849] |
Tue, 13 April 2010 20:57  |
Hi Stefan
Right, previously I used EGit 0.6 and then after upgrading to 0.7.1 through the autoupdate in Zend Studio this problem happened.
I solved it myself by deleting and re-creating the repo. There are no errors anymore and I am able to work again.
When is the merging coming?
Cheers
Michael
Re: Most egit functionality grayed out... [message #579494 is a reply to message #579477] |
Wed, 14 April 2010 08:34  |
We should then test this scenario.
Great!
We plan for 0.8.0 which may be released in early June to match up with the
Eclipse Helios simultaneous release.
FUDForum. Page generated in 0.14043 seconds
