Build from Source Qs [message #522901] |
Wed, 24 March 2010 09:14  |
I was trying to build STEM from source so I can start making a modified version, but am having trouble. The guidance I was using is here http://wiki.eclipse.org/index.php/STEM_Source_Code (to get source, which worked fine) and here http://wiki.eclipse.org/index.php/Installation_Guide (looking under Preparing to Run STEM as a STEM Developer).
I imported STEM (tried both the branches\STEM_1_0_0\ and trunk\ versions) into Eclipse. It builds everything it imports, but there were errors in a few packages. These were all due to failed imports from org.eclipse.birt. I looked up BIRT on the Eclipse site, and found this page to acquire it: http://wiki.eclipse.org/BIRT_Update_Site_URL
My Eclipse Platform is
Version: 3.5.2.R35x_v20100210-0800-9hEiFzmFst-TiEn9hNYgDWg1XN8ulH_JvC NGB
Build id: M20100211-1343
so I tried the BIRT 2.5.x milestone build which says it is compatible with Eclipse Platform 3.5.2. (I also tried the release build for Eclipse 3.5, just to see).
The STEM imports for BIRT are now alright, but STEM still won't start. I use the ANT script to build the internal data, then try to run the UI package. The STEM splash screen comes up, then I get the error pasted below.
I looked around a little online, but am not experienced with Eclipse and was hoping someone else will know right away how to resolve this. There looks to be a version error for org.eclipse.ecf.provider.filetransfer_3.0.1. In my plugins folder I have: org.eclipse.ecf.provider.filetransfer_3.0.1.v20090831-1906.j ar
Full error log below.
Doug
!SESSION 2010-03-23 17:53:09.482 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_17
Framework arguments: -product org.eclipse.stem.ui.product
Command-line arguments: -product org.eclipse.stem.ui.product -data C:\Documents and Settings\drafalsk\workspace/../runtime-stem.product -dev file:C:/Documents and Settings/drafalsk/workspace/.metadata/.plugins/org.eclipse.pde.core/stem.product/dev.properties -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.app 0 0 2010-03-23 17:53:10.670
!MESSAGE Product org.eclipse.stem.ui.product could not be found.
!ENTRY org.eclipse.osgi 4 0 2010-03-23 17:53:10.685
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:236)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
!ENTRY org.eclipse.osgi 2 0 2010-03-23 17:53:10.717
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-03-23 17:53:10.717
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.repository_1.0.1.R35x_v20100105.jar/ was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.repository 2 0 2010-03-23 17:53:10.717
!MESSAGE Missing required bundle org.eclipse.ecf.provider.filetransfer_3.0.1.
!ENTRY org.eclipse.osgi 2 0 2010-03-23 17:53:10.732
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-03-23 17:53:10.732
!MESSAGE Bundle org.eclipse.equinox.p2.metadata.repository_1.0.101.R35x_v20090812 [64] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.metadata.repository 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing imported package org.eclipse.equinox.internal.p2.persistence_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.p2.repository_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.p2.repository.helpers_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.provisional.p2.repository_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.provisional.spi.p2.repository_0.0.0.
!MESSAGE Bundle org.eclipse.ui.navigator.resources_3.4.1.M20090826-0800 [101] was not resolved.
!SUBENTRY 2 org.eclipse.ui.navigator.resources 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.ui.ide_[3.5.0,4.0.0).
!MESSAGE Bundle org.eclipse.ui.ide_3.5.2.M20100113-0800 [102] was not resolved.
!SUBENTRY 2 org.eclipse.ui.ide 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.equinox.p2.engine_[1.0.100,2.0.0).
!MESSAGE Bundle org.eclipse.equinox.p2.artifact.repository_1.0.101.R35x_v20090721 [106] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.artifact.repository 2 0 2010-03-23 17:53:10.732
!MESSAGE Bundle org.eclipse.equinox.p2.engine_1.0.102.R35x_v20091117 [114] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.equinox.p2.metadata.repository_1.0.100.
!MESSAGE Missing imported package org.eclipse.equinox.internal.p2.metadata.repository_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.p2.metadata.repository.io_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.provisional.p2.artifact.repository_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.provisional.p2.metadata.repository_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.provisional.spi.p2.metadata.repository_0.0.0.
!MESSAGE Bundle org.eclipse.ui.win32_3.2.100.v20090429-1800 [115] was not resolved.
!SUBENTRY 2 org.eclipse.ui.win32 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing host org.eclipse.ui.ide_[3.2.0,4.0.0).
!MESSAGE Bundle org.eclipse.equinox.p2.repository_1.0.1.R35x_v20100105 [117] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.repository 2 0 2010-03-23 17:53:10.732
!MESSAGE Bundle org.eclipse.stem.diseasemodels.forcing_1.0.0.qualifier [721] was not resolved.
!SUBENTRY 2 org.eclipse.stem.diseasemodels.forcing 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.stem.diseasemodels_0.0.0.
!MESSAGE Missing required bundle org.eclipse.stem.definitions_0.0.0.
!MESSAGE Bundle org.eclipse.stem.internal.data.geography.population.human.models_1.0.0.qualifier [724] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.data.geography.population.human.models 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.stem.internal.data_0.0.0.
!MESSAGE Missing required bundle org.eclipse.stem.internal.data.geography_0.0.0.
!MESSAGE Missing required bundle org.eclipse.stem.internal.data.geography.models_0.0.0.
!MESSAGE Bundle org.eclipse.stem.ui.populationmodels_1.0.0 [727] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.populationmodels 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.stem.populationmodels_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.ide_0.0.0.
!MESSAGE Missing required bundle org.eclipse.stem.ui_0.0.0.
!MESSAGE Bundle org.eclipse.stem.populationmodels_1.0.0 [728] was not resolved.
!SUBENTRY 2 org.eclipse.stem.populationmodels 2 0 2010-03-23 17:53:10.732
!MESSAGE Bundle org.eclipse.stem.internal.data.geography.population_1.0.0.qualifier [730] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.data.geography.population 2 0 2010-03-23 17:53:10.732
!MESSAGE Bundle org.eclipse.stem.internal.data.geography.infrastructure.transportation_1.0.0.qualifier [731] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.data.geography.infrastructure.transportation 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.stem.transport_0.0.0.
!MESSAGE Bundle org.eclipse.stem.ui.reports_1.0.0.qualifier [733] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.reports 2 0 2010-03-23 17:53:10.732
!MESSAGE Bundle org.eclipse.stem.diseasemodels.externaldatasource_1.0.0.qualifier [734] was not resolved.
!SUBENTRY 2 org.eclipse.stem.diseasemodels.externaldatasource 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.stem.util.analysis_0.0.0.
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.ui.ge_1.0.0.qualifier [736] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.ge 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.solvers.rk_1.0.0 [737] was not resolved.
!SUBENTRY 2 org.eclipse.stem.solvers.rk 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.analysis.automaticexperiment_1.0.0.qualifier [738] was not resolved.
!SUBENTRY 2 org.eclipse.stem.analysis.automaticexperiment 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.stem.util.loggers_0.0.0.
!MESSAGE Bundle org.eclipse.stem.definitions_1.0.0.qualifier [741] was not resolved.
!SUBENTRY 2 org.eclipse.stem.definitions 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.internal.diseasemodels.scenarios_1.0.0.qualifier [742] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.diseasemodels.scenarios 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.internal.data.geography_1.0.0.qualifier [745] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.data.geography 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.solvers.fd_1.0.0 [746] was not resolved.
!SUBENTRY 2 org.eclipse.stem.solvers.fd 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.diseasemodels_1.0.0.qualifier [748] was not resolved.
!SUBENTRY 2 org.eclipse.stem.diseasemodels 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.internal.data.geography.models_1.0.0.qualificer [749] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.data.geography.models 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.ui.diseasemodels.externaldatasource_1.0.0.qualifier [750] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.diseasemodels.externaldatasource 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.stem.diseasemodels.externaldatasource_0.0.0.
!MESSAGE Missing required bundle org.eclipse.stem.ui.diseasemodels_0.0.0.
!MESSAGE Bundle org.eclipse.stem.ui.diseasemodels.example_1.0.0.qualifier [751] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.diseasemodels.example 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.stem.diseasemodels.example_0.0.0.
!MESSAGE Bundle org.eclipse.stem.ui.diseasemodels_1.0.0.qualifier [752] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.diseasemodels 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.ui.navigator.resources_0.0.0.
!MESSAGE Bundle org.eclipse.stem.transport_1.0.0.qualifier [754] was not resolved.
!SUBENTRY 2 org.eclipse.stem.transport 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.ui_1.0.0.qualifier [755] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.util.analysis_1.0.0.qualifier [756] was not resolved.
!SUBENTRY 2 org.eclipse.stem.util.analysis 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.ui.diseasemodels.forcing.editor_1.0.0.qualifier [757] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.diseasemodels.forcing.editor 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.stem.diseasemodels.forcing_0.0.0.
!MESSAGE Bundle org.eclipse.stem.util.loggers_1.0.0.qualifier [758] was not resolved.
!SUBENTRY 2 org.eclipse.stem.util.loggers 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.internal.data_1.0.0.qualifier [760] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.data 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.internal.diseasemodels.models_1.0.0.qualifier [761] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.diseasemodels.models 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.ui.solvers.rk_1.0.0 [762] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.solvers.rk 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.stem.solvers.rk_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.ide_3.4.2.
!MESSAGE Bundle org.eclipse.stem.diseasemodels.example_1.0.0.qualifier [763] was not resolved.
!SUBENTRY 2 org.eclipse.stem.diseasemodels.example 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.ui.nl1_1.0.0.qualifier [766] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.nl1 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing host org.eclipse.stem.ui_0.0.0.
!MESSAGE Bundle org.eclipse.stem.ui.solvers.fd_1.0.0 [767] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.solvers.fd 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.stem.solvers.fd_0.0.0.
Re: Build from Source Qs [message #525812 is a reply to message #525801] |
Wed, 07 April 2010 16:56   |
hooray, progress! This is not a STEM error, so I think that DR can be closed since the updated stem.product works for both of you.
It looks to be an installation / eclipse error, as noted in this thread. I made it a lot farther in the export process this time, now I get:
Framework arguments: -product org.eclipse.epp.package.reporting.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.reporting.product
Error
Wed Apr 07 16:50:56 EDT 2010
Missing requirement: STEM 1.0.1 (org.eclipse.stem.ui.product 1.0.1) requires 'org.apache.commons.codec [1.3.0.v20080530-1600]' but it could not be found
I'll go try to add it and see if I hit other errors...
Update -- I don't need to add it, it is already listed in the plug-ins. Two versions are:
Id: org.apache.commons.codec, Version: 1.3.0.v20080530-1600, Location: reference:file:plugins/org.apache.commons.codec_1.3.0.v20080 530-1600.jar
Id: org.apache.commons.codec, Version: 1.3.0.v20100106-1700, Location: reference:file:plugins/org.apache.commons.codec_1.3.0.v20100 106-1700.jar
So I'll have to figure out how to sort that out later.
Thanks for the help!
Update 2 -- I just changed the stem.product dependencies to specify version 1.3.0.v20080530-1600 for org.apache.commons.codec and it built. Not sure if that is the best way to fix it, but it gets me what I need for now.
[Updated on: Wed, 07 April 2010 17:15] by Moderator
Re: Build from Source Qs [message #563220 is a reply to message #563195] |
Thu, 08 April 2010 16:27  |
Hi Doug, I don't think we're dependent on a specific version of commons.codec (the dependencies aren't in STEM, they're in Eclipse packages). Also it looks like Eclipse still ships (as of 3.5.2) the 20080530 version. Not sure where the 20100106 one comes in, unless it's part of another feature in your Eclipse SDK install.
I think your local fix is probably the best course of action.
FUDForum. Page generated in 0.30619 seconds
